Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC > NESIC Private Classifieds
Closed Thread
Old 03-13-2007, 11:17 AM   #1
Aphex28
Member Sales Rating: (40)
Member#: 11506
2015 WRX
Default FS: MA - RS Turbo Kit/v5 DCCD Cluster/VF39/TB/ECU/Autometer/HKS/CBE/ej251
Selling parts that I don't need from my swap
Located in Waltham, MA
Prices are for pickup/delivery and do not include shipping.
Shipping at buyer's expense.
PM me for my paypal address and I won't honor dibs for buyers that will want something shipped. First to pay gets it.
I will only hold an item for a few days till the agreed date of pickup and then relist.
I'm welcome to trades, just let me know.
More pics and items coming as I get ready to sell them.
Parts are for a 2000 RS / 2004 STi
Version V/VI STi Type R Cluster with DCCD
$200
Has about 60km on it. DIRECT PLUG AND PLAY into 2000/2001 2.5RS. I don't know about 99's but I know it doesn't fit 98's.
HKS Type 1 Turbo Timer
$90 obo
Has left over double sided tape on it and I can't quite figure out a good way to take it off. Comes with ignition harness for 04 STi, but it should fit everything. It worked on my 00 RS. You will have to wire in Engine Speed, Voltage & Vehicle Speed Sensor if you want all the features of it.
HKS Oil Catch Can
$60 obo
Not sure if I'm actually selling this or keeping it, but if I get the right offer I'll let it go. I also don't know if this is real or not, but it says HKS on it and it's functional. An Oil catch can is an oil catch can.
RS 2 Piston Brake Calipers
$55 obo
I had these on my car temporarily until I got 4pots. Calipers are painted silver, brackets are black. They were previously red and some brake fluid got on one of them so the silver is coming off. Can use a respray. Comes with a set of pads that I don't exactly know what they are. I know they're not stock, but were more than satisfactory for everyday use.
2000 2.5RS Cluster
$120 OBO
Has about 136k miles on it IIRC. Does not have plastic shield on it, but does come with a full tank of gas!!
Version IV WRX Intercooler
$50 obo
This thing is in sorry condition.
Came from SwapStarProducts/Supermoose...
Just about all the fins on the front are bent, and the bov fitting was sawed off for some reason. You will have to figure some way to attach a bov/bpv to this.
You will have to use the metal Y-pipe stuff from a wrx TMIC
Hence the cheap price.
2000 RS ECU
$100
JECS ECU not DENSO so Open ECU/Enguinity can't be used on it.
Should be P&P into a 2001 RS as well.
2.5 RS Badges
$10 each obo
Still have Impreza attached to them. 98-01 Style with chrome 2.5 and red RS lettering.
I have 2. Pics to come.
2002-03 WRX Foglights
$95 obo
Got a FMIC so I can no longer use these on my RS. Connectors are slightly different but they still work on a v5/6 bumper. Will work on GC's, direct P&P into 99-01 2.5RS
2000 RS Ported Throttle Body
$100 obo
2000/01 RS Coil Pack & Wires
$50 obo for coil pack
$10/set for wires
Should fit all 2.5RS models but 98 RS, but you're welcome to try it out before buying.
Aphex28 is offline
Old 03-13-2007, 11:18 AM   #2
Aphex28
Member#: 11506
2015 WRX
More Pics:
Cluster
ECU
Fogs
TB
Coil
I/C
Aphex28 is offline
Old 03-13-2007, 11:20 AM   #3
Aphex28
Member#: 11506
2015 WRX
More Items for sale:
IHI VF-39
$380
Pics to come.
No cracks, low to moderate mileage and no shaft play!
Good condition
Auto Meter Phantom Gauges:
Auto Meter Dual Gauge pod for 2.5RS
$15
Water Temperature
$45 obo
Comes with DSG coolant hose adapter. Pics of said adapter will be up soon.
Oil Pressure
$40 obo
Comes with Oil Pressure Sender Unit, but not sandwich adaptor pictured.
