Old 05-15-2009, 09:22 AM   #401
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
No, not saying that. Just don't want to ruin the surprises as if I already didn't do that.
D Money is offline   Reply With Quote
Old 05-15-2009, 08:26 PM   #402
xxscaxx
Member#: 86459
2013 BRZ
cant wait to see your **** d
xxscaxx is offline   Reply With Quote
Old 05-16-2009, 10:21 AM   #403
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
what do you want to see? gross.
WRX8XB is offline   Reply With Quote
Old 05-17-2009, 03:14 PM   #404
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
You wanna see my bird?
Old 05-17-2009, 07:24 PM   #405
xxscaxx
Member#: 86459
2013 BRZ
ha-ha. s!!t, is that better? his car being finished you fudgepackers
Old 05-18-2009, 04:25 PM   #406
hyperspeedy
Member#: 167189
wow that is clean
hyperspeedy is offline   Reply With Quote
Old 10-04-2009, 08:18 AM   #407
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
Well heres my feabile attempt thus far..
All engine loom has been pushed through the cabin then through the passenger front fender. Braille battery is also located there as well as the fuse box. The loom going to the ABS and lights has also been moved so there not visible.
For the holes Ive glued in an aluminium pieces to fill the holes then filled over them. The smaller holes ive just filled over. Theres a bit of filler there but it will all get sanded down so theres not much there. I didnt touch the strut towers as people say that this may be prone to cracking. I think the other areas should be fine??
ABS im wanting to relocate also to the fender, but im not sure about it yet.
I will be sanding it sometime this week then painting it..
tino is offline   Reply With Quote
Old 10-04-2009, 10:11 AM   #408
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
^^ that much filler seems like it will crack the first bump you hit or the first time you drop a wrench on it
bigolrig is offline   Reply With Quote
Old 10-04-2009, 02:50 PM   #409
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
I agree. Tino I dont think that method is going to work bro. It seems you filled in all those ridges on the sides of the wheel wells with just bondo, instead of welding in plates.
Old 10-04-2009, 03:03 PM   #410
Pierrot
Member#: 180417
some come out ok but others get out of hand
function>fashion
Pierrot is offline   Reply With Quote
Old 10-04-2009, 03:15 PM   #411
450 slug
Member#: 221778
Default smooth
ya i did bodywork for a couple years and you atleast need to weld up all the seams and weld holes shut to have a chance of that not cracking apart, also you can use 3m panel adhesive as body filler which is more flexible and wont crack as easily as body filler
450 slug is offline   Reply With Quote
Old 10-04-2009, 03:19 PM   #412
tino
Top Scoob 019
Member#: 43630
I have put it on fairly thick but will sand alot of it down so there shouldn't be that much there. I just wanted a fair bit of material to start with.
Or do you still think it will crack??? Especially near the bottom of the chasis rail? If so I'll sand it completely back then.
Old 10-04-2009, 03:30 PM   #413
leoimpreza
Member#: 197989
2002 Impreza WRX STI
WR Blue
leoimpreza is offline   Reply With Quote
Old 10-04-2009, 04:42 PM   #414
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Idea if no has mentioned yet:
Wrap the engine bay with carbon wrap?
Sorry if someone mentioned it ()
Smoke is offline   Reply With Quote
Old 10-04-2009, 04:51 PM   #415
KillerRabbit
Member#: 184772
2004 WRX
World Rally Blue
Go back a page or two....
KillerRabbit is offline   Reply With Quote
Old 10-05-2009, 09:41 AM   #416
tino
Top Scoob 019
Member#: 43630
All of done to fill the holes is to glue in an aluminum peice behind or infront of the panel. Then i have bogged over them. Im starting to get worried now that a few people have said that this process may lead them to crack. I might just sand it completely smooth and not worry about filling those holes to prevent this occuring..
Old 10-05-2009, 03:09 PM   #417
450 slug
Member#: 221778
Default smmoooth
there is no (may crack) it will for sure, sand it down now before you waste ur time and money on paint
Old 10-05-2009, 06:28 PM   #418
tino
Top Scoob 019
Member#: 43630
Yeah I'm going to sand it all pretty much back to mtal. I will keep some small places with filler though but no where to the extreme it is right now.
Would there be much movement in the side panels though? As I would like to keep those holes flushed over still
Old 10-05-2009, 08:40 PM   #419
AWDshenanigans
Member#: 197856
2010 FJ Cruiser
Sandstorm
Originally Posted by 9vapors View Post
From Leoimpreza...
wth is that giant bulge in the first pic??
AWDshenanigans is offline   Reply With Quote
Old 10-05-2009, 08:52 PM   #420
rockle3
Member#: 167573
09 spec B
i think its a water to air intercooler
rockle3 is offline   Reply With Quote
Old 10-05-2009, 10:55 PM   #421
timmy03t
Member#: 220873
just amazing wish i had the time and money
timmy03t is offline   Reply With Quote
Old 10-06-2009, 05:30 AM   #422
k00ky
Member#: 108067
2003 STi
T, can your alum fab guy weld? I would be getting the seams welded an wel in some plates at the holes you have filled I did my first cars engine bay with fibreglass over the inside of the holes and filler on the engine bay side and it cracked very quickly. If you are spending time to do it while the donk is out do it right mate ;-)
k00ky is offline   Reply With Quote
Old 10-06-2009, 06:23 AM   #423
tino
Top Scoob 019
Member#: 43630
Im just going to sand it all right back to metal.. I dont care if i can see the seams so i will most probaly remove the filler from those areas.
but i will still leave the ally panels as ive already done the drivers side a few months ago and its fine thus far..
Old 10-06-2009, 01:51 PM   #424
9vapors
Member#: 92582
I spent countless hours welding all of the holes and welding in plates. I know mine isn't going anywhere and will not crack. I tried to fill everything... It's scary though, as you are going along, you think youre done, then all of the sudden there are holes you missed...
9vapors is offline   Reply With Quote
Old 10-06-2009, 02:07 PM   #425
bugeyesubie
Member#: 179783
Silver STi swap 380wph!!
**** i hope mine doesnt crack, i guess if it does ill re do it... properly as it is to late now.
bugeyesubie is offline   Reply With Quote
washed engine bay, now car won't start CEL on pinoy_boy204 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 42 06-08-2010 09:12 AM
spilled oil in engine bay bugeye4life Newbies & FAQs 8 06-03-2010 03:51 PM
07 ABS actuator and all Engine bay lines TraviST185 Suspension/Brakes/Handling 1 04-08-2009 08:38 AM
06 STi attempted wire tuck, polished manifold, samco hoeses, baller custom intake reallyslow Member's Car Gallery 34 06-19-2007 01:11 PM
Wiring TT and keeping engine kill feature sssp Electrical & Lighting 2 08-15-2004 11:58 PM
