Old 08-05-2012, 11:06 PM   #1501
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Originally Posted by EvileyeZ88
Subaru bays are hard to tuck, and expensive.
Not everyone has deep pockets
No they're not. We all paved the way to make it easy for everyone. I answer every single pm I get about them to this day.
Expensive? I know a shell for sale with a bay thats already done. Cheap too
D Money is offline   Reply With Quote
Old 08-05-2012, 11:43 PM   #1502
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
I may need to send a pm your way eventually. After I relocate the battery and fuse box, there are some things that I haven't seen in this thread or others regarding how to pull it off
Smurftastic is offline   Reply With Quote
Old 08-06-2012, 01:26 AM   #1503
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
No problem
Old 08-06-2012, 02:06 AM   #1504
onesicksoob
Member#: 215841
Dont PM me about
wheel specs
Originally Posted by Smurftastic View Post
Thanks man appreciate it. Right now it's just a matter of investing in a quality battery relocation kit and then investing the time to relocate everything
@onesicksoob - while I have made some progress as noted above (notice, not only the fluid reservoir relocated to the trunk, but that whole side shaved down) I still have a LONG ways to go. Such is the life of a married man who works too much
All in good fun, you have to start somewhere.
No harder than other vehicle make really, just Subaru people always seem to be ngine the rest of the world. I haven't spent any money I wouldn't have spent anyway doing mine, aside from $300 or so on the pedal box setup.
onesicksoob is offline   Reply With Quote
Old 08-06-2012, 04:38 AM   #1505
onesicksoob
Member#: 215841
Dont PM me about
wheel specs
It's a slow night...here is what I accomplished since my last post.
Holes filled
Ground smooth-ish. That was my last grinder disc. :facepalm:
Old 08-14-2012, 08:31 PM   #1506
richy_21
Member#: 58670
2005 got muuuuu?
whos a good company that sells battery relocation kits? Looking for it all if possible dont wanna have to piece it together if at all possible.
richy_21 is offline   Reply With Quote
Old 08-14-2012, 09:19 PM   #1507
04ImprezaWRX
Member#: 120237
2004 WRX
Taylor makes a nice kit! You can get a good deal on Amazon.
04ImprezaWRX is offline   Reply With Quote
Old 08-15-2012, 08:50 AM   #1508
onesicksoob
Member#: 215841
Dont PM me about
wheel specs
If my calculations are correct I will have this all smoothed out with another eleventyfour billion hours of sanding.
Old 08-15-2012, 01:07 PM   #1509
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Don't get suckered in to buying a small-frame battery such as the Odyssey PC680 or similar. They simply are not up to the task - especially once they are relocated to the truck. I've gone through 2 of them before I gave up and just bought a full-size battery.
Also, no matter the size, stay FAR AWAY from "dry cell" batteries. If they are discharged below 8vdc EVEN ONCE, they are ruined. This information came straight from Odyssey.
5lipstream is offline   Reply With Quote
Old 08-15-2012, 01:34 PM   #1510
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
This is pretty much how my bay is sitting right now. This is after "stage 1". This winter is when I break out the big guns and do the full tuck.
Plan:
Brakes
* Relocate ABS unit using custom SS lines.
* Relocate brake biasing valve to the cabin under the dash.
* Relocate ABS sensor wires
* Relocate all hard lines on the firewall
Harness
* Complete custom mil-spec harness with a single entry point through the firewall. The only OEM harness parts being reused are the sensor plugs. Anything not being used will be removed.
* Relocation of fuse box. I'm not ready to disclose the location yet.
Bay
* Removal of every hole, bracket, or threaded boss not being used.
* Repainting
* Replacing OEM fan setup with custom FAL setup
Other
* Most of the vac lines have already been "streamlined" and replaced with braided nylon AN lines, but I still plan on rerouting a couple for a cleaner appearance.
* Currently, my 2GA battery cable for the relocated battery is ran under the car. I'm going to reroute the cable through the passenger cabin.
