Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Services
Old 03-14-2007, 12:27 AM   #1
GrimmSpeed
Vendor Sales Rating: (212)
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Default GrimmSpeed PnP and Coating Services
So we've been a vendor for about 40 days now and have been so dang busy with nasioc work alone we didnt want to start a classifieds thread because we didnt want to over work ourselves and extend turn around time. Anyways, the time has come to start posting about are services.
Info below. More info can be found at www.grimmspeed.com
Thanks again to nasioc for your continued support!
Exhaust Manifold
Welcome to our hottest product! Our Subaru boxer engines kill our spool up time, most noteably because of the very long exhaust manifold. To directly combat this loss of spool up we will port and polish all 9 inlets/outlets of your 3 piece exhaust manifold. We enlarge each port to match up with the stock subaru gaskets, porting ~6-7mm of material at the entrance/outlet of each port.
Exhaust Manifold
Turbo
Porting and polshing your turbo is the single most important service we offer for decreasing your spool up times and shifting your entire powerband to the left. We port and polish both hotside inlet/outlet AND coldside inlet/outlet for maximum flow. Currently we have stopped our ceramic coatings for the turbo...if you can't live without the coating please contact us and we can work something out.
**PLEASE CONTACT FOR TURBO PRICING**
TGV Delete
Dont feel like spending 500 for a new set up butterfly-less tgvs? For less than 1/2 the price you can get the same exact benefits from our TGV Deletes. In this process we take a stock TGV and completely gut it, which includes taking out the metal plate, butterflies, and bar. These will allow for maximum flow through the TGV. Stop the engine's heat from entering the TGV's with our ceramic coating. It is very important that heat stays out of the TGV's because this is the last transfer before the intake air enters the engine. Cooler intake air equals more hp.
TGV Delete $179.99 (+ 100 core charge)
TGV Delete w/ Ceramic Coating $204.99(+ 100 core charge)
Downpipe
Match up that turbo to downpipe connection with our PnP service. We will gasket match your downpipe inlet to the turbo>downpipe gasket. If you have a divorced wastegate downpipe we will knife edge(show in picture) the split for smoother air flow. Keep the super-heated exhaust in your downpipe and away from your tranny by adding our ceramic coating. We also advise heat wrapping your downpipe as a second defense against the heat.
Downpipe PnP AND Coating Package (no core exchange, customer must send downpipe in for service)
Ceramic Coating Service (no core exchange, customer must send downpipe in for service)
Intake Manifold
We bore out the ends of each of the 4 runners to better match up with the inlet of the TGV. From the factory there is a large step going into the TGV, we get rid of that step for a smoother transition. Feel like adding the bling factor with function?...add our option ceramic coating as shown in picture.
PnP Intake Manifold - WRX
[color=#000000][font=Arial][color=#000000][font=Arial][color=#000000][font=Arial][color=#000000][font=Arial][color=#000000]
GrimmSpeed is offline   Reply With Quote
Old 03-19-2007, 04:38 AM   #2
modaddict
Member Sales Rating: (20)
Member#: 95840
sold to a good bud
awaiting next car
Do you have any pics of the "boring out" of the intake manifold? So, you have a manifold and TGV's that are done, and you will send me those, and I send you mine back, correct?
BTW, I need a crossover...anyway I can get one shipped to me by april 15th?
pm me back please.
modaddict is offline   Reply With Quote
Old 03-21-2007, 02:26 PM   #3
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
pm me back please.
i'll look around for some pics. yeah we have a both mani and tgv's in stock for the wrx. sti's are limited right now. yep, we'll send you those and then you send your old stockers in so you have NO DOWN TIME
Old 03-21-2007, 10:55 PM   #4
stealth84ct
Member Sales Rating: (34)
Member#: 84442
2005 STI
CGM
Do you only port the whole manifold or just the inlets and outlets?
stealth84ct is offline   Reply With Quote
Old 03-22-2007, 08:14 AM   #5
chackoc
Member Sales Rating: (4)
Member#: 51442
2004 WRX Wagon
JBP
Can I ask why you no longer coat exhaust manifolds (as indicated in the first pic)? Is it a cost or performance concern?
chackoc is offline   Reply With Quote
Old 03-22-2007, 12:29 PM   #6
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
we are in the middle of changing our process to port basically the entire piece. previously we have ported the first 2-3 inches because most the gains you get are from taking away the steps, not smoothing out the entire inside of the pipes. but in the near future we'd like to step it up a notch and get the whole thing ported/polished for you guys for that added .000001 hp .
imo, polishing the whole inside wont gain much more..but it does have a nice bling effect
neither. the coating we use can be self cured on the car, however when installing you have to be real careful not to scratch up the coating or else you are going to have problems. we are still doing it but for a reduced cost. in the next couple of weeks we will be moving into a shop so we will have the ability to cure the stuff before we send it out....then we should be game on again.