Can include both as a package for $70
Greddy Oil Sandwich Adaptor
$40 obo
Voltage
$10
Boost
$35 obo
Comes with T connector and 2 sets of vaccum line included with the kit.
EGT/Pyrometer
$95 obo
It wasn't working correctly in my car when I took it out, but I'm not sure if it was just a ground, the gauge or the egt probe. I am including a brand new EGT Probe, old probe and 2 sets of probe wires. Brand new probe is $100 from jegs, $60 from other vendors
RS TD04 Custom Turbo Kit
$1300 OBO
Videos of this setup are here:
http://www.youtube.com/profile?user=aphex28
Turbo your car for under $2k and leave stock wrx's in the dust!
All you will need to get is engine management and a Intercooler Y-Pipe and it's everything you need. I used an Emanage Ultimate and I can provide ANY support and/or questions you need pertaining to the kit.
more pics here:
http://smg.photobucket.com/albums/v4...ex28/turbokit/
Consists of:
Clocked and rotated WRX TD04
Polished WRX intercooler
XS Power BOV
Modded 850cc WRX Injectors
04 WRX Fuel Pump
Custom Intake
Wrapped and Coated Up Pipe
Wrapped and Coated Down Pipe
HKS 40mm External Wastegate, Open Dump
Custom Mid-pipe.
Modified Oil Pan for oil return line.
Will bolt up to any 2.5RS Cat-back Exhaust with this setup. Stock or aftermarket.
2000 EJ251 out of my RS
$500 obo
One of the idler pulleys exploded on itself and almost caused the timing belt to eat itself. The belt skipped a few teeth, but the engine is non-interference and should be completely working. Keep in mind this engine was boosted. I took it apart down past the intake manifold and timing belt covers and put it back together once I found the pulley destroyed.
Obviously it needs a new timing belt and associated things. Includes stock pulley and not the lightened one pictured
EJ257 Shortblock
$800 OBO
Has a spun rod bearing on #3.
I have split the block and crank is separate. Pistons & Rings are in great condition. Rods seemed good too.
Borla XR-1 Catback Exhaust w/ Magnaflow resonator
$150 obo
Has a magnaflow resonator welded into it b/c it was too loud for mine and my brother's tastes. It's been on both of our cars and there is something rattling in the muffler hence the low price. It works well and sounds awesome especially with a Borla Header. Rattling can be heard when the car is warming up and I can't quite figure it out. If you do you have a really nice cheap exhaust! Piping is something like 2.125" or something. Less than 2.25" but more than 2"
Can be seen in the picture Above ^
Aphex28 is offline
Old 03-13-2007, 12:31 PM   #4
Aphex28
Member#: 11506
2015 WRX
More space reserved for things for sale
Exedy Stage 1 Clutch & Pressure Plate for 2.5RS transmission
$50 OBO
Has about 50% life left and is a good upgrade over stock. Organic disc with a slightly stiffer pressure plate.
2000 RS transmission
Best offer
It may be sold, but I still have not recieved payment.
This trans has treated me well but will not hold up to STi power levels. It's in good condition despite having 140k miles on it.
2 - 8" Bazooka Tube Subwofers
$20 obo
These are OOOLLLLDDD School but still work . They are un-amplified and I think they like 60-80 watts RMS.
Pics to come.
Front Oxygen Sensor
$55 Each
4 wire oxygen sensor for 2000/01 2.5RS.
I have a set of 2.
To see the list of pics, go here:
http://smg.photobucket.com/albums/v4...28/For%20Sale/
Aphex28 is offline
Old 03-13-2007, 01:47 PM   #5
Chapel
Member Sales Rating: (2)
Member#: 3496
1995 Roadmaster
Beige
wow... are you doing 'the big swap' now?
I notice the V8 STI Swap listed.
