Old 03-11-2007, 11:54 PM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default What Color Wires To Tap For Lights And Horn?
Hello,
Trying to decode the FSM is driving me frikkin bonkers. I've searched my nuts off but none of the data is for my model year. I'm hoping I can appeal to you all and you'll tell me what color of wires to look for under the dash. The car is a 2005 Impreza RS.
Here's what I think I found out, but I have VERY little confidence that I'm right:
Horn: It looks like to get the horn right, I need to supply 12V to the + side of the relay, then connect the ground side of the relay to the Red-Green wire before it goes into the horn switch.
Parking lights: To switch a relay off the parking light switch in the control stalk, it looks like I need to connect the Black-Red wire exiting the switch to the + terminal of the relay and then ground the other side.
High Beams: To switch a relay off the high beams, it looks like I need to connect 12V to the + terminal of the relay, then connect the ground side of the relay to Red-Black wire before it enters the control stalk.
Man, this is one messed up wiring system. Why are the Horn and High Beams ground switched while the parking lights are positive-switched? Why doesn't the high-beam relay control the high beams? Argggghhh!
Old 03-12-2007, 09:03 PM   #2
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Come on, someone has to be able to tell me if this is right!
What wire to tap for MAF to Snow Controller Irishman Water/Methanol Injection, Nitrous & Intercooler Cooling 2 08-11-2007 10:22 AM
What wires to tap for boost gauge illuminatin hotshot172 Newbies & FAQs 9 08-06-2005 02:01 PM
HELP. I don 't know what wire to tap for my autometer boost gauge tcarter Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-21-2002 12:28 AM
O2 sensor location and wire to tap for AFR? camz911 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-11-2002 04:22 PM
