Old 03-10-2007, 07:48 PM   #1
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
Default Info STi Oil Pan on WRX
I have decided to make this post to help others who are intersted in this since I found several posts with conflicting or bad information.
The STi oil pan was installed to allow fitment of the APS Equal Length Header. I do not know if the STi pan has better baffling to prevent oil starvation or not.
Updated with part numbers and more pictures. If anyone has pictures of the inside of a STi Oil pan it would be appreciated. We did not get pictures at that stage for some reason.
Enjoy
Parts Needed
STi Oil Pan P/N: 11109AA131 List Price: $108.50
STi Oil Pickup P/N:
STi Dip Stick P/N: 11140AA120 List Price $19.13
Baffle P/N:
Pictures
Oil Pickup STi on Bottom
STi on Left (Inside it has a screen but is hard to photograph)
Differences in the Baffle STi on left
Baffle (bolted to the bottom of the blcok)
Dipstick STi on Top
Dipstick End STi on Top
snwman is offline   Reply With Quote
Old 03-10-2007, 08:27 PM   #2
prometheum
Member#: 92003
04 bicycle!
interesting
prometheum is offline   Reply With Quote
Old 03-10-2007, 08:34 PM   #3
Tilt
Member#: 92281
It's hard to tell from the photos... would you say there is a definite oil starvation prevention advantage (like the oil baffle) with the sti parts?
Tilt is offline   Reply With Quote
Old 03-10-2007, 08:38 PM   #4
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
intresting..why no screen on the sti pickup? cant tell from the angle
fastnoypi is offline   Reply With Quote
Old 03-10-2007, 08:56 PM   #5
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
What function does the baffle perform?
PaulRex is offline   Reply With Quote
Old 03-10-2007, 08:58 PM   #6
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
It keeps the oil near the oil pickup tube during hard cornering and possibly also prevents splashing.
blkscooby is offline   Reply With Quote
Old 03-10-2007, 09:36 PM   #7
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
It does have a screen just hard to see in any of the pics.
Old 03-10-2007, 09:46 PM   #8
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
Information placed into original post.
Old 03-10-2007, 09:51 PM   #9
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
thank u
Old 03-11-2007, 10:59 AM   #10
el crichon wrx
Member#: 8493
2001 Impreza GDA
PSM-01G-IHI powered
good post !
do you have the parts # for all the above necessary to install EL headers ?
oil pan, baffle, dip stick, oil pickup
that would be a great add to the "header FAQ"
Thanks.
el crichon wrx is offline   Reply With Quote
Old 03-11-2007, 12:12 PM   #11
MasterKwan
Member#: 98961
2003 WRX
How much do you have to disconnect to lift the motor and get at all the pan bolts? I'm planning on doing this too.
Old 03-11-2007, 01:28 PM   #12
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
When we did this swap we actually got the oil pans swapped without lifting the block, however it was very hard to do this. Most likely to lift the block you'd need to take off the headers, loosen the motor mounts and disconnect the pitch stop. That should give you a good area to work with, you could lift the engine by jacking on the foward part of the transmission that way.
Old 03-11-2007, 04:13 PM   #13
Johnnyblueeyes
Member#: 142528
I have an sti sb so this should be important [using wrx oil parts]
thx
Johnnyblueeyes is offline   Reply With Quote
Old 03-11-2007, 04:35 PM   #14
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
Old 05-16-2007, 10:23 PM   #15
PhastEddie
Member#: 136545
2006 Evolution IX
Good info. I stumbled across this thread as I too will be doing this VERY shortly. Do you guys recommend any sealant or is there a gasket for the oil pan??? Any other gaskets or sealant needed? I am thinking of doing STI motor mounts while I am down there. (oil pan gives me an excuse to do it) Going twinscroll!
I also forgot to ask if anyone knows the torque specs of all the bolts during the sti oil pan swap?
PhastEddie is offline   Reply With Quote
Old 05-18-2007, 11:48 PM   #16
PhastEddie
Member#: 136545
2006 Evolution IX
anyone?
Old 05-21-2007, 05:56 PM   #17
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
The oil pan has no gasket you will need something like Permatex Ultra Grey RTV. Pretty easy to find at any auto part store.
Tq Specs....I think are something really low like 7 ft lb
Old 05-31-2007, 06:26 PM   #18
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
[email protected] EJ205 4EAT
so has anyone confirmed the last two part numbers required to do this?
the baffles and pickup part number?
Jon
iNfEk is offline   Reply With Quote
Old 06-09-2007, 03:30 PM   #19
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
You need the pickup since the oil pan is shaped diffferently. You then need the baffle since it is shapped differently to accomodate the pickup. I do not have part numbers sorry
Old 06-09-2007, 03:41 PM   #20
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
thanks, but the OP posted 2 of the 4 part numbers needed i believe, that's why I was asking about the remaining p/n's
Old 06-10-2007, 02:39 AM   #21
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
I am the OP. Sorry I dont have the P/N's I got those parts for free and did not have to order them from the dealer. Just go to your dealer and have them look everything up for you...
Old 06-10-2007, 08:00 AM   #22
PhastEddie
Member#: 136545
2006 Evolution IX
I recently did this install along with all new groupn motor and tranny mounts. I could not get the oil pickups on by themselves, I had to hold them up there WITH the oil pan. A real pain. Even couldnt remove the oil pan without taking the oil pickup off. Any of you guys have the same issue?
Old 06-10-2007, 01:37 PM   #23
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
Yes I had do the same thing with the sti pan. If the motor was out I think it woudl be a lot easier
Old 07-10-2007, 05:03 PM   #24
cellobro
RIP 3/18/1965 to 1/10/2008
Member#: 91500
hmmm sr-30+640cc=?
I has teh Endless BBK.
yeah, it's a pain. love the headers, tho.
crazy car guys...
cellobro is offline   Reply With Quote
Old 07-10-2007, 07:29 PM   #25
kunfuzion
Member#: 1094
'85 Levin Hatch
color of rust
Do you know what is holding or preventing the oil pickup to be removed from the oil pan or vise versa? It looks the oil p/u is connected first, then baffle, then oil pan? Can you confirm? Thanks.
kunfuzion is offline   Reply With Quote
WRX oil pan vs STi oil pan Gigabelova Built Motor Discussion 206 04-28-2016 06:37 PM
WTB: NV STi oil pan and WRX oil cooler lowell787 Private 'Wanted' Classifieds 2 01-12-2010 10:58 AM
STi Oil Pan on 99 2.5 Engine? Soulofdarkness Normally Aspirated Powertrain 3 05-31-2009 04:31 PM
STi oil pan on bugeye? tonecold Newbies & FAQs 26 03-06-2009 12:36 PM
anyone change a wrx oil pan to sti oil pan? 1WRX2NV Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-30-2007 09:32 PM
