Old 03-12-2007, 10:24 PM   #1
Ryan314
Member#: 82989
Hybrid EJ257
Default That's it, I can't stand this noise anymore!
There is this on going noise coming from my '02 WRX that I just CAN NOT deal with anymore... in other words, I can hear it over my stereo, and that's a problem!
I am going to try to explain this weird noise/sound as best as I can. It's a constant sound when I am driving around, and it seems to get louder when I accelerate and when I'm on the highway and the sound goes away as I come to a complete stop. It's extremely hard for me to come up with words to describe the sound... it's like a "whurring" sound, or "errrrr" (like if you were to say "whurr, whurr, whurr, whurr" or "errrr, errr, errr" consecutively. It also sort of sounds like a burping sound, or gurgling sound to some point... but more of the "whurr" and "errr" then anything.
That's the best I can do... I'm seriously going insane listening to it all the time. Please help!
Ryan314 is offline   Reply With Quote
Old 03-12-2007, 10:29 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
It is probably your rear diff on its way out. if the sound is only speed and acceleration based then it is most likely one of the differentials. If the sound changes with speed and cornering forces then it is probably a wheel bearing. Can't rule out CV joints either, front ones sound will change if you are turning and with speed. Rear with speed and bumps.
Old 03-12-2007, 10:29 PM   #3
austenf740
Member#: 21519
02 WRB WRX
98 RS
What about if you are driving and you put the car into neutral and coast for a bit. Will it still make the sound? What if oyu are at a stop and then you rev the engine does the sound start again. What I am getting at is the sound coming from the engine or from the drive train. I am guessing this would be some type of drive train problem instead of something wrong in the engine. ^^^ What master said. I would think it is one of those problems.
austenf740 is offline   Reply With Quote
Old 03-12-2007, 10:42 PM   #4
Ryan314
Member#: 82989
Hybrid EJ257
The sound stays when I put it in neutral and coast, it's just not as loud. Like I said, the sound seems to increase upon acceleration. I don't hear the noise at all if I'm at a stop and rev the engine.
Old 03-12-2007, 10:49 PM   #5
KJR
Member#: 16879
def sounds like drive train noise. axle or diff noise. can you poss get a sound clip?
KJR is offline   Reply With Quote
Old 03-13-2007, 12:22 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...it could be a wheel bearing, too
Old 03-13-2007, 09:25 AM   #7
Ryan314
Member#: 82989
Hybrid EJ257
I'll try to get one up.
What are my options now though? Should I bring it in to have it checked? *shurgs*
Old 03-13-2007, 09:30 AM   #8
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I'm betting on wheel bearing.
Old 03-13-2007, 07:19 PM   #9
Ryan314
Member#: 82989
Hybrid EJ257
Anyone else?
I'm thinking about just bringing it in and having them look at all those things... I don't see how I am going to pin point it exactly.
Old 03-13-2007, 07:29 PM   #10
Rasmusson14
Member#: 77658
2004 ej207, ppg dogs
3" green, ITS ALL 4 SALE!
I passed an Outback today with a wheel bearing out and dang it sounded bad. I made sure there was a lot of distance between me and him.
Rasmusson14 is offline   Reply With Quote
Old 03-13-2007, 11:13 PM   #11
wrx1986
Member#: 74769
07 WRX TR
UGM
easy to tell if its your wheel bearing...just jack it up and try to wiggle the wheels. If it has a little play in it...its your wheel bearing
wrx1986 is offline   Reply With Quote
Old 03-13-2007, 11:24 PM   #12
railguy
Member#: 53756
Does the sound change when you turn left or right? If the noise doesnt change, it could still be a wheel bearing but usually as the load is transfered it should either change, get louder, or go away. Depending on bad the bearing is.
railguy is offline   Reply With Quote
Old 03-13-2007, 11:29 PM   #13
Ryan314
Member#: 82989
Hybrid EJ257
I'm gonna say no... haven't really noticed any difference when turning.
Old 03-14-2007, 12:12 AM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
.....it is past that point already, most likely
Old 03-14-2007, 12:17 AM   #15
Ryan314
Member#: 82989
Hybrid EJ257
So my best bet is a wheel bearing?
Old 03-14-2007, 05:35 PM   #16
02warwagon
Member#: 133580
2002 WRX WAGON
[email protected]
Sounds exactly like my car which I know has a rear diff problem,mine howls anything above 80kms or 50mph and you can hear it over the stereo check your rear diff ring gears are probably scored?Good Luck
02warwagon is offline   Reply With Quote
Old 03-14-2007, 08:20 PM   #17
01G_WRX_02
Member#: 89746
2002 WRX Stage 4
PSM w/Gold RPF1's on 255s
Could also be the drive shaft bearing
01G_WRX_02 is offline   Reply With Quote
Old 07-16-2007, 12:25 AM   #18
dust12
Member#: 13417
Ryan - was it a bad wheel bearing?
dust12 is offline   Reply With Quote
Old 07-16-2007, 01:41 AM   #19
Drew's Rex
Member#: 151422
2005 Impreza T
I'm also gonna say Wheel Bearings.
Drew's Rex is offline   Reply With Quote
Old 07-16-2007, 05:37 AM   #20
Ryan314
Member#: 82989
Hybrid EJ257
Nope... Pinion bearing Which is not good, in terms of getting it fixed. The entire tranny has to come out in order to get to it. It's going in for repair this Thursday.
http://forums.nasioc.com/forums/show....php?t=1300714
Old 07-16-2007, 07:48 AM   #21
thosepeople
Member#: 133104
2002 silver WRX
oh yes 4:11 gears
If it is a wheel bearing it would probably be one of the rears. I had a front bearing go out and you can tell exactly what it was. You could feel it in the steering and it makes an awful sound. My guess would be in the rear diff.
thosepeople is offline   Reply With Quote
Old 07-16-2007, 10:11 AM   #22
Worxman02
Member#: 66563
2002 Impreza WRX
WR Blue Pearl
I possibly have a similiar sound, except mine sounds more like squeling brakes. It does change when I'm turning but it also happens in a straight line. Its only the fronts and goes away under braking. It also doesn't happen all the time. What do you guys think? I think its the brake pads not moving away from the rotor enough.
Worxman02 is offline   Reply With Quote
Old 07-16-2007, 10:36 AM   #23
sharkmonkey
Member#: 118566
2005 WRX
You either have a brake pad dragging or a bad wheel bearing.
sharkmonkey is offline   Reply With Quote
Old 07-16-2007, 02:28 PM   #24
Ryan314
Member#: 82989
Hybrid EJ257
Guys... it's a bad pinion bearing.
Old 07-16-2007, 02:48 PM   #25
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
sorry to hear that... what are they charging you? I have a similar issue only its not to the point of "over the stereo loud" yet.
FCmaniac is offline   Reply With Quote
Alright I can't stand it anymore...... GreenMarine South East Region Forum 29 06-28-2006 07:56 PM
Anybody else can't stand the noise from their aftermarket bars? B16A2NR Brakes, Steering & Suspension 25 03-28-2006 11:28 AM
I can't stand it anymore... Goosney Canada Region Forum 4 11-02-2005 12:10 AM