Old 08-15-2012, 02:49 PM   #1511
Pidgeon
Member#: 284247
2002 Wrx
MBP!
shiz looks awesome man
Pidgeon is offline   Reply With Quote
Old 08-15-2012, 02:59 PM   #1512
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
Check out Summit Racing. They carry the Taylor and Moroso kits, as well as their house brand. I'll likely be going with the Summit Premium kit for my 'Stang.
2point0 is offline   Reply With Quote
Old 08-15-2012, 09:13 PM   #1513
richy_21
Member#: 58670
2005 got muuuuu?
Ooohhh yea I like that box!
Old 08-15-2012, 09:15 PM   #1514
richy_21
Member#: 58670
2005 got muuuuu?
What battery do you recommend? I have a sub and amp. Thanks !
Old 08-21-2012, 01:02 PM   #1515
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
I bought a X2 Power with 770cca.
Here it is in the trunk
Old 08-22-2012, 01:24 AM   #1516
dub c
Member#: 145069
Keep It Sleazy
ATTN: Fluid Mechanics Experts
Not sure if it has been addressed on here.
When it comes to relocating the power steering reservoir, can the inlet/outlet (to the reservoir) be anywhere in relation to level with the pumps suction/discharge?
dub c is offline   Reply With Quote
Old 08-22-2012, 11:07 AM   #1517
richy_21
Member#: 58670
2005 got muuuuu?
Ok so if i get the taylor box will 12 ft of wiring be enough? For the negative and the postive wiring? Thanks for the help 5lipstream!
Ill start my rides thread up shortly. I have the XS mini battery and it wasnt the best idea like 440 cca i believe. Since the car barely sees pavement
Old 08-22-2012, 09:16 PM   #1518
dub c
Member#: 145069
Keep It Sleazy
Bump.
Old 08-23-2012, 03:57 PM   #1519
sjs0433
Member#: 86061
Am I the only one that does not like a fully shaved bay? I love the semi-shaved bay that's just been cleaned up. Something about the super smooth look of a fully done bay looks unnatural.
sjs0433 is offline   Reply With Quote
Old 08-23-2012, 04:14 PM   #1520
Pidgeon
Member#: 284247
2002 Wrx
MBP!
well, yes i think so haha the look of a engine sitting in the bay with no wires at all, is what makes it cool
Old 08-23-2012, 04:30 PM   #1521
onesicksoob
Member#: 215841
Dont PM me about
wheel specs
If I am understanding you correctly I am with you. I could have easily welded sheet over everything and made it 100% smooth, but I like it better being able to still see the indents and all the spots I seam welded and things like that. I did weld shut all the holes and only put back the ones that are neccesary but in more discrete places. I re-did the every harness in the car for cleaner routing so there is only one hole for wiring in the firewall, the 2 lines to the heater core, and the throttle cable. Thet are all tucked in by the transmission tunnel.
Old 08-23-2012, 04:57 PM   #1522
sjs0433
Member#: 86061
^I'm with you.
I personally think the one 5lipstream posted above is perfect. It's cleaned up a lot but not so much that it looks fake.
Old 08-23-2012, 05:49 PM   #1523
onesicksoob
Member#: 215841
Dont PM me about
wheel specs
Oh you are talking tuck? That is a mess, wires and lines everywhere.
Old 08-24-2012, 12:58 AM   #1524
Smurftastic
Member#: 243697
02 | BLOD Founding
Finally got around to ordering all the materials for the battery relocation. Picked up a distribution block as well - now time to to decide:
Is a circuit breaker and 150 amp in-line fuse overkill?
Old 08-24-2012, 08:14 PM   #1525
richy_21
Member#: 58670
2005 got muuuuu?
Heck ya. Should do ours together lol
washed engine bay, now car won't start CEL on pinoy_boy204 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 42 06-08-2010 09:12 AM
spilled oil in engine bay bugeye4life Newbies & FAQs 8 06-03-2010 03:51 PM
07 ABS actuator and all Engine bay lines TraviST185 Suspension/Brakes/Handling 1 04-08-2009 08:38 AM
06 STi attempted wire tuck, polished manifold, samco hoeses, baller custom intake reallyslow Member's Car Gallery 34 06-19-2007 01:11 PM
Wiring TT and keeping engine kill feature sssp Electrical & Lighting 2 08-15-2004 11:58 PM
