Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 10-17-2012, 09:40 AM   #1626
Geeoff
Member#: 106439
06 WRX TR
'05 Matrix XRS
Originally Posted by D Money View Post
I can email you my fitting list and pics of my setup however token-negro is correct about what he said above. Hes just comes off a little negative, nothing new.
I'm considering deleting the ABS as well, and would like to see your setup!
Geeoff is offline   Reply With Quote
Old 10-18-2012, 12:23 PM   #1627
armyssoldierboy
Member#: 109424
06 AW STI
Twin Scroll HTA gt3076r
Ok, I'm trying to dive in head first but can't figure out how to disconnect these plugs from the fuse box:
armyssoldierboy is offline   Reply With Quote
Old 10-18-2012, 12:28 PM   #1628
buddsautoparts.com
Member#: 263591
2004 being rebuilt
good question!
You have to disconnect that one through the top.
buddsautoparts.com is offline   Reply With Quote
Old 10-18-2012, 12:33 PM   #1629
armyssoldierboy
Member#: 109424
06 AW STI
I looked. I'm no idiot, maybe blind though lol
Old 10-18-2012, 12:57 PM   #1630
buddsautoparts.com
Member#: 263591
2004 being rebuilt
good question!
There are small clips that you have to lift from the bottom push the thing out the top then angle it and remove it form the bottom. If i had one in front of me it would be easier to explain. I just did this on a customers car a few weeks ago.
Old 10-18-2012, 02:35 PM   #1631
armyssoldierboy
Member#: 109424
06 AW STI
Ok there were two clips on the ends that I had to press for the big one. I think I see a couple for the two white ones but I need something thinner than my flathead.
Got it. I used a thin piece of aluminum I had shaved off from the radiator shroud I made yesterday.
Old 10-18-2012, 04:34 PM   #1632
armyssoldierboy
Member#: 109424
06 AW STI
Damn, right when I thought I was making progress... I can't get this to budge
Old 10-18-2012, 04:35 PM   #1633
buddsautoparts.com
Member#: 263591
2004 being rebuilt
good question!
can't really see what you are even looking at
Old 10-18-2012, 07:58 PM   #1634
subarutah
Member#: 248428
2006 STI
FROZEN GREY
I can't see your pictures since I'm on a nipr computer but I see that you're in Schweinfurt and I was there back in 05-08 . Conn or Ledward?
subarutah is offline   Reply With Quote
Old 10-19-2012, 12:08 AM   #1635
stevejones19
Member#: 275250
2006 WRX
Don't worry, you can't see it on any computer.
stevejones19 is offline   Reply With Quote
Old 10-19-2012, 12:47 AM   #1636
armyssoldierboy
Member#: 109424
06 AW STI
Lol sorry. Its the big harness with the plastic piece that slides into the fuse box...it runs to the alternator. The pic was from engine side looking at the side of the box.
^^I work on Conn, live on York Town.
Edit: I got it. There were a couple clips under the tape that separate that whole plastic piece in two. I got all the wires pulled through and the alternator hooked back up. Did y'all just mount the fuse tray without the big plastic white "box"?
Old 10-19-2012, 07:59 AM   #1637
armyssoldierboy
Member#: 109424
06 AW STI
Edit^
Old 10-19-2012, 08:21 AM   #1638
jvsoundwave
Member#: 66060
2007 STI Limited#534
Crystal Gray
Fully shaved in for show.. IMO.
But Im cleaning my bay up a Bit... Just tucked my Fuse box and added some better Power and Ground cables. Also added a inline fuse behind the battery so if it blows, I wont have to go into the fender.
jvsoundwave is offline   Reply With Quote
Old 10-19-2012, 12:22 PM   #1639
Mishimoto
NASIOC Manufacturer
Member#: 207954
^ Very clean.
Mishimoto is offline   Reply With Quote
Old 10-19-2012, 12:46 PM   #1640
armyssoldierboy
Member#: 109424
06 AW STI
Got the wires ran through. I might try to fab a bracket or do the zip lock thing and zip tie it to the other fat harness that runs to the headlights etc
Do y'all extend the wires and route them straight out the front by the fans and behind the headlight to the fuse box?
Old 10-19-2012, 01:41 PM   #1641
jvsoundwave
Member#: 66060
Crystal Gray
Originally Posted by Mishimoto View Post
^ Very clean.
THX bro!
Old 10-19-2012, 01:46 PM   #1642
jvsoundwave
Member#: 66060
Crystal Gray
You are better off replacing the starter and Alternator cable with 4g wire. Extending power wires isnt a good idea. But those smaller wires can be cut and solder in extensions. I would then route the wires through the hole closer to the headlight.
Old 10-20-2012, 01:12 AM   #1643
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
Yup, exactly. Then time to start shaving
Smurftastic is offline   Reply With Quote
Old 10-20-2012, 12:14 PM   #1644
armyssoldierboy
Member#: 109424
06 AW STI
All done for now. Moved fuse box, deleted windshield washer reservoir (I don't have hood sprayers), removed the sprayer lines, relocated abs sensor wires, removed a bracket by the master cylinder and shaved off this other piece of plastic that stuck past the radiator shroud.
Old 10-20-2012, 07:38 PM   #1645
BLUWRXWGNX
Member#: 290034
02 Impreza WRX
02C
Originally Posted by BLUWRXWGNX View Post
Here is My other project (yes I know its a VW)
Before:
Durring:
After: Not yet!! but its going to be Satin Blue w/flake and the engine bay will be bone white.
Got my VW finished.
BLUWRXWGNX is offline   Reply With Quote
Old 10-21-2012, 06:42 PM   #1646
XSCIV1
Member#: 257773
Hey guys, Its been a while since I posted but here are some photos from another show we have just had down here in NZ of my Subaru Wrx RA & yes it is fully wired up & is 99% complete
Let me know what you think. Ricci
XSCIV1 is offline   Reply With Quote
Old 10-21-2012, 06:55 PM   #1647
SIMPFLY
Member#: 54794
Jan 2004 WRX @ 5 mi
Dec 2016 @ 245,000 mi.
all these jazzed up engines are so gay
SIMPFLY is offline   Reply With Quote
Old 10-21-2012, 06:59 PM   #1648
JVD
Member#: 213130
...said the poor person
JVD is offline   Reply With Quote
Old 10-21-2012, 07:06 PM   #1649
subarutah
Member#: 248428
2006 STI
FROZEN GREY
LOL^ I can't wait to share pictures of mine
Old 10-22-2012, 02:21 AM   #1650
2006whitesti
Member#: 124311
2006 STi, 03WRX wago
10Tribeca,00 RS,99 Foz
This looks great, but how are you charging the battery?
2006whitesti is offline   Reply With Quote
washed engine bay, now car won't start CEL on pinoy_boy204 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 42 06-08-2010 10:12 AM
spilled oil in engine bay bugeye4life Newbies & FAQs 8 06-03-2010 04:51 PM
07 ABS actuator and all Engine bay lines TraviST185 Suspension/Brakes/Handling 1 04-08-2009 09:38 AM
06 STi attempted wire tuck, polished manifold, samco hoeses, baller custom intake reallyslow Member's Car Gallery 34 06-19-2007 02:11 PM
Wiring TT and keeping engine kill feature sssp Electrical & Lighting 2 08-16-2004 12:58 AM
