Old 01-19-2013, 07:44 PM   #1751
Ruzty1311
Member#: 311911
2012 WRX Limited
Satin White Pearl
Thought I would share these since they were at subiefest last year and were pretty awesome I don't take credit for any of the work done to these cars.
Ruzty1311 is offline   Reply With Quote
Old 01-19-2013, 07:54 PM   #1752
Smurftastic
Member#: 243697
02 Stg2+ WRX
Top Scoob 031
Originally Posted by EvileyeZ88 View Post
Pretty sure I'll be relocating my battery to under the passenger, and then shaving the battery pedestal.
I haven't touched my bay in months,
Thanks for lighting a fire under my ass smurfy.
I was amazed at how rough the bay was after shaving out the battery pedestal.. I felt like I had no choice but to replace the metal. But, I had some rust from water sitting under the pedestal.
Smurftastic is offline   Reply With Quote
Old 01-19-2013, 11:20 PM   #1753
xxscaxx
Member#: 86459
2013 BRZ
I drove with my fuse box in my fender like that forever... no issues. I had mine mounted upside down though so if anything did get wet it wasn't pooled up in there. You can also use an electric box like brcewayne did to cover it.
xxscaxx is offline   Reply With Quote
Old 01-20-2013, 07:44 PM   #1754
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
I'm going to be making a box similar to Brcewayne's to contain my fuse box, and a couple other goodies I have under the hood.
Big-Sexy907 is offline   Reply With Quote
Old 01-20-2013, 07:59 PM   #1755
Smurftastic
Member#: 243697
02 Stg2+ WRX
Top Scoob 031
Made a bracket to hook up the reservoir in the trunk today. +1 for daily drive-ability Bay is now completely shaved, smoothed out, and awaiting paint
Old 01-22-2013, 04:11 AM   #1756
Rice Devil
Member#: 51164
Jap Jp mag 09
Ti mag 09 (cover)
^^^^^ Pics before and after painting required ^^^^^
Rice Devil is offline   Reply With Quote
Old 01-22-2013, 09:08 AM   #1757
tuzzio
Member#: 292532
05 STI
Should've just found an IC sprayer tank for the trunk, so it would've been hidden. And hooked the lines to the windshield sprayer. Did it in my STI, worked great
tuzzio is offline   Reply With Quote
Old 01-22-2013, 01:42 PM   #1758
jasoncanseeoh
Member#: 235985
2008 FWD WRX STI
Originally Posted by Ruzty1311 View Post
My goodness, that's amazing. Does anyone know if the owner if this car is here on Nasioc? I wanna know more! Haha
jasoncanseeoh is offline   Reply With Quote
Old 01-22-2013, 02:25 PM   #1759
armyssoldierboy
Member#: 109424
06 AW STI
TS HTA 3076r 436hp/426tq
Perfect! I didn't even think of that. I took out the I/c sprayer and most of the lines :/ I guess I'll reroute em lol do you use the I/c sprayer button to actuate it? Or did you run the wires from the windshield reservoir pump to the I/c sprayer pump?
armyssoldierboy is offline   Reply With Quote
Old 01-22-2013, 03:14 PM   #1760
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Run the wires, it's easier than running the small hose.
Old 01-22-2013, 03:33 PM   #1761
tuzzio
Member#: 292532
05 STI
Personally mine is still hooked to the IC water sprayer button. I RARELY use that feature anyways.
Old 01-22-2013, 03:52 PM   #1762
vogun16
Member#: 93206
02 WRX....
JDM V7/8/9 RA-R Rotated
Was the IC reservoir sprayer 4 wires? I am cleaning up my engine bay and I need to do the same.
Vaughn
vogun16 is offline   Reply With Quote
Old 01-24-2013, 11:02 PM   #1763
Smurftastic
Member#: 243697
02 Stg2+ WRX
Top Scoob 031
Been searching for images of WRB Subies with black engine bays... bay will be ready for paint this weekend and I've boiled it down to black or a glossy blue. No luck on ze googles... any help is appreciated!
