Old 03-15-2007, 09:55 PM   #1
ScoobySnacker
Member#: 105303
2003 WRX
Default Low beam bulb replacement suggestions (02 wrx)? *yes i read the FAQ*
I have been looking to upgrade my headlight bulbs for a while now. I read the FAQ and came out more confused than before. I hear that the orsam silverstars are a good upgrade as well as the nighthawks but i really dont know. Im looking for a relatively cheap bulb that has good light output and a nice color(anything but the dull OEM look). What would everyone suggest? I am leaning towards a bulb that can be ebay'd for a good price. Thanks everyone.
ScoobySnacker is offline   Reply With Quote
Old 03-15-2007, 10:25 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Just look a few threads down for some suggestions-
http://forums.nasioc.com/forums/show....php?t=1222270
Your options with 9007s are unfortunately limited, and Osram Silverstars are not made in that type.
Avoid the crappy Ebay bulbs.
Old 03-15-2007, 10:31 PM   #3
ScoobySnacker
Member#: 105303
2003 WRX
Wow, i really didnt notice how much we are limited in the case of an 02 wrx. So GE Nighthawks are the way to go? I just want a replacement bulb not one that come with seperate components. Thanks.
Old 03-17-2007, 10:38 AM   #4
DAVE98RS
Member#: 525
<<98 2.5RS(RIP)>>
02, Cobb stg 2.5, FMIC
IMHO, the Philips VisionPlus are better than the Nighthawks...especially if you get a relay harness. Although a harness is not necessary it does make a difference.
DAVE98RS is offline   Reply With Quote
Old 03-17-2007, 05:03 PM   #5
02redwagone
Member#: 87067
02 Old but tasty
SRP
Have you used both? Ive only used the GEs and have been quite impressed over stock. I still need to do the harness.
02redwagone is online now   Reply With Quote
Old 03-17-2007, 11:40 PM   #6
taerron
Member#: 75744
2k2 low boostin
evo3, for now....
i've used both with a relay harness. the philips are better than the ge nighthawks
taerron is offline   Reply With Quote
Old 03-18-2007, 12:09 AM   #7
02redwagone
Member#: 87067
02 Old but tasty
SRP
Good to know.
Old 03-18-2007, 09:39 AM   #8
DAVE98RS
Member#: 525
<<98 2.5RS(RIP)>>
I've used both and settled on the VisionPlus'.....that was before the Lightwerkz conversion
Old 03-18-2007, 04:05 PM   #9
limpstick
Member#: 104418
2002 braless WRX
In a blue skirt
Hey DAVE98RS, did you notice much of a colour difference between the GE's and the VisionPlus bulbs?
I switched recently from blue coated bulbs to GE Nighthawks and the improvement was amazing on a stock harness (relayed harness still on backorder). I'm not sure what made the most difference - getting rid of the crappy blue coated bulbs or the quality of the Nighthawks. Either way I'm happy and they were cheep cheep.
limpstick is offline   Reply With Quote
02 wagon clutch/flywheel question, yes I read the FAQ flyinghighlm Transmission (AT/MT) & Driveline 1 06-23-2009 03:42 PM
2004 wrx Low Beam Bulb Replacement Q Three105 Electrical & Lighting 3 06-10-2006 10:55 PM
clutch advice (yes, ive read the FAQ and searched) happasaiyan Transmission (AT/MT) & Driveline 6 01-24-2006 04:39 PM
Which clutch? (yes, I read the FAQ) shikataganai Transmission (AT/MT) & Driveline 12 09-11-2005 01:21 AM
Spongy pedal qn (yes I read the faq) realwomble Brakes, Steering & Suspension 5 06-26-2004 03:26 PM
Message Board Statistics All times are GMT -4. The time now is 07:35 PM.
