Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 06-23-2009, 04:42 AM   #676
vecdran
Member#: 162932
Hrm, don't know why I didn't post this here when I finished my console conversion.
vecdran is offline   Reply With Quote
Old 06-23-2009, 10:47 AM   #677
blueteamno
Member#: 32089
2011 WRX
2012 Outback
Originally Posted by XanRules View Post
also. Absolutely for the love of god sand before you apply this stuff.
you really don't need to sand before applying plasti-dip to interior parts... in fact, if you don't sand you can remove it later and have your stock interior back if you get sick of the black.
here's how mine turned out with no sanding, and only a few light coats...
it lasted well over a year with no wear/peeling/scratches. i actually redid one of the vent rings because a bug landed in it while it was drying just by rubbing the plast-dip off until it was good as new and respraying.
blueteamno is offline   Reply With Quote
Old 06-23-2009, 04:44 PM   #678
sheepdog
Member#: 93773
1995 Flat Khaki GC8
2011 STi Wagon
Yes, but if you sand your durability factor goes up significantly. Its all about what you prefer, a potentially reversible mod or a durable permanent one.
sheepdog is offline   Reply With Quote
Old 06-23-2009, 04:47 PM   #679
bcfsc
Member#: 183142
2007 sti wrx
obp
woah that looks sweet
bcfsc is offline   Reply With Quote
Old 07-07-2009, 02:55 AM   #680
SubieNate
Member#: 185685
1999 Impreza L Wagon
Silverthorne Metallic
I'm going to do this to my wagon. Now, I want the best possible durability without destroying the look of the plastic (AKA not sanding so much it damages the texture or shows through the paint) what grit of sandpaper should I use?
I was also thinking of buying some TSP for prep instead of just using alcohol or acetone. Thoughts?
Nathan
SubieNate is offline   Reply With Quote
Old 07-07-2009, 09:39 AM   #681
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
Spenk is offline   Reply With Quote
Old 07-07-2009, 04:50 PM   #682
Mul
Member#: 156171
2002 WRX wagon
here's mine:
added body filler in the spaces around the part under the vent next to the cup holder so it looks like one whole piece.
Mul is offline   Reply With Quote
Old 07-07-2009, 05:10 PM   #683
myoung321
Member#: 163120
2007 STI
grant it plasti-dip is easy to apply and looks great, the down side is that it's a dust magnet and hard to clean. You can see the how lint and dust is grabbed by it in many of the previous pictures.
myoung321 is offline   Reply With Quote
Old 07-07-2009, 05:30 PM   #684
WRX USA
Member#: 11192
.. VF48'd Bugeye
Here is mine:
Several other mods visible:
Replaced fabric on door cards (and added fabric to map pocket)
Covered bottom half of center console with the same fabric
iPhone dock in OEM clock location
Red Hazard button is on order.
WRX USA is offline   Reply With Quote
Old 07-07-2009, 06:05 PM   #685
Lboogie
Member#: 171611
2014 FiST
Blk
Keep a tack cloth handy to just dab on the plasti dipped surfaces to get the lint/dust off. Or vacuum the panels off with a bristle headed hose attachment when you're cleaning inside the car. Its also great for getting dust/crumbs out of the shifter & e-brake boots.
Lboogie is offline   Reply With Quote
Old 08-01-2009, 10:36 PM   #686
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Does sanding make it more durable and let it stick easier?
I bought some primer too I am going to use just for better bonding.
Also does it seem rough afterwards or am I spraying wrong?
I'm going to pick up some 1500 grit sandpaper to smooth things out.
Smoke is offline   Reply With Quote
Old 08-01-2009, 10:40 PM   #687
Un0RiGiNaL
Member#: 189748
Hey guys I have some duplicolor gunmetal wheel paint, how do you think it will look if i spray that?
I currently have my **** plasti dipped but i hate it cause its hard to clean and gets dust and lint all over it.
And i dont care about being able to go back to gray cause when i bought the car the trim was fu**ed up anyways, it had some wierd ass stains that wouldnt come off.
and Da Risin Smoke -- plasti dip aint too friendly with sandpaper-- let alone rubbing the damn thing with ur fingers
Un0RiGiNaL is offline   Reply With Quote
Old 08-04-2009, 12:09 PM   #688
sheepdog
Member#: 93773
1995 Flat Khaki GC8
2011 STi Wagon
Sand, use an adhesion promoter/plastic primer, then spray the plasti-dip. Don't sand the plasti-dip after you spray it obviously, sand the plastic before. The "wetter" a coat you put on, the smoother texture you'll get. If you actually read the thread, there are several points where people say that, and that sanding increases durability, but it is no longer a reversable modification.
