Old 03-10-2007, 03:26 PM   #1
Drew888
Member#: 6459
2008 LGT Spec-B stg4
Delicious Tuned 336/336
Default Confirmed 18x8 rims that fit lowered WRX Wagon
Ok, I last asked about 17's that at first looked more like 18's. I prefer the 18" look much more but grip is slightly more important...So...
I need an 8" rim and if I can get it to fit properly under my fender in an 18" size then that's preferred.
Who has 18x8's on their wagons? Curious as to what choices we have.
What rim:
Offset:
Suspension:
Measured drop
(center of hub to bottom of fender):
I assume all will already have rear fenders rolled/cut.
Please post a pic if you can; side (drop), and rear (clearance view).
Thanks guys!!
Drew
Drew888 is offline   Reply With Quote
Old 03-10-2007, 08:36 PM   #2
manz79
Member#: 111505
07 STi
Black GT3076
A freind of mine has an 04 wagon his setup
Prodrive springs
Prodrive PFF7
+51
225/40 tires
fender NOT rolled
manz79 is offline   Reply With Quote
Old 03-10-2007, 08:56 PM   #3
kenny08
Member#: 79907
02 blue wagon
18g goodnesss
OZ superleggera 18x8 +51
prodrive springs
rolled front and rear fenders
235/40/18
kenny08 is offline   Reply With Quote
Old 03-13-2007, 12:10 AM   #4
Drew888
Member#: 6459
Kenny...got a pic?
Old 03-13-2007, 07:34 PM   #5
chewbakarox
Member#: 25478
2003 WRX Sport Wagon
What rim: SSR GT2, 18x8
Offset: +51
Tires: 225/40/18 Kumho Ecsta MX
Suspension: Prodrive springs on OEM struts
Measured drop (center of hub to bottom of fender): Unknown, but somewhere around 2" front and 1.5" rear
None of the fenders are rolled, and absolutely NO rubbing whatsoever. Clearance between the strut and inside lip of the wheel/tire is more of an issue than fender clearance. Got a great deal on these rims when Tire Rack had them on clearance.....
chewbakarox is offline   Reply With Quote
Old 03-14-2007, 05:35 PM   #6
fuzzymemory
Member#: 63477
04 WRX Wagon
San Remo Red
Any more feedback on these? I've read that the offset is ideal for wagons... are the Kumhos the only tires you have run on them? Also, have you done anything in regards to the clearance issues between the strut and the inside lip of the tire? Do you think they would rub against coilovers?
Offset: +51
fuzzymemory is offline   Reply With Quote
Old 03-14-2007, 08:13 PM   #7
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
I think anything between +47~+53mm would be okay. It is really down to the tire choice though...
What rim: SSR Comp, 18x8
Offset: +51mm
Tires: 225/40/18 Kumho ASX
Suspension: Stock STi springs
Stock fender and no rub at all.
minifreak is offline   Reply With Quote
Old 03-15-2007, 11:07 AM   #8
chewbakarox
Member#: 25478
Fuzz - The Kumhos are the only tires I've had on the SSRs. Clearance between the tire/strut was close, but not to the point where I had to do anything about it. I have a feeling if I went with a 235 tire I would have had some problems.
Really can't answer your question on coilovers - not sure how much bigger they typically are compared to the OEM struts.
Old 03-16-2007, 08:54 AM   #9
fuzzymemory
Member#: 63477
04 WRX Wagon
San Remo Red
I have a very sad SSR GT2, 18x8 story. I'll post it a little later in this forum once I'm done crying. (FYI - this is a seller-error issue, nothing wrong w/ SSR or their manufacturing quality)
Old 03-17-2007, 12:27 PM   #10
Drew888
Member#: 6459
So it seems the consensus is that we may be limited to a 225. I don't know how wide the contact patch is (still have to search) but a 235 or more on a 17" rim might have an advantage - grip wise that is.
Old 05-13-2007, 01:37 PM   #11
EagleRockWrex
Member#: 95780
2008 Infinity G37S
Ivory/Black
Going to be running 225/45/18 on an 18x8 Rota Formula. Stock suspension, going to be running STi Pinks. Wish me luck. Any pictures or sucess stories with this combo would be appreciated. Offset is +48
EagleRockWrex is offline   Reply With Quote
Confirmed 225/45-17" tires that fit lowered WRX Wagon omahasubaru Tire & Wheel 462 09-04-2016 07:10 AM
16" rims that fit 06 wrx 06blksubwrx Tire & Wheel 2 02-26-2007 11:11 PM
15" rims that fit over wrx brakes Guerice Private 'Wanted' Classifieds 3 09-01-2006 05:45 PM
MI - Rims to fit 2005 WRX Wagon Murf_68 Private 'Wanted' Classifieds 10 07-13-2005 07:31 PM
Who makes front lips that fit 2002 WRX wagon? Leandro Interior & Exterior Modification 10 08-02-2004 10:57 AM
