Old 03-16-2007, 11:17 AM   #1
WRXINTX
Member#: 96712
Default how-to mod STI side feed injectors for Higher flow??
I searched for this and I found nothing on modding the side feeders...
I have an '04 Forester XT automatic and it uses the Yellow top 565cc STI injectors and I am doing a TD06-20G 8cm turbo....
I want to start around 270-300whp and work up to 350-380whp after that...
but, I will probably wait to go above 300whp until I have a built tranny with converter and IPT valvebody....
I have seen pics of these injectors that were modded after removing the screens on the bottom, but, does this require complete disassembly of the injector or can it be modded while still in one piece...???
Thanks for the help
RYNO
WRXINTX is offline   Reply With Quote
Old 03-16-2007, 12:01 PM   #2
TheMadScientist
Member#: 23717
2005 Big red
Do you have a milling machine?
If not then send them out to be modded. The side feeds are not like th etop feed that can be modded with a razor.
TMS
TheMadScientist is offline   Reply With Quote
Old 03-16-2007, 12:45 PM   #3
WRXINTX
Member#: 96712
Yes, I have access to a bridgeport mill, a lathe, and a great old friend who is a retired master machinist from the Navy...
He is an awesome guy!!!!
Do you have any pics or directions as to how deep to mill them off and do they have to be dissasembled???
Thanks!
Old 03-16-2007, 01:39 PM   #4
TheMadScientist
Member#: 23717
2005 Big red
From looking at them all they do is macnine out the screen in the tip. Make sure to have them flowed and cleaned after/if yu do it.
I have never done it. I have never seen them done. I have never seen a write up to do it.
I do know that on the top feeds that screen is REALY thin. I have done 12 sets of top feeds or so.
TMS
Old 03-31-2007, 01:19 AM   #5
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I modded the yellow 550 sti side feeds on my setup. I used a mini disc cutter (harbour freight) and first cut off the aluminum diffuser on the end. then I slowly ground the end down until the screen was cut out. I didnt flow test them, but damn they flowed ALOT more!
Old 03-31-2007, 09:12 AM   #6
Freon
Member#: 88322
2009 BMW 135i
Freon is offline   Reply With Quote
Old 03-31-2007, 09:23 AM   #7
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
I think you could do it with a dremel with some of the smaller metal cutting bits. Need to be very careful though.
Old 03-31-2007, 10:00 AM   #8
STIBungy
Member#: 51684
I tried with a dremel and failed miserably. I destroyed 3 injectors. w00t!
STIBungy is offline   Reply With Quote
Old 03-31-2007, 03:19 PM   #9
RicerSube69
Member#: 120961
99 RS-T
RBP
yeah it seems like it would be hard to do with a dremel.
RicerSube69 is offline   Reply With Quote
Old 03-31-2007, 03:45 PM   #10
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Old 03-31-2007, 09:59 PM   #11
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Hey...
1 - they work great.
2- I am not tuning for milage, simply balls out fuel.
Old 04-01-2007, 01:07 PM   #12
distorto
Top Scoob 024
Member#: 56364
RIP stompr :(
bagged vulvva
Hey...
i guess you know that your duty cycle went down, but how do you know if they are flowing evenly.
distorto is offline   Reply With Quote
Old 04-01-2007, 01:11 PM   #13
limestoner
Member#: 35490
97 Impreza 2.2l
slow.
he doesn't, and they're not.
limestoner is offline   Reply With Quote
Old 04-02-2007, 12:26 AM   #14
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
But I did a 12.9 at 109.56 spinning 1st and 2nd!
If you aren't tuning for milage, whats a few cc's between injectors if you are tuning for a "rich" tune?
Old 04-02-2007, 01:45 AM   #15
benw
Member#: 103320
1998 swapped
Forester L
Deatschwerks is in my home town, and I got to see the results of their professionally "hacked" side feeds... they didn't flow anywhere close to equal.
Have them professionally modded so they flow well, as well as retaining a good atomization pattern.
benw is offline   Reply With Quote
Old 04-02-2007, 05:18 AM   #16
TheMadScientist
Member#: 23717
2005 Big red
I have been running the "hacked" side feeds for ~1 week now.
They were sent out for cleaning and flow testing. They came back with 804, 804, 800, 800, with a "good" spray pattern.
My milage might have come down ~1 maybe 2 MPG. The ECU still targets 14:1 durring cruise, if the AFR dosen't change the MPG is not going to change much if at all. All at cruise, once on boost well that whole MPG thing doesn't matter any way.
TMS
Old 04-02-2007, 11:57 AM   #17
benw
Member#: 103320
1998 swapped
Forester L
to everyone: cleaning and flow testing does not make injectors flow similarly! I have seen the bench results of hacked injectors and it's scary how bad they are. Real easy to burn a hole in a piston when your differences are 10% or more across the board.
Old 04-02-2007, 02:17 PM   #18
neonglh
Member#: 127886
If anyone needs injectors flowtested/cleaned, send me a PM. I have access to a flowtester, and the prices are probably better then anyone else can do. Its a fun toy to play with too
--mark
neonglh is offline   Reply With Quote
Old 04-03-2007, 03:12 AM   #19
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
"flow testing" doesn't account for voltage changes as well as the various operating conditions of an injector. I have personally seen differences of over 10% from injector to injector. On an aggressively tuned car this can mean a blown engine.
That said, if you must run a stock modified injector, always remember to place the highest flowing ones in #3 and #4 - these are the leanest / hottest cylinders.
Gary
Gruppe-S
Gruppe-S is offline   Reply With Quote
Old 04-03-2007, 08:49 PM   #20
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
playing editor for the good of all cylinders......
Old 04-03-2007, 08:50 PM   #21
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Wouldn't you mean HIGHEST flowing?
Ooops yeah highest flowing, thansk for noticing that. Fixed!
Gary
Gruppe-S
Old 04-06-2007, 11:00 PM   #22
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Used my modded injectors today to do 311 hp and 354 torque at 22 psi with a 7-1 compression motor. Had 11-1 afrs on average.
Old 04-06-2007, 11:31 PM   #23
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Thats not the point of cleaning and flow testing now is it? Cleaning allows it to flow as much as possible, and flow tests to see how much they flow. I dont see flow matching anywhere in there
Old 04-07-2007, 06:00 PM   #24
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
The AFRs, unless measured at each individual cylinder will not indicate a problem if some are running a bit richer on some a bit leaner on others. If you are measuring at the header collector and you have a sensitive WB02 (I am using the PLX one) you might detect a broader deviation in AFR which could be an indication of a problem as I have done in the past, but it is still difficult to detect.
No doubt modded injectors work, my recommendation to everyone going modded is to just make sure you get individual flow numbers, avoid installing injectors with high deviations in flow, and put the highest flowing ones on cyl 3/4.
Oh BTW if you need OEM cores, we have tons in stock right now.
Gary
Gruppe-S
Where to chop Injectors for higher flow outlwstr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 04-28-2016 02:35 PM
FS: 05 Sti intake manifold wiring , tgvs, modded STi side feed injectors 740cc iheartmysuby Engine/Power/Exhaust 15 06-17-2011 07:21 AM
WTT: PA: PE850cc Side feed injectors for stock side feed injectors + $100 wkderf Tri-State Area Private Classifieds 7 09-19-2010 09:17 PM
2006 sti side feed injectors for sale [email protected] Engine/Power/Exhaust 2 11-22-2008 01:09 AM
F/S Perrin high flow fuel rails for STI side feed injectors 99 cents eBay Ricowrx Private 'For Sale' Classifieds 1 10-19-2004 10:32 PM
