Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 03-12-2007, 10:02 PM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default How Do I Test a Ground Switched Car?
So the wackos at Subaru decided to make a ground switched system. Now I have to tear into it and figure out which wires are doing what. On a positive switched system, I could just use a standard test light and poke around to I found a hot one. Not so easy with a ground switched system.
OK, so here's what I'm thinking. If I poke around under the dash, with the test light connected to ground, when I hit the load side of a switch, the light will turn on because the only path to ground for the circuit is through the test light. Then when I flip the switch to the on position, the light will go out because the path to ground through the switch is lower resistance than the path to ground through the test light.
Am I right?
Old 03-19-2007, 12:59 PM   #2
cMags
Member#: 88668
'05 Outback Sport
5MT - Regal Blue / Grey
Outback Sport
You could also connect the light to +12V, and it will light anytime you probe a ground... Lamps do not have polarity. This way you don't have to test only at a switch - you can probe as you normally would.
cMags is offline   Reply With Quote
Old 03-19-2007, 01:07 PM   #3
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
/me facepalms
Good god, why didn't I think of that!
Old 03-19-2007, 01:24 PM   #4
rkramer
Member#: 118209
2015 WRX Limitec
keep in mind playing around with an actual light bulb based tester can and will fry certain things. for a light bulb to light, you need to pass current THROUGH the circuit. IC's don't take kindly to that sort of thing. Use a multimeter instead. Then if you really wanted to you could still do ground-> ground testing through resistance.
Old 03-19-2007, 01:33 PM   #5
Mechie3
Member#: 120152
+1 on the multi meter. You can either drop some good cash on a nice one, or get a cheapie pocket one at radioshack. Plus, you get the bonus's of resistance testing (as rkramer said) and can see if wires are hooked to other things (such as dimmer switches) or what the actual voltage you are getting is.
Mechie3 is offline   Reply With Quote
how do you bypass the safety switch tekfoc Car Audio, Video & Security 18 10-11-2005 01:46 AM
How do I clean my dccd switch? booyakasha Electrical & Lighting 8 05-15-2005 09:35 PM
So i think i have a boost leak, how do i test this? jefersun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-20-2004 09:58 PM
How do I Test my TPS subachad Service & Maintenance 5 04-25-2004 12:56 PM
Do Impreza's have a “ground switched” headlight system? Arnie Interior & Exterior Modification 7 07-11-2001 02:20 PM
