Welcome to the North American Subaru Impreza Owners Club Saturday February 28, 2015
Old 03-17-2007, 07:51 PM   #1
GripGC8
Member#: 110653
87 FC3S
Default ABS delete
does anyone know which model 93-01 impreza L had no ABS?
or can anyone tell me how they deleted ABS in thier factory ABS equipped GC?
im working on shaving my engine bay and i need to get rid of ABS
GripGC8 is offline   Reply With Quote
Old 03-17-2007, 11:22 PM   #2
igoreka
Member#: 116722
I did this, it's pretty hard and time consuming.
First I got all the parts from Junk yard, all the lines (here you can practice how to take them out in one peice, I used like four different cars), new reservuar and cylinder, new ratio cylinder (whatever its called, black little thing)
You gotta have all four lines changed: 2 to wheels and 2 to the ratio cylinder, you can't really use any from the once you have, except the once that go to the rear wheels from ratio cylinder, don't touch those.
The easy part is to remove them from the car, you can bent them but putting another pair is tricky and you have to remove everything you can what's on your way, I can't remember if I had to remove my A/C line.
Another thing is get your self a really good ranch for brake lines, will save time.
As far as electrical I don't know my harness is RA, and had no ABS originally
I hope that helps, I better not spend 5 minutes writing this for nothing, good luck
igoreka is offline   Reply With Quote
Old 03-18-2007, 01:35 AM   #3
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
what in the world is so important that you need to take out the ABS?? Unless you are driving in deep gravel or deep snow, w/o ABS you will stop longer and lack control in avoidance situations. Not the best idea when you are adding 100+hp IMHO.
-Rob
rob is offline   Reply With Quote
Old 03-18-2007, 02:33 AM   #4
STi_VIII
Member#: 72957
2004 EJ257 VF37 51E
w/ TypeRA Roof Vent & Lip
The guys at Sport Compact Car have proven that ABS does not always mean a shorter stopping distance. Using logic, it is easy to see why ABS will not stop a vehicle as quickly as possible. Most ABS systems work by modulating the brake pressure around a programmed value. A perceptive driver can maintain the brake pressure closer to the best value. ABS does do a more consistent job most of the time, though. It also makes for a safer vehicle in emergency "panic" stops because the average driver would just stab the brakes instead of a more appropriate brake pressure. Obviously, better ABS does a better job than older systems. Think of ABS like a shotgun. If you can't aim too well, a shotgun is better.
STi_VIII is offline   Reply With Quote
Old 03-18-2007, 11:10 AM   #5
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
the 00/01RS abs unlike the gda is VERY VERY good
even on snow. its still 2 channel but still a really good system
problem is most people are not good enough drives.
for abs to be advantageous you have to not straight arm panic stop but steer around the problem with the brakes flored
Old 03-18-2007, 12:43 PM   #6
kheff46
Member#: 66739
2002 WRX wagon
ABS= better for soccer moms(or non driver types in general). my STi swapped L has no ABS(it's wired and mechanically there, but my chassis was non ABS so i left it) and i like it bettr than my OBS with ABS.
--keith
kheff46 is offline   Reply With Quote
Old 03-18-2007, 12:53 PM   #7
jamesfacts
Member#: 51282
98 RS
black & blue from parking
How is the 00/01 system different from the 98/99?
I've always been curious: does the programming in the pump or the ecu have a greater impact on how effective the system is?
jamesfacts is offline   Reply With Quote
Old 03-18-2007, 01:46 PM   #8
sheepdog
Member#: 93773
1995 Flat Khaki GC8
2011 STi Wagon
Mine was deleted during my motor swap
sheepdog is offline   Reply With Quote
Old 03-18-2007, 02:18 PM   #9
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
--keith
hmm yeah......ok. I guess that means every single race team runs without ABS?
I have raced rally-x enough to know that ABS off is simply slower every single time (having tried both over the past several years). I have run my mr2 (no ABS available) on the track. Even with fairly good threshold braking skills, I still have to leave a little more margin for lock up than if I had ABS. The notion that it's not advantagious for any kind of serious driving is just silly.
-Rob
Old 03-18-2007, 02:27 PM   #10
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
I don't think its a debate over teh functionality of ABS, its just that the ABS on the GC bodied preza's sucks. I can't tell you how many times my ABS sensor has mistaken a bump for a lockup and I almost blew into the back of a soccer mom because it totally dropped my pedal out from under my foot. A well tuned ABS system is great, but the older **** is more of a hassle than a help.
civic2scooby is offline   Reply With Quote
Old 03-18-2007, 02:38 PM   #11
GripGC8
Member#: 110653
87 FC3S
i didnt ask what everyone thinks of 00-01 abs systems...if you like it in your car thats fine...im taking it out of my car.
i have my own brake lines i can bend..i just need to know what parts i need to source that are non abs.
so far i know i need a prop valve, master cylinder, and brake booster from a non-ABS impreza L..anything else?
thank you
Old 03-18-2007, 07:30 PM   #12
kheff46
Member#: 66739
2002 WRX wagon
-Rob
don't be gay! if it weren't truly useful, they'd delete it and save weight like anyone with some common sense! of course it helps, but has been proven to be a wash in SOME circumstances for some types of drivers. not all drivers are created equal obviously!
and nowhere did i say it's not advantageous(mine is correct spelling), you assumed that.
--keith
Old 03-18-2007, 07:33 PM   #13
kheff46
Member#: 66739
2002 WRX wagon
thank you
FYI. my whole system is ABS parts, just not working like ABS. if it helps you out any!