Chapel is offline
Old 03-13-2007, 01:55 PM   #6
Aphex28
Member#: 11506
2015 WRX
yep
Aphex28 is offline
Old 03-13-2007, 02:00 PM   #7
Chapel
Member#: 3496
1995 Roadmaster
Beige
fattyboombatty...
Chapel is offline
Old 03-13-2007, 07:39 PM   #8
gc8wrx02
Member Sales Rating: (3)
Member#: 28429
2003 wrx
sonic yellow
im interested in the vf39
gc8wrx02 is offline
Old 03-13-2007, 07:45 PM   #9
gc8wrx02
Member#: 28429
2003 wrx
sonic yellow
how much for the girlscout cookies lol
gc8wrx02 is offline
Old 03-13-2007, 09:05 PM   #10
bren wrx
Member Sales Rating: (8)
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
bren wrx is offline
Old 03-13-2007, 09:45 PM   #11
Aphex28
Member#: 11506
2015 WRX
hehe Those cookies have been devoured!
Aphex28 is offline
Old 03-14-2007, 03:03 AM   #12
darkmist2k1
Member Sales Rating: (9)
Member#: 31364
Ver6 Trek and couple
bottle of gatorade 4boost
yo! can i grab those front caliper bracket from u!!! plz plz!!
sunny
darkmist2k1 is offline
Old 03-14-2007, 08:50 AM   #13
Aphex28
Member#: 11506
2015 WRX
you sure? They're just RS brakes
Aphex28 is offline
Old 03-14-2007, 09:20 PM   #14
25rsESP
Member Sales Rating: (4)
Member#: 56985
2006 WRX Wagon
bump for a kick ass turbo kit!
25rsESP is offline
Old 03-17-2007, 06:26 PM   #15
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
aphex,
i pm'd you about the vf39 saying buyer with cash in hand let me know when you want to meet up. I asked multiple times for a number to contact you at and you gave me the run around. We agreed on a price for the vf39 and i simply said tell me when you can meet up - im free - then i asked if you could include the fogs in another bundled price - you gave me a price i agreed and asked again when can we pick it up and a number to reach you at. I thought we were honored there since it was not being shipped but you replied you got a better deal on the foglights, which i can slightly understand since you would never confirm with me a date of pickup which goes against your rules below. and unless i was at ECS this weekend there was no way of me getting the turbo. I can understand your preoccupied with your swap but still is it hard to reply with a number - im not that far away. Why do I feel like im getting stroked here?? Are you really ready to sell these parts?
bren wrx is offline
Old 03-17-2007, 08:19 PM   #16
hornyturbo
Member Sales Rating: (14)
Member#: 108618
2010 10 RX350, 04 A4
12 IS350, 08 STI
PM sent about Greddy Oil Sandwich Adaptor
hornyturbo is offline
Old 03-18-2007, 02:34 AM   #17
Aphex28
Member#: 11506
2015 WRX
Ok Bren, why do you want so bad to talk on the phone? What can be done on the phone that can't be done through PMs.. I'm not one to /give my phone number out over forums sorry.
I say I'm available for pickup, but unless my memory is failing me, which is completely possible because I get 20+ pm's per day, you never gave me a concrete 'I want this product' just like most potential "buyers" do. Then you ask for a "package deal and I give you a price , and you then go about trying to undercut it even more after that.
I would rather sell to somebody who is paying what I want for them.
You then seem obsessed about getting my number and I already have a sour taste in my mouth from getting nickeled and dimed. So as it goes, I'm not in the mood to talk on the phone. So once again, what is the point of talking on the phone when it can all be done here.
As I said in my for sale post, FIRST TO PAY GETS THE ITEM. No DIBS, now if you want to keep crying go ahead, but it won't get anything done.
Yes I'm really ready to sell these parts, but for some reason now I don't really feel like selling it to you since you're being such a sour ninny. Instead of crying over you not getting my phone number you could have just asked me through here when to meet up, or even asking to me on AIM.
Instead you try to make me look like an ass over an internet forum by posting only 3 days, I repeat 3 DAYS after first pm-ing me. Boy you are quick to bi*** and complain.
