Old 03-12-2007, 01:35 AM   #1
nerdydorkus
Member#: 67062
Default Can HIDs dim over time?
I was wondering can HID bulbs lose their intensity or lumen output over time? Or is it the ballast that could cause the bulb to produce less lumens. I was under the impression that an HID bulb is on or off, and only those options. I didn't know they could wear and produce less light.
nerdydorkus is offline   Reply With Quote
Old 03-12-2007, 06:33 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes the bulbs can lose output and change color over time, especially the aftermarket ones. OEM grade HID bulbs are rated for about 2500 hours which is a long time, but aftermarket bulbs can be a crapshoot.
A failing ballast will usually result in the bulb not lighting up at all or flickering.
Old 03-12-2007, 10:54 AM   #3
infinite012
Member#: 74392
2015 Forester
the salts inside the bulb's chamber gets used everytime the bulb is ignited (turned on), so yes, they will "wear out" over time. you can see the most significant change in color after burn-in, or around 100 hours (philips 85122/6 bulb) of initial use of a brand new bulb.
infinite012 is offline   Reply With Quote
Old 03-12-2007, 11:46 AM   #4
Migo
Member#: 81352
2003 '03 EJ257 wagon
Green
Certainly a lot longer than halogens though, right?
Because driving with it on for 2 hours at a time would mean that after 50 days, the HID would need replacing?? That would mean I'd need to replace HID's every 6 months with the amount of night driving I do. Is 100 hours even established?
Migo is offline   Reply With Quote
Old 03-12-2007, 12:22 PM   #5
rougeben83
Member#: 115154
2005 Outback XT
White on grey
2500/2hr daily = 1250 days.
rougeben83 is offline   Reply With Quote
Old 03-12-2007, 03:57 PM   #6
Migo
Member#: 81352
Green
Oh sorry I meant 100 hours after burn-in... someone said something about significant color change after that time.
Hey rougeben83, how's that thing I sold/bought to/from you? I remember your name for some reason. PP6? STi springs? MRT headers? What did I purchase or sell?!? lol
Old 03-12-2007, 04:47 PM   #7
nerdydorkus
Member#: 67062
Does that mean the color/lumens change after 100 hours after usage? Mine i would guess only has a total of 20 hours usage at most.
Can clutch shudder cause drivetrain damage over time? Blue2002WRX Transmission (AT/MT) & Driveline 4 08-10-2010 07:14 PM
what movie scene can you watch over and over again and not become bored? cnw Off-Topic 98 10-25-2007 08:00 PM
Apexi EL2 gauges dim over time? Subaruist Electrical & Lighting 3 03-11-2006 04:38 AM
Period of time you can be pulled over for the same thing? (In MA) perkowskiforpope New England Impreza Club Forum -- NESIC 29 01-31-2006 10:22 AM
Engine gets louder over time? BrownKiler Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-09-2001 04:32 PM