--keith
Old 03-18-2007, 08:35 PM   #14
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
are the weight savings worth it? wouldnt it be easier just to pop the fuse?
i think i might do this on my obs, i had ABS. my brighton doesnt have it and it stops pretty good, but not as good as my all wheel disc equipped wagon
mxpunk is offline   Reply With Quote
Old 03-19-2007, 02:01 AM   #15
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
--keith
Keith,
I was responding this comment:
"ABS= better for soccer moms(or non driver types in general). "
You seem to suggest ABS is not a braking performance enhancer. You didn't elaborate much past this so perhaps I missed your point. Oh and I'll send you a cookie for winning the spelling bee (and you tell me not to be gay...harhar)
Grip:
Without debating the effectiveness of the ABS system, let me try again. What are you trying to fit under you hood that you need to remove the ABS pump for? It's seems like, if nothing else a HUGE hassle and maybe there is a way to fit what you are trying squeeze in there in a different way?
-Rob
Old 03-19-2007, 02:25 AM   #16
Brydon
Member#: 107569
1998 Forester S
SRP
thank you
Wow no info on this thread at all. Any way all you need is two brake line T's You cna like me steal them off of a non abs japanesse car. Toyotas and Nissans work great. My car was origanally a non ABS car but when I went Brembos and STI master cylinder I got rid of the hill holder crap so i had to do this. It is really easy but would be easier to do on ABS equiped car.
All of the lines run to the ABS unit. 2 lines un and four out. I was told to set up the brake lines in an X direction, meaning front left to back right and front right to back left. So that is how I set them up and have been running no ABS Brembos for a year and a half now. They brake great! great response great feel. It actually takes a lot of work to get them to lock up. you need to really hammer on them in the wet. If you have good tires and brakes then I wouldn't worry about it unless you like to panic a lot.
Hope this actually helps!
Brydon is offline   Reply With Quote
Old 03-19-2007, 12:46 PM   #17
nme187
Member#: 117763
Pull the fuse =P ftw
I want to remove mine since now I have the damn ABS light on, but Id rather have the light then ABS...
nme187 is offline   Reply With Quote
Old 03-19-2007, 04:10 PM   #18
johnkaldar
Member#: 51047
1999 gc8 RS/sti-ra
This doesn't answer what parts to order, but I vote for running new lines with proportion valves for each corner!
johnkaldar is offline   Reply With Quote
Old 03-19-2007, 06:15 PM   #19
GripGC8
Member#: 110653
87 FC3S
some good info....still not sure as to the simple'st way to do this.
im not trying to fit somthing under my hood...im trying to get rid of useless things under my hood.
ABS is just an aid for stopping and i dont need an aid.
Old 03-19-2007, 07:03 PM   #20
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
Grip:
-Rob
He mentioned that he's cleaning up his engine bay. I've been thinking the same thing, as the unit has a jungle of lines coming out of it, with rusted fittings and all.
Instead of going through the hassle of remvoing the ABS, I'm just going to make a fiberglass cover for it. I would suggest that Grip consider doing something similar.
t3hWIT is offline   Reply With Quote
Old 03-19-2007, 10:18 PM   #21
LegacyWRX
Member#: 127048
97 Impreza coupe
blue
Is it as easy as pulling a fuse? Would I just be able to put it in when i want abs? It's cool, but annoying. I would like to be able to just pop in a fuse when it snows.
LegacyWRX is offline   Reply With Quote
Old 03-20-2007, 02:54 AM   #22
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
are you joking? 00-01 abs sucks balls. hard. even with featherlight pressure on (considerably slick) ice, it would stop tens of feet further than a properly removed ABS car. mine used to have it.
thank you
i dont know if the impreza L master is a 3 or 4 port, butif it matters to you, heres a few things to know:
early 90s legacys have the same brake lines in them. they are more abundant in the junkyards as well. there are 2 types of non-abs in them that ive seen, a 4 port and a 3 port.wh ichever you get, get it all, itll be easier. oh, and its WAY easier to pull/instal with the motor out, so look for a car in the J yard without a motor, youll thank yourself when you put them in.
Hurley 2.5 WRS is offline   Reply With Quote
Old 03-20-2007, 11:27 AM   #23
nme187
Member#: 117763
Yah I've seen people hook a switch up to the abs fuse so when you want it BAM! Only downside to having it off is the ABS light; I'd have that light either way since one of my ABS sensors is all fugged up =( ftl(cant find which one....)
http://www.rs25.com/forums/showthrea...bs+fuse+switch
Old 03-20-2007, 03:24 PM   #24
t3hWIT
Member#: 58779
95 STi RA (rhd)
In my car, if you hit the brake and gas pedal at the same time, the ABS light comes on and you no longer have antilock brakes.
Turn the car off and back on, and everything's fine.
Old 03-20-2007, 10:38 PM   #25
Ryobob
Member#: 143976
Default why
u wanna delete abs?
Ryobob is offline   Reply With Quote
deleted calweezy Brakes, Steering & Suspension 1 05-20-2010 09:31 AM
**Delete Me** huminajumina Private Vehicle 'For Sale' Classifieds 11 05-17-2010 10:46 AM
What ABS delete lines do i get for my wrx? ki11switch Brakes, Steering & Suspension 4 09-16-2009 02:57 PM
Brembo+ABS Delete+ Auto. Issues or no? Seraphinwolf Subaru Conversions 2 02-09-2009 02:27 PM
ABS Deletion on a MY2000 2.5 RS d00f Brakes, Steering & Suspension 0 03-21-2007 07:37 PM
