Old 03-15-2007, 05:11 PM   #1
Wrx1234
Member#: 142341
2004 2.5L GT30rd WRX
SRR
Default Ej205 to jdm Ej207 swap question.
Hey im sure i'll get flamed but i searched for about 20-25 minutes and couldnt find this specific instance. now i have to go to work so i'm out of time to look for it.
I have a chance to purchase a JDM Ej207 shortblock (including pumps an pan) to put into my 04 WRX. It has 30k (its on mwsoc) and from what i understand and have been vaguely told is that it would be as simple as dropping in the new block. Theres no wiring or modifications necessary right? Also can someone shed some information on the Ej207 (aka the advantages over my stock block besides stating 'more power holding') such as will i see a power gain?
Sorry if its a dumb question but i'm new to scoobies.
Wrx1234 is offline   Reply With Quote
Old 03-15-2007, 05:22 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
You won't see a power gain unless you have the supporting mods to take advantage of this block. It is stronger because it is semiclosed deck, so it will take more boost without cylinder flex. But if you don't have a turbo that can give that to you and a way to tune it, there's no point...
Old 03-15-2007, 10:09 PM   #3
Wrx1234
Member#: 142341
SRR
i have a stock turbo now with all supporting mods for a bigger turbo but dont trust my stock wrx block. For the money would you suggest to just take apart my motor and rebuild it for that? I dont intend going huge but would like an 18g or vf39
Old 03-15-2007, 10:15 PM   #4
jamesfacts
Member#: 51282
98 RS
black & blue from parking
It also has factory forged internals and is balanced. You can safely run a 207 bottom end to 8500 rpms or so.
jamesfacts is offline   Reply With Quote
Old 03-15-2007, 10:21 PM   #5
Wrx1234
Member#: 142341
SRR
could my stock heads take an increased rpm range?
Old 03-15-2007, 10:37 PM   #6
overlord
Member#: 52186
2005 LGT LTD
Regal Blue
The EJ207 has higher compression so you would see power gains and faster spool. What those would be exactly I dont know. You would have to get a tune, head work etc. If you are getting this you may as well get a full longblock or full motor swap. Any motor work on a WRX worth doing is worth doing right. IE: get parts that were specifically made for each other.
overlord is offline   Reply With Quote
Old 03-15-2007, 10:50 PM   #7
Wrx1234
Member#: 142341
SRR
would it be worth it to just go for a s2 crawford short block instead?
Old 03-16-2007, 09:01 AM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
no
i would wager that most people here are perplexed at the desire to upgrade a 205 block w/ a vf39/18G .. its simply not necessary. that setup is only good for 240-300 whp max.. a tune by a reputable tuner is far more valuable
Old 03-16-2007, 09:17 AM   #9
Member#: 88758
2000 Civic
2010 Xterra
Originally Posted by Jaxx View Post
no
+2....unless you have a shaddy tune there is no reason your ej205 wont support either of those turbos. Start talking gt-30's and other larger turbos then I'd be conerned. Just make sure you get a good tune and tell the tuner you dont care about peak power but want the car to run for xxxx amount of miles.
302@12psi is online now   Reply With Quote
Old 03-16-2007, 01:34 PM   #10
Wrx1234
Member#: 142341
SRR
im mainly worried about the block crapping out on me. How much would it be after all if i spun a bearing on my stock block
Old 03-16-2007, 02:37 PM   #11
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
understood
but its more about the tune than the block the 205 is FINE to those power levels
save your $
Old 03-16-2007, 02:49 PM   #12
Matt Monson
Member#: 832
99 2.5RS, '85 911
If you spun a bearing it would be because your tune was off and you detonated or you contaminated your oil with a fueling issue. Or it would be because you overrevved it. I am with Jaxx on this. Spend your money in other directions.
Americanyouth,
ALL Ej20's have a forged crank and forged rods. Not ALL Ej207's have forged pistons. Some do, and some have hyperuetic cast pistons. I don't assume it's forged unless they confirm the one they are looking at is in fact forged pistons...
Old 03-16-2007, 03:49 PM   #13
2fast4me
Member#: 99605
05 s4, ver.7
wrb
Yes all ej20s have forged rods, but only the 207 has rods light enough to handle the rpm.. as for the forged piston, only the ver.7 has them. To the 207 swap, your going to utilize the block if youve got the right heads to rev it out, but if its cheap enough, why not..
2fast4me is offline   Reply With Quote
Old 03-16-2007, 06:54 PM   #14
Matt Monson
Member#: 832
99 2.5RS, '85 911
You wouldn't be the one trying to sell this block would you?
Plenty of people have revved stock Ej205 and Ej22T rods well up into the 8000rpm range. It's not out of the ordinary. But again, unless he's got headwork and cams that let him go up there, he's not going to be entering that territory. He's sure as hell not going to do it with a vf39...
Old 03-17-2007, 09:47 PM   #15
2fast4me
Member#: 99605
05 s4, ver.7
wrb
Nah, im not selling the guy the block, I have a 207, thus giving my input. W/o proper head work anyone reving 8k range is crazy, it doesnt last long, complete 207 w/ heads revs to 8.5 w/o any problems.
Old 03-18-2007, 12:12 PM   #16
jamesfacts
Member#: 51282
98 RS
Americanyouth,
With the GD guys, I assume we are talking about a v7 block, not a GC 207 motor. Although you're right, it could be a v8+ which would not have forged pistons either.
Old 03-18-2007, 07:48 PM   #17
circaisdashiat
Member#: 96315
1995 STi V5 replica
World rally blue
not trying to steal your post, but would a entire Ej207 (full block) bolt into a 02, 03 WRX without wiring?
circaisdashiat is offline   Reply With Quote
Old 03-18-2007, 09:08 PM   #18
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
no..jdm stuff isnt obd-II compatible as far as i know
mxpunk is offline   Reply With Quote
Old 03-18-2007, 10:27 PM   #19
overlord
Member#: 52186
2005 LGT LTD
Regal Blue
The EJ207 swap is plug and play in the GDA's. You are correct that they are not OBD II but you can plug in the USDM ECU if you want to trade AVCS for OBD II compliance. You can also get your USDM ecu tuned to run the EJ207. If you use the JDM ecu it can be tuned ( I can't remember if it is Utec or not).
I would not just swap the short blocks or even the long blocks. If you are serious about a stronger block then the crawford, axis, cobb, etc short blocks can be had for a good price. In any case you will need to get head work done and a tune to take advantage of the new parts.
OR as the experts are telling you, Get a good tune on the EJ205. Even though it is not subaru's best block ever, it is still good.
Old 03-19-2007, 12:37 AM   #20
circaisdashiat
Member#: 96315
1995 STi V5 replica
World rally blue
hey thanks, everyone is saying the EJ205 is complete crap and i am about to finish 5 months or hard work to find out the engine i have is complete crap. I know its not the best but i also want to feel i should be able to upgrade it without having to buy a new block.
JDM STI swap question dougie fresh Newbies & FAQs 0 07-08-2008 04:04 PM
02 usdm ej205 to early ej207 swap questions dukeduster Subaru Conversions 4 11-20-2007 02:04 PM
jdm ej25 swap question Blk_RS01 Subaru Conversions 0 08-29-2006 10:35 PM
tips for USDM EJ205 to JDM EJ205 swap? Chuck H Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-16-2005 08:37 PM
Jdm ej207 swap into wrx is finished. Its crazy. WRXerRacer Subaru Conversions 10 01-03-2005 07:17 PM
