Old 03-14-2007, 09:20 PM   #1
avant-gardewrx
Member#: 115433
2004 Wrx
WR Blue
Unhappy turbo timer help
I just installed my greddy full auto turbo timer and I am pretty sure that the wires are connected right. I had a harness for the dash and the ebrake and ecu are wired right, but when i turn on the car and then turn it off the turbo timer turns off and says "off" right away. Can someone help me out and tell me if there is a certain setting or wire i need to cut in order to get this thing to work.
avant-gardewrx is offline   Reply With Quote
Old 03-14-2007, 09:50 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I wonder if we have an electrical forum? Let me see....yep.....I think I'll move this as a courtesy to the other 140,000 forum members.
Old 03-17-2007, 01:18 AM   #3
NVOUS WRX
Member#: 123368
2002 WRX Sedan
i had the same problem w mine. pull the e brake turn the car off and the car shut off.... here it was a bad ground with the ebrake.. ground it directly to something to see if u have it hooked up right. if u turn ur car off and it stays runnin u have it hooked up right u just need a better connection with your e brake wire.
NVOUS WRX is offline   Reply With Quote
Old 03-18-2007, 08:24 PM   #4
Force
Member#: 123515
2005 vette c6 z51
LeMans Blue
you have to ground the e-brake safety wire.
If you don't choose to use the E-brake as a safety switch for the timer, you can ground the wire to any good ground in the car.
Force is offline   Reply With Quote
Razo RE40 Turbo Timer Help Needed! ginjaninja Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-12-2002 07:37 PM
hks turbo timer help Fast turbo 21 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-14-2002 01:11 PM
Blitz turbo timer help Si2WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-16-2002 09:03 PM
Erratic turbo timer, Help! linus011 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-25-2002 10:45 PM
Slight problem with my Turbo timer - help! djerickd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-26-2001 12:06 PM
