Old 03-16-2007, 11:49 AM   #1
verdee
Member#: 113772
2006 WRX Wagon vf39
Default 2006 WRX Target Boost and Altitude
I have a stage 2 2006 Wrx with a Cobb catted downpipe and an SPT Catback exhaust. I have been running this setup for about 2 months. The question I have, is what should I expect for boost. I live in Denver, so I am expecting to be lower than Cobb's targets. Right now I do not see higher that 14psi. I have checked this both with my boost guage and the AP reading. I have tightened the wastegate arm (At first I was only hitting about 11psi). I just want to see if this is normal, or if there is something else I should do. The car runs great and pulls hard, but I just want ot make sure its OK.
Evan
verdee is offline   Reply With Quote
Old 03-16-2007, 11:57 AM   #2
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Depending on barometric pressure, you will only see a fraction of what the targets are. I am at the same elevation as you, and with our barometric pressure, the ECU automatically targets ~12% reduction in boost, so about .88*15.6=13.8. You can target a higher boost to make it hit 15.6, but tightening your wastegate arm isn't the answer. The ECU WANTS to hit a reduced boost target and will do whatever it can to do it, including lowering your wastegate duty cycles depending on the turbo dynamics tables. All that being said, your car is doing what is supposed to do.
06rexwagon is offline   Reply With Quote
Old 03-16-2007, 01:30 PM   #3
Airboy
Member#: 72829
2006 WRX
2015 WRX
The atmospheric pressure compensation for the '06 WRX is ~-13% at 12.2psi (5000ft). However, this value is applied to the boost target in absolute pressure. So, Boost target of 15psi gauge is actually stored in the ECU as 29.7psi (actual unit is mmHg but anyways). At 5000ft elevation, the target becomes 25.9psi MAP. Subtracting atmospheric pressure of 12.2psi and you get 13.7psi gauge pressure.
Airboy is offline   Reply With Quote
Old 03-16-2007, 05:33 PM   #4
verdee
Member#: 113772
2006 WRX Wagon vf39
Thanks a lot, makes a lot more sense now.
Under target boost and lean afr jtmarsh AccessPort 2 02-23-2010 07:43 PM
2006 WRX Stock Boost pAnC8K3 Newbies & FAQs 7 12-11-2006 07:35 AM
2006 WRX AccessPort boost question??? Bala AccessPort 9 05-12-2006 12:54 PM
2006 wrx tr boost D Town WRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 03-30-2006 11:32 PM
2006 WRX stock boost/VAC levels jkoc Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 02-12-2006 06:27 PM
