Old 03-11-2007, 03:46 PM   #1
NewGwrx
Member#: 103645
2011 Subaru Legacy
Default Tach is being stupid!
Ok so i took out my gauge cluster today to look and see how hard it is to change the color on my gauge cluster. I touched the needle on my tach a couple times on the speedo. Finally when i plugged everything back in my speedo was fine but my tach would not move. I unplugged and it tried to see what happened but not really to familiar with this electrical stuff. After i replugged it, the tach would move and seemed to be right but its very "sticky" and jumpy. Not smooth what so ever.
Anyone know what might have happened and what i need to do to fix it???
NewGwrx is offline   Reply With Quote
Old 03-11-2007, 06:45 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Just how hard did you "touch" the needle? They do not like to be disturbed, many people have ruined their clusters by pulling the needles off to change the gauge faces.
If you're lucky you may be able to manipulate the needle to work properly again, but if not you will need a new cluster.
Old 03-11-2007, 09:57 PM   #3
NewGwrx
Member#: 103645
2011 Subaru Legacy
i didnt touch it to hard. But its possible that the not to hard was enough to damage it. If replacing the gauge is what i need to do, what would i do about mileage and everything
Old 03-12-2007, 12:30 AM   #4
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
You do not have to replace the entire gauge cluster, you can order just the part of the unit you damaged. It is a lot cheaper this way as well from what I've read.
Old 03-12-2007, 01:11 AM   #5
RS_noob
Member#: 85325
05 2.5RS 'IMPREZA'
Regal Blue
I had the same issue and may know what the problem might be but it's a little difficult to explain. If it is the same issue I had then you do not need to buy any thing just need to go back and check your needle.
If you look between the needle and the guage face, there is a little black plastic ring that might've been pushed up into the needle housing that you need to bring down. It holds the guage face down away from the needle housing. I'm sure that made no sense but I'm pretty sure it's the same thing that I experienced. PM me if you have questions and I'll see if I can explain better.
RS_noob is offline   Reply With Quote
Old 03-12-2007, 01:18 AM   #6
RS_noob
Member#: 85325
05 2.5RS 'IMPREZA'
Regal Blue
Here's the quote from Trunk_Monkey's tutorial if that helps you understand better.
Originally Posted by Trunk_Monkey View Post
Notice that there are little black rings under the gauge needles, if they pop up, it makes it easier to slip paper under it, just make sure you push them back down before re-assembly. You know there down if the needles move easily - as if in a liquid. All they really do is hold the thing face against the frame of the gauge, they come on and off really easily
Hope that helps.
Old 03-12-2007, 09:41 AM   #7
NewGwrx
Member#: 103645
2011 Subaru Legacy
ill haveto try that when i get home later.
Old 03-12-2007, 03:16 PM   #8
NewGwrx
Member#: 103645
2011 Subaru Legacy
just popped the plastic clip under the needle back in. Works find now. Thanks for the input
Old 03-13-2007, 03:56 AM   #9
RS_noob
Member#: 85325
05 2.5RS 'IMPREZA'
Regal Blue
Nice.
wrx is being really slow Jessy403 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-03-2010 09:42 PM
Someone Other Than TACH is Asking Why Ethanol--Not Electric Cars and Hybrids--Is the AVANTI R5 Non-Subaru News & Rumors 3 06-04-2009 11:52 AM
My stupid back is being stupid. Strider Off-Topic 22 01-07-2008 09:18 AM
Is cop just being stupid? Testozz Bay Area Impreza Club Forum -- BAIC 20 02-03-2002 03:57 AM
This may be stupid, but is it possible to get a 18"... Keith Brakes, Steering & Suspension 8 05-16-2001 12:02 AM
