Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 03-18-2007, 02:21 PM   #1
spaz619
Member#: 24741
1997 Legacy GT
black
Default How to Install Hella Supertones w/o relay
Just want to make sure I wire things up correctly.
Do I just splice into the existing wiring for the OEM horns?
And obviously ground each Hella horn.
Is this all there is to the install without a relay?
spaz619 is offline   Reply With Quote
Old 03-18-2007, 04:27 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
No need to cut/splice the factory wiring- just get two spade connectors, four of the spade receptacles, and some wire. Run a negative wire from the spade connector to the two spade receptacles and push them on the horns, then do the same for the positive wire. It doesn't matter how you put them on the factory wires, they'll still work.
Brian
Old 03-18-2007, 05:16 PM   #3
spaz619
Member#: 24741
1997 Legacy GT
black
By not using a relay......could this be hazardous?
Old 03-18-2007, 05:21 PM   #4
spaz619
Member#: 24741
1997 Legacy GT
black
Brian
My car is a 2006 Impreza, therefore I have 2 discs for the horn. So its basically plug n play? Just buy 4 male spade connectors, 4 female spade connectors, and a lil wire......and I'm set?
Also, by not using a relay will this cause any issues or be hazardous?
Old 03-18-2007, 06:24 PM   #5
KPT
Member#: 136889
Yeah it's just plug and play. The Hellas need to be grounded, as was already said, and you can just take the wire from the stock horns and hook it to the other hella terminal. I had to extend the wire though in order to place the hellas where I wanted them.
It's been documented in a few other threads that running it without the relay is not dangerous and will not harm the car, they just won't be quite as loud.
I'm running mine with no relay and trust me they are plenty loud.
KPT is offline   Reply With Quote
Old 02-20-2009, 07:04 PM   #6
T-Heineken
Member#: 157988
2004 WRX Impreza Wgn
Does anyone who isn't using the relay want to sell it?
Mine hella relay = dead
T-Heineken is offline   Reply With Quote
Old 02-20-2009, 09:04 PM   #7
wirolla
Member#: 109725
2001 GM6
SRP
or you could just get another relay for about $10.....
wirolla is offline   Reply With Quote
Old 02-20-2009, 11:54 PM   #8
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
you can buy a relay anywhere.at any hardware/auto parts/ electronic store.
jdubya301 is offline   Reply With Quote
Old 02-21-2009, 01:19 AM   #9
rougeben83
Member#: 115154
2005 Outback XT
White on grey
no relay is fine. Some say the horn is just a little louder with the relay...I couldn't tell the difference so I didn't bother making a seperate harness for mine.
rougeben83 is offline   Reply With Quote
Old 02-21-2009, 01:24 AM   #10
fulie
Member#: 142345
2002 WRX 34'd
There is a thread on here that tests with and without the relay from different distances.
With the relay its only 2db louder then without at best I believe 116db without and 118 with
fulie is offline   Reply With Quote
Old 02-22-2009, 05:42 PM   #11
Honest Bob
Member#: 94698
2005 30R Wagon
CGM
Ive had the horns hooked up both ways. They are louder when using a relay, however the extra wiring mess isnt worth the loudness.
Honest Bob is offline   Reply With Quote
Old 02-24-2009, 03:59 PM   #12
BLACKBUG03
Member#: 193604
dude you can have mine pm me
BLACKBUG03 is offline   Reply With Quote
Need help installing Hella Supertones wrxugly Southern California Impreza Club Forum -- SCIC 17 11-06-2007 11:33 PM
Bored So I Installed HELLA Supertones Seattle206 Member's Car Gallery 26 12-03-2006 12:55 AM
Installing Hella Supertone Horn Question keithja Car Audio, Video & Security 9 01-02-2003 02:15 AM
How loud are Hella Supertones? JC Interior & Exterior Modification 20 11-16-2001 10:41 AM
How to Install Hella 500's??? Help. thepas General Forum Archive 15 02-16-2001 09:51 AM