Old 01-24-2013, 11:04 PM   #1764
easterbran
Member#: 307359
'05 STi Stage II
Post a pic of an engine bay you like and I'd be more than happy to photoshop it whatever color! I'll do it tomorrow though.
easterbran is offline   Reply With Quote
Old 01-25-2013, 11:51 AM   #1765
Smurftastic
Member#: 243697
02 Stg2+ WRX
Top Scoob 031
Well.... mine isn't ready yet... I suppose there is no greater WRB (sorry, I know "Blurple") example than D Money that I can think of.
Old 01-25-2013, 11:57 AM   #1766
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
I recently did my in WRB. But my pictures of it suck. No shaving. It's not my thing. I just wanted a super clean bay.
Before:
After cleaning and sanding:
After paint:
Old 01-25-2013, 12:28 PM   #1767
mmfullen
Member#: 236685
2008 WRX 5 door WRB
30R'd &PPG'd...yup.
^very nice...might have to do the same when my motor goes.
mmfullen is offline   Reply With Quote
Old 01-25-2013, 01:26 PM   #1768
ScoobyJD
Member#: 185910
07 WRX TR
kpluiten, what subframe is that?
ScoobyJD is offline   Reply With Quote
Old 01-25-2013, 02:04 PM   #1769
kpluiten
Member#: 120273
06 WRBWRXWGN
RPM. They are out of business now.
Old 01-25-2013, 07:50 PM   #1770
Smurftastic
Member#: 243697
02 Stg2+ WRX
Top Scoob 031
kpluiten, I was going to say I was surprised you didn't have any rust under/around your battery tray, but I guess you live in Arizona so that's not a problem
For now not running hydra or using an aftermarket BCS, has anyone run a longer line between the restrictor pill and BCS in order to hide the entire BCS mess under a TMIC? Thinking about this in my head...
Old 01-26-2013, 09:32 AM   #1771
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Anyone know where I can find a m10x1.0 IF tee? I can't seem to find one and the vendor referred to in the forums is no longer in business.
This is for linking the rear brakes into the ABS delete I'm working on.
Blammo, found it.
http://www.technafitstore.com/FEAMLE...-p/319-31b.htm
Old 02-05-2013, 07:26 PM   #1772
Smurftastic
Member#: 243697
02 Stg2+ WRX
Top Scoob 031
Alright, not done but I do feel like I've reached a solid milestone. Everything deleted except for A/C, P/S, and ABS, since this is a true DD. In the future I will probably delete AC and ABS if I can pick up some other DD on the cheap.
Learned a lot in this process over the course of many many months, doing portions of this a few hours at a time (or large chunks of time for soldering). Definitely a newfound respect for the craftsmanship that went into some of the other builds in here.
I don't feel like I'm done, but I do feel that I've reached a good milestone.
Old 02-07-2013, 12:11 PM   #1773
bouse1
Member#: 8106
2001 Impreza RSTi
Looks great Smurf. Any photos of the fuse box from the inside?
bouse1 is offline   Reply With Quote
Old 02-07-2013, 12:22 PM   #1774
Realityryan
Member#: 346282
2011 Subaru Wrx Sti
Spark Silver Metallic
That looks awesome.
Realityryan is offline   Reply With Quote
Old 02-07-2013, 06:58 PM   #1775
Smurftastic
Member#: 243697
02 Stg2+ WRX
Top Scoob 031
Unfortunately I didn't take a picture of the fuse box location.... it is located just above the wheel well.
I have been thinking about moving the oil catch can back to the firewall behind the turbo.... but had a friend catch an engine fire when one of his hoses came off his setup in the same location. I see a lot of people place their catch can or AOS in that location... curious about group thoughts on that unlikely but possible issue.
washed engine bay, now car won't start CEL on pinoy_boy204 Factory 2.0L Turbo Powertrain 42 06-08-2010 09:12 AM
spilled oil in engine bay bugeye4life Newbies & FAQs 8 06-03-2010 03:51 PM
07 ABS actuator and all Engine bay lines TraviST185 Suspension/Brakes/Handling 1 04-08-2009 08:38 AM
06 STi attempted wire tuck, polished manifold, samco hoeses, baller custom intake reallyslow Member's Car Gallery 34 06-19-2007 01:11 PM
Wiring TT and keeping engine kill feature sssp Electrical & Lighting 2 08-15-2004 11:58 PM
Message Board Statistics All times are GMT -4. The time now is 05:27 AM.
