Old 12-06-2001, 01:22 PM   #1
brainofjjj
Member#: 6334
11 M3
Monte Carlo Blue
Default Aux input and Creative Nomad
Guys...
I'm getting a Nomad jukebox soon and was wondering if the stock radio had an Aux in or RCA inputs on the back. I don't want to use the tape input option. Any thoughts? Has anyone purchase one of these yet?
another question...how crappy are these stock speakers? should that be my first replacement for the stereo?
Thanks
brainofjjj is offline   Reply With Quote
Old 12-06-2001, 02:24 PM   #2
Tomnel
Member#: 12625
MY02 WRX Impreza
No aux or rca's on back, if you search you'll find a picture.
You'll have to get a new HU for that.
As far as doing the speakers, I'm putting in an amp first, along with a neo car jukebox in the trunk. then later I plan to do the speakers, maybe some boston rally's.
Tomnel is offline   Reply With Quote
Old 12-06-2001, 04:17 PM   #3
mitch808
Member#: 10228
2002 Subaru WRX
If you can't afford a new head unit... There are always those RF adaptors. They convert a signal to FM and you just turn to that station. Although not the greatest of quality, it willsuffice for the time being. They're like 20 bucks.
mitch808 is offline   Reply With Quote
Old 12-06-2001, 10:34 PM   #4
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Well, the stock head unit does have another set of inputs, but you may have trouble using them.
See:
http://www.i-club.com/forums/showthr...postid=1214493
ANZAC_1915 is offline   Reply With Quote
Old 12-06-2001, 10:42 PM   #5
supersubee
Member#: 351
97 Legacy GT
actually Glen, that may not be that hard, the hard part would be finding a molex to fit into the socket, or having to hardwire the stuff in. There has a to be a turn on signal to tell the radio the changer is connected, similar to the T&C wire in the new GM's. Thats the wire that controls onstar through the radio. Hmmm, i should have a guy at work look at that. Anyway i could get a copy of that book from you Glen??? Let me know.
Kevin
www.subee-sound.com
supersubee is offline   Reply With Quote
Old 12-07-2001, 12:19 AM   #6
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Generally with add-on CD changers the head unit has to communicate over the bus to find out:
a) the changer is there
b) discs in which slots
etc.
So there is no single signal to just switch it on.
At least Pioneer and other units I've used have been that way.
Also, it isn't a Molex, and they don't list the part number of a plug to fit in it. Though if we could find a Panasonic changer, the plug from the harness for it might fit.
However, there is a mute pin. That might help someone out.
Glenn
Old 12-07-2001, 12:18 PM   #7
MountainWRX
Member#: 12826
2002 WRX Wagon
Thumbs up Thanks Glenn!
I've been wanting to hook up some type of MP3 player for a while and have been researching the alternatives... and this tread is great!! The pin call outs are definitely a starting point in decipering how to take advantage of it. I think the biggest thing now is to figure out how to "turn on" the changer function so that it will accept an input (bus signal?). I'm not an EE but if I have time, I'll experiment with it... if I find something I'll let you guys know!
MountainWRX is offline   Reply With Quote
Old 12-07-2001, 03:52 PM   #8
Jakezor
Member#: 9624
2002 ImprezaWRXsedan
Platinum Silver Metallic
If you want to add amps and such I have an <A HREF="http://www.audiocontrol.com" Target="_new">Audiocontrol</A> HPX that takes either rca in or speaker level in and does front/rear fadable out and sub out, master volume, sub volume, an 1/8" aux in and "expansion circuit" to make up for MP3 compression. I used it with a Dlink mp3 player and then my Nomad Jukebox in my old Regal (pre WRX).
It is for sale along with or seperate to a 10" Kicker Comp VR I have. ~1 cubic ft box, 4 ohm sub.
PM me or email me if interested.
Jakezor
Jakezor is offline   Reply With Quote
Old 12-07-2001, 07:37 PM   #9
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
You'll notice that the display says "CD-IN" to the left of the disc indicators. I believe (if an ext changer is detected), pressing the CD button again will set a "CD-EX" to the right hand side of the disc indicators.
I assume it only does this if it detects a changer. I'm sure someone smart could make a PIC emulate a changer to give you aux input functionality.
Glenn
Old 04-29-2002, 07:58 AM   #10
SPeeDSiN
Member#: 4667
Black (well kinda)
Just wanted to give this a bump and see if anyone has figured out how to fool the HU into taking those inputs.
I have gathered all the parts for my mp3 power supply and after exams, I'm going to try to put this thing in my car.
Found a working p90 in the trashcan!! which will soon be my mp3 player.
Thanks
Aaron Caudle
SPeeDSiN is offline   Reply With Quote
Old 09-09-2002, 06:09 AM   #11
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
bump
mattjk is offline   Reply With Quote
Old 09-09-2002, 06:06 PM   #12
Blackskull
Member#: 5616
2002 Impreza WRX
Perhaps this device will work. It's suppose to emulate a panasonic cd changer for the Vw headunits.
http://www.ajusd.org/~edward/vwcdpic/
Blackskull is offline   Reply With Quote
Old 09-09-2002, 07:38 PM   #13
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
Good idea, although my Isuzu engineer friend says the
Suby radios are the same as Isuzu's units... I may pick up
an Isuzu OEM CD Changer interface from Fry's and try it.
Matt
Old 09-10-2002, 02:21 PM   #14
Blackskull
Member#: 5616
2002 Impreza WRX
Default Panasonic changer protocol
Old 09-10-2002, 02:36 PM   #15
Blackskull
Member#: 5616
2002 Impreza WRX
After looking at the pinouts from Glenn and the protocol info I posted. This probably won't work.
Our radios only have 2 data lines. Whereas the VW radios have 3 datalines or the changer protocol listed is for 3 datalines.
Stock head unit information -- pin-outs, aux inputs, and more SVXdc Car Audio, Video & Security 60 12-06-2015 02:11 PM
Decks with AUX input and XM ready? White01 Car Audio, Video & Security 4 05-31-2003 06:54 AM
