Old 03-16-2007, 05:25 PM   #1
rotorhead
Member#: 35187
2003 impreza wrx
Default cruise probs from DRL?
i just want to make sure this isn't an issue, so anyone with more familiarity with the wiring underhood would be very helpful. once upon a time i disabled my DRL's by unplugging the drop resistor on the right strut tower. throughout the whole time i've owned my car, my cruise has held the throttle open at very random intervals. seeing as the DRL plug is remarkably close to the cruise unit, i wanted to make sure that having the DRL unplugged at that location would not cause cruise issues. i have since reconnected that plug and disconnected the DRL's behind the glove box instead, since i'm looking into doing the headlight/relay mod. i just want to know if i should bother hooking my cruise linkage back up just yet.
copied my post from the cruise recall thread:
***********my throttle sticks open as well, and it's very random. it'll stick for about 5 seconds, then release. i had the cruise recall done looooong ago, and that's not the problem. when it happens, the idle will also hover between 2k and 3k rpm. last time it happened (high idle), i looked under the hood and saw the cruise cable under HIGH tension and partially pulled open. i rotated the throttle closed, and it pulled itself back open to a high idle condition. i've never seen under the hood what happens when the throttle sticks open, but i'm willing to bet it has something to do with the self adjusting cruise control. btw, during all these instances, the cruise was NOT in the 'on' position. the bad part is, if subaru can't see the problem happen in front of them, they won't fix it. they believe there is a problem, but don't know what to fix 'till they see something broken. which really bites, because i'm waiting for the damn thing to try and kill me AGAIN. i've had so many close calls, it's pathetic. i absolutely love my car, but if it's this dangerous, it is a piece of worthless junk. i've contacted SOA to see what they can do, as the local dealers just don't seem to care that i may lose my life in this car. as a little test, after my last subaru visit, i disconnected the cruise cable. if i don't have another near miss in the next 6 months, i'll know EXACTLY that was the problem.***********
rotorhead is offline   Reply With Quote
Old 03-19-2007, 08:59 PM   #2
rotorhead
Member#: 35187
2003 impreza wrx
*bump
Old 03-20-2007, 12:27 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The DRL disconnect, whether the dropping resistor or main module, will have no effect on the cruise. If it's physically sticking there is something wrong with the cruise cable or module.
Old 03-20-2007, 10:52 AM   #4
rotorhead
Member#: 35187
2003 impreza wrx
that was my original thought, but i had to make sure. last thing i want is to unexpectedly rocket off into someone else's car. thanks mulder!
greg
06 STI Differential & Cruise control prob from LED tail light bulbs REDDOG Drivetrain 0 05-02-2008 07:20 PM
04 wrx cruise control and DRL karlknaupp Exterior/Styling 2 05-15-2007 05:50 PM
04 wrx cruise control and DRL karlknaupp Tri-State Area Private Classifieds 2 05-15-2007 05:50 PM
04 wrx cruise control and DRL karlknaupp Engine/Power/Exhaust 0 04-02-2007 06:57 PM
Cruise control from 93 SS into 95L vica153 Electrical & Lighting 9 09-07-2006 12:50 PM
