Welcome to the North American Subaru Impreza Owners Club Thursday October 27, 2016
Old 03-14-2007, 10:43 PM   #1
Member#: 136314
2014 Grand Cherokee
Default My ETX20L Battery Install: Lost 15 lbs...
I hope this thread doesn't get closed...come on guys, it's only a battery.
Anyway, here's a picture of my AGM "Big Crank" Deka ETX20L $72.98 battery with shipping (one size up from the 11.6 lb ETX14L) from BatteryMart.com:
17.5 Ah @ 10hr rate
270 CCA
The silver covering is some leftover self-adhesive foil backed foam duct insulation I wrapped around the battery to help deflect some of the underhood heat (batteries HATE heat). Using the stock plastic battery tray, a 0.99 cent brace from a hardware store, and a 8" universal battery hold down kit ($5.00) from Advance Auto, I was able to mount this 15.5 pound battery in the stock location...shaving about 15 lbs off the front of the car (stock battery weighed 30.5 lbs). I had to monkey with the wires a little bit so it would fit, but no cutting was required. The SAE connectors were leftover from my old PC680 I used to run in my mach 1.
WRXLTD is offline   Reply With Quote
odyssey PC680 battery - 15 lbs. - SATX zmw TXIC Private Classifieds 0 12-15-2009 01:54 PM
My ETX14 battery install. AKA: my car just lost 20lbs! djerickd Electrical & Lighting 36 03-14-2007 07:04 PM
i just lost 6 lbs. kedrin Off-Topic 5 11-22-2005 08:11 PM
Battery install: Is it ok to remove these doohickeys? John Callahan Alaskan Impreza Club Forum -- AKIC 5 11-14-2005 01:47 PM
Lost 4 lbs in 2 months saturn2wrx Off-Topic 36 01-03-2005 07:58 PM