Mine is super easy to clean, some armorall and a microfiber cloth and it comes perfectly clean, no lint/dust or anything.
Old 08-04-2009, 05:47 PM   #689
yamahaSHO
Member#: 73932
2005 STi - E85
2004 S2000 - E85
Originally Posted by WRX USA View Post
Here is mine:
Got any pictures of the iPhone dock?
yamahaSHO is offline   Reply With Quote
Old 08-04-2009, 11:40 PM   #690
sti robot
Member#: 110932
2013 BRZ
I'm almost done with my plastidip and my 04-05 interior conversion, but a hair dried on part. I guess I'll have to peel it off that piece and start again. bleh.
sti robot is offline   Reply With Quote
Old 08-05-2009, 08:21 AM   #691
englishguy3012
Member#: 147943
2004 Sti 2.5 XTR'd
372whp, Stock block 1yr+
what about something like that new krylon paint that chemically bonds to plastic? do you think that might have better results?
englishguy3012 is offline   Reply With Quote
Old 08-05-2009, 09:32 AM   #692
CC4nj
Member#: 136945
2005 WRX/CRX/LGT
Obs. Black
I used that Krylon Fusion in Satin Black on my CRX
I did it about 4 years ago and since its held up great, no chipping pealing,
and even better- it looks as OEM as it can get.
Granted I dont take it out much...but I def recommend that stuff for plastic
CC4nj is offline   Reply With Quote
Old 08-05-2009, 11:25 AM   #693
sheepdog
Member#: 93773
1995 Flat Khaki GC8
2011 STi Wagon
I've chipped every type of plastic paint on the market on mine. Plasti-dip over a sanded part has held up better than anything for me.
Old 08-05-2009, 12:16 PM   #694
englishguy3012
Member#: 147943
2004 Sti 2.5 XTR'd
cheers for the input lads.. one for one against.. neone else?
Old 08-05-2009, 12:44 PM   #695
BoostinIX
Member#: 136701
2013 WRBBRZ/S14 240
04WRX/05STi- Goooone
I've scratched my plastidip setup, but when it gets bad, just peel it off and redo No sanding means my parts are just fine underneath. Plastidip FTW.
BoostinIX is offline   Reply With Quote
Old 08-12-2009, 11:36 PM   #696
Un0RiGiNaL
Member#: 189748
Bump my quesiton, what do you guys think if i spray my gunmetal duplicolor wheel paint? i can obviously plasti-dip over it, but im gonna try it, i think itll turn out sick
Old 08-12-2009, 11:57 PM   #697
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Edit: Nevermind; should've just took a minute to search!
Anyone know how to remove the e-brake cover and such on my car?
I don't have the CD holder thing with the lid.
Old 08-13-2009, 12:05 AM   #698
04redwrecks
Member#: 218300
2004 WRX
San Remo Red
hope it turns out good
04redwrecks is offline   Reply With Quote
Old 08-13-2009, 11:02 AM   #699
NormaWhite
Member#: 210995
2002 wrx wagon
aspen,pearl
Here is mine:
what turbo timer is that?
NormaWhite is offline   Reply With Quote
Old 08-13-2009, 11:03 AM   #700
Sleepr56
Member#: 67326
2015 WRX Limited
World Rally Blue Pearl
Pics of my dash done.....
http://forums.nasioc.com/forums/show....php?t=1822121
Also have a second set of pieces for sale already coated if someone wants to take them off my hands
Sleepr56 is offline   Reply With Quote
WTB Plasti wheel well covers EJ22t Kid Private 'Wanted' Classifieds 3 01-21-2009 06:46 PM
Decided to Suede & Plasti badfish1134 North West Impreza Club Forum -- NWIC 22 10-30-2008 07:11 PM
Plasti-Kote 5604 - Silverthorne match.... -Kevlar- Interior & Exterior Modification 3 05-09-2008 01:46 PM
repainting optical drives, where can I buy Plasti-kote online? captaind Off-Topic 2 10-21-2006 05:36 PM
Is the WRX OEM front spoiler plasti or fiberglass? thejean Interior & Exterior Modification 5 02-04-2003 02:47 PM