It just makes you seem like a whiney moaner.
One of those customers to a shop who goes to the BBB to complain about them just because they didn't give you or your car special attention and it wasn't completed within a week.
I would have sold to you if you were actually a little bit patient, but proved to be too hard to deal with.
Sorry honryturbo sandwich adapter is sold. I stopped paying attention to this NASIOC listing because all I get on this site are people asking questions then disappearing.
Aphex28 is offline
Old 03-18-2007, 04:15 AM   #18
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
Im not whining - you simply were beating around the bush - I had to send several PMs, its not hard to say - im not comfortable with giving my number, but i am available xx time, are you? Simple as that - when you avoided the question multiple times - i figure your not telling me something. First PM i said i wanted the turbo. How can i pay for YOUR items when you wouldnt respond with a time or place or a number when i asked.
I asked you many a time when you would be available to meet up saying we were ready to meet up. That is pretty concrete to me. Its reverse stroking, thats why i asked if you were indeed ready to sell it or it was still on a car and you were riding it out. It's fine if you dont want to sell the item to me - I dont have time to track down someone with poor communication through PMs.
And you'd rather sell to someone who is giving you your ASKING price? I wish sales worked that way. Is this your first time selling something on the internet? None of those prices said firm. I never pay asking. I inquiried two items and asked for a bundled deal and YOU gave me one, and what you gave me for a price left a sour taste in your mouth? Get over yourself dude. Maybe you should specify in your auction that your panties are in a bunch when people try to communicate past your PM vagueness (asking for your #) or that highest bidder gets priority. Stick to yard sales man im done.
bren wrx is offline
Old 03-18-2007, 09:12 AM   #19
Aphex28
Member#: 11506
2015 WRX
3 days. haha this guy is a toolbag.
Way to get your panties in a bunch
Later
Aphex28 is offline
Old 03-18-2007, 09:06 PM   #20
Newera09
Member Sales Rating: (12)
Member#: 125294
Hey I tried to Aim you but you were "away" swapping. shoot me a pm when you might be available or try and hit me up on aim in regards to the vf39
Newera09 is offline
Old 03-18-2007, 11:59 PM   #21
Aphex28
Member#: 11506
2015 WRX
sent reply, looks like the good vf-39 is gone
Aphex28 is offline
Old 04-06-2007, 08:53 AM   #22
RuskiiWRX02
Member#: 99924
2001 GC8
BRP w/ sweet JDMness
if any of this stuff is still available i might be interested in the clutch for 50 buxs... pm me and let me know thanks...- Alex
RuskiiWRX02 is offline
Old 04-06-2007, 09:15 AM   #23
Aphex28
Member#: 11506
2015 WRX
you know the clutch is for a push style RS trans right?
PM sent
Aphex28 is offline
Old 04-09-2007, 09:45 PM   #24
evoq007
Member Sales Rating: (5)
Member#: 90875
2013 4dr STi
check your pm's!
evoq007 is offline
Old 04-10-2007, 06:31 PM   #25
Aphex28
Member#: 11506
2015 WRX
okies!
Aphex28 is offline
Closed Thread
FS: MA - RS Turbo Kit - Everything you need but EM! Aphex28 1993 - 2001 Impreza Specific Parts 5 11-06-2007 01:01 AM
FS: MA - RS Custom TD04 Turbo kit everything you need but EM Aphex28 Engine/Power/Exhaust 11 09-15-2007 01:03 PM
FS: MA - RS ECU/Front 02 Sensor/Coil packs/RS EJ251 Partout Aphex28 Engine/Power/Exhaust 1 04-04-2007 03:36 PM
FS: Full RS turbo kit, engine management and all 8Complex Mid West Subaru Owners Club Forum -- MWSOC 1 11-07-2003 04:41 PM
FS: Vishnu RS turbo kit with oil pan, local sale prefered byl-23 Bay Area Impreza Club Forum -- BAIC 4 12-22-2002 06:16 PM
