03-12-2007, 03:17 AM | #1 |
Member#: 84377
South East
Vehicle:2011 335d |
quick newb ? about witch one i need
Ok i am getting v8 heads put onto a 2.5 block, i curently have a wrx. Now i want to run avcs with my new motor, so can i order the wrx hydra or do i need the sti one and do i need to change my wiring harness? i dont really know how to ask that in the right wording i hope someone can make sense of what im getting at.
03-12-2007, 10:21 AM | #2 |
Member#: 92601
RMIC
Vehicle:01 Z06 |
I am pretty sure you will need to order the Hydra for an sti as well as get an sti wiring harness to run the avcs. Hopefully Phil or someone with more knowledge can give a for sure answer, but I think that is right.
03-12-2007, 06:07 PM | #3 | |
Member#: 94494
NWIC
Vehicle:2005 Element 92x Black |
All hydra's are designed to control AVCS, including the WRX one. This is about 25***37; of the reason why I bought a Hydra. You will not need anything from an STI to control the AVCS other than the heads and some wiring. The main difference with the STI hydra is related to the Drive-by-wire, which you don't have to worry about. You actually have a benefit over the STI hydra owners because you can still use your cruise control. WRX Hydra is the answer. Last edited by keaniegenie; 03-12-2007 at 06:15 PM. |
03-12-2007, 07:42 PM | #4 |
Member#: 92601
RMIC
Vehicle:01 Z06 |
Ah, I stand corrected. Thanks for clearing that up. Ya learn something new everyday, good to know.
03-15-2007, 10:06 AM | #5 |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
Yes that is correct you always purchase the Element Hydra for your chassis model and not the engine. We can configure the software to run just about any engine combination your heart desires.
Thanks, Phil www.elementtuning.com |
03-17-2007, 04:06 AM | #6 |
Member#: 84377
South East
Vehicle:2011 335d |
thanks guys. phil ill be ordering soon!
Need quick confirmation about parts need for setup | lh0628 | Brakes, Steering & Suspension | 0 | 07-28-2008 01:32 PM |
Another quick newb Q: O2 sensors, will one out of an '04 STi work in a bugeye WRX? | Gunmetal Grey | Newbies & FAQs | 6 | 11-28-2007 01:39 PM |
Cars or Sex......witch one | edaniele1212 | Off-Topic | 22 | 04-02-2005 10:00 PM |
oem boost gauge or hks evc witch one is corect | RedSun | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 06-07-2004 02:57 AM |
Help, need quick answer to quick question about ezpass | munkis | General Forum Archive | 2 | 09-29-2000 03:45 PM |
