Old 03-16-2007, 02:09 AM   #1
dkane
Member#: 142720
Default Vacuum/Boost Gauge Install
I've searched a lot for this. Maybe, I'm using the wrong key words. Anyway, I own a 2002 WRX. I just bought and want to install an Autometer boost/vacuum gauge. The instructions say if it were just a boost gauge I could install it using a T-fitting, but since I have boost/vacuum I need to hook an 1/8" adapter into the ENGINE PRESSURE PORT. I have been unable to find out what this is let alone where it is on my engine. I showed my car to a talented mechanic and he couldn't find it, only said that it should be somewhere on the intake. Could someone please link me to a pic or diagram or install instructions showing where the engine pressure port is or some other really easy way to install this thing. I would greatly appreciate it. Thanks. Oh yeah, is it possible that I might have to remove my intercooler to access the preesure port? Just a thought. I could really use some help.
dkane is offline   Reply With Quote
Old 03-16-2007, 02:38 AM   #2
02redwagone
Member#: 87067
02 Old but tasty
SRP
Tap here only. (IE:the white tee and clear tube)
02redwagone is offline   Reply With Quote
Old 03-16-2007, 12:55 PM   #3
dkane
Member#: 142720
Thank you for taking the time to post a picture and help me out, but the Autometer instructions say to tap where you showed in the pic for only a boost gauge and that for a vacuum/boost gauge you need to tap somewhere into the engine pressure port on the intake system using a 1/8" adapter that they provide with the kit. So, I'm not sure if that location works. Arghhh!
Old 03-16-2007, 01:18 PM   #4
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Probably the alternative location is given for people fitting it as a vacuum gauge on a naturally aspirated engine. You for sure will be able to read vacuum from the location posted by 02redwagone.
UkNuck is offline   Reply With Quote
Old 03-17-2007, 11:28 PM   #5
uathatis
Member#: 117300
if the 1/8 doesn't work. i found a 3/16th one you can get at autozone works better, the firewall plug you run this through is behind the intercooler
uathatis is offline   Reply With Quote
Old 05-10-2008, 06:44 PM   #6
Weasel Soup
Member#: 159271
2013 VW Golf R
'95 Escort Rally-X beater
that pic is exactly what people installing boost gauges need to see
thanks
Weasel Soup is offline   Reply With Quote
Old 05-30-2008, 05:41 AM   #7
cwr5035
Member#: 176324
02 WRX
thanks for the pic... I know to tap there but I had no clue how far down the line would be good...Yours is the first pic I've seen when searching for this.
cwr5035 is offline   Reply With Quote
Old 05-30-2008, 12:04 PM   #8
Micky
Member#: 89757
2004 Impreza STI
Black & dirty
Why there only?
Micky is offline   Reply With Quote
Vacuum line selection for boost gauge install... Suggestions? AjntOrnj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-11-2009 12:01 AM
Autometer vacuum/boost gauge Chi_San Newbies & FAQs 9 05-13-2009 02:29 PM
turbo timer boost gauge install w/ factory boost gauge Blakestyle521 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-21-2004 11:19 AM
Vacuum/boost gauge Charlton Legacy Forum 5 10-21-2003 09:39 AM
Boost Gauge Install / Need Additional Pieces... Ethan North West Impreza Club Forum -- NWIC 6 05-30-2001 01:35 AM