Old 03-28-2007, 10:04 PM   #7
Feign
Member Sales Rating: (39)
Member#: 68604
06 STi
When are you going to have crossovers available again?
Feign is offline   Reply With Quote
Old 03-28-2007, 10:52 PM   #8
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
no eta right now. definitely working hard to find a new manufacturer because the one we spent the last month working with didnt end up working out.
Old 04-06-2007, 03:14 AM   #9
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
mmm...tonights goodness.
Old 04-06-2007, 12:32 PM   #10
BigJ04STi
Member Sales Rating: (13)
Member#: 77239
2004 Impreza WRX
None
Pm'd you...
BigJ04STi is offline   Reply With Quote
Old 04-25-2007, 10:41 PM   #11
MrSlowbaru
Member Sales Rating: (6)
Member#: 129231
2005 wrx
cgm
can the ceramic coating be done in red?
MrSlowbaru is offline   Reply With Quote
Old 05-02-2007, 03:02 AM   #12
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
just black as of right now
Old 05-02-2007, 01:22 PM   #13
Shabib67
Member Sales Rating: (1)
Member#: 61749
What kind of coating do you guys use HPC or Swaintech?
Shabib67 is offline   Reply With Quote
Old 05-02-2007, 01:23 PM   #14
Shabib67
Member#: 61749
Did you guys get more crossover pipes and did you move to your new location?
Old 05-02-2007, 04:42 PM   #15
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
we use techlines coatings.
actually are version 2 crossover is going to be out very soon. yep we moved into our shop april 1st.
Old 05-08-2007, 09:17 PM   #16
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
very soon as in a few weeks now
Old 05-10-2007, 11:42 AM   #17
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
yummy pics...and yes, those are coated on the inside too
Old 05-10-2007, 12:14 PM   #18
Mars_D
Member Sales Rating: (21)
Member#: 90480
2005 9-2x
Dude....Sweet!
Mars_D is offline   Reply With Quote
Old 05-10-2007, 12:16 PM   #19
jtsherri
Member Sales Rating: (26)
Member#: 55847
2008 BMW 135i
Jet Black
<-- Jealous of the inside coating...
jtsherri is offline   Reply With Quote
Old 05-10-2007, 12:51 PM   #20
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
now you REALLY cant say we dont come out with new stuff every other day lol. we work hard for subi funness
Old 05-10-2007, 02:05 PM   #21
modaddict
Member#: 95840
sold to a good bud
awaiting next car
do you have sti manifolds and tgv's in stock yet....for an exchange?
Old 05-10-2007, 02:14 PM   #22
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
if you are looking for intake manifold, not yet, and tgv's hopefully soon. if you are talking exhaust manifold, they are the same.
Josh
Old 05-10-2007, 04:31 PM   #23
BigJ04STi
Member#: 77239
2004 Impreza WRX
None
Josh... You should have an extra set very soon... (STi IM and TGV)
Old 05-10-2007, 06:33 PM   #24
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
great.
And just got word we have a set of sti tgv's in stock.
Josh
Old 05-15-2007, 12:55 AM   #25
Mars_D
Member#: 90480
2005 9-2x
Now I need the TGVs and intake mani to match the spacers!
FS : 68hta w/ grimmspeed pnp and ceramic coating rexblake Engine/Power/Exhaust 32 03-19-2011 05:39 PM
Grimmspeed Pnp and crosspipe mapleleaf Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 12-20-2009 03:08 PM
FS: PA - '05 STi OEM Uppipe PnP and coated $60 Mycues1982 Engine/Power/Exhaust 2 12-18-2008 10:35 PM
BRAND NEW Grimmspeed PNP & Coated Headers Ej22Tim Engine/Power/Exhaust 6 08-02-2008 06:37 PM
NJ: looking for local shop that offers PNP cermaic coating service intpostman23 Tri-State Area Forum 5 04-10-2008 09:09 PM
