Old 03-18-2007, 10:52 PM   #1
dhunckyn
Member#: 98553
2013 WRX Hatch
Default New Dyno. 06 wrx vf-39 FMIC
First I would like to thank Nathan (for the great tune) and the guys at Pro Power Dyno Service (for their hospitality and great faciltiy). cheers.gif The car feels great, much smoother than before and the added power is noticeable. On Cobb's Mustang dyno I was 251/285 with an APS TMIC. Now 311/332 on a Dynojet dyno. Not sure how much of a increase it is but it does feel much better, maybe 20+ more hp????
old Dyno
Current mods:
VF39 from STi
Perrin FMIC
Perrin shorty Intake
Cobb TBE
ProTune by Nathan
Clutch Masters FX300 Clutch
Clutch Masters lightweigt Flywheel
Prodrive Springs
Whiteline swaybars
Whiteline Diff Bushings
Seibon carbon fiber hood
SSR 17x7.5 Comp Wheels 225/45-17 tires
SSR 18x8 GT10 Wheels 225/40-18 tires
..and some other stuff I'm sure I'm forgetting about
dhunckyn is offline   Reply With Quote
Old 03-18-2007, 11:20 PM   #2
Cyclops
Member#: 95017
2000 2.2RSTI stroker
2010 SWP STI
With the TMIC were you still using the vf39? With a pro tune how much of a difference do you feel going to the FMIC? I'm debating whether to go FMIC with a vf39 or stay TMIC until I get the Green. Either way nice setup.
EDIT: Sorry let me rephrase that. You already told me you felt maybe a 20hp change. What I meant to ask is what other possibly negative side effects did you notice, like a delay in boost, etc. The only posts I've found searched have mostly been without a retune. Those that did retune usually say there is hardly a difference. Just looking for some comparison.
Cyclops is offline   Reply With Quote
Old 03-18-2007, 11:39 PM   #3
dhunckyn
Member#: 98553
2013 WRX Hatch
yes and it was also protuned (at cobb by Christian), honestly I'm not feeling any difference in lag. If you can afford it go FMIC. the vf39 has to work hard to make good boost and (or at least it does at my altitude, WG wide open and I can only hit 18psi) and the FMIC really helps to keep the intake temp down.
Old 03-19-2007, 12:20 AM   #4
djsniggedy
Member#: 102157
What you lookin at
willis?
i need a login to see the numbers
djsniggedy is offline   Reply With Quote
Old 03-19-2007, 12:38 AM   #5
dhunckyn
Member#: 98553
2013 WRX Hatch
Sorry, is that better?
Old 03-19-2007, 04:35 AM   #6
WhiTe_07_WRx
Member#: 135623
2007 Subaru
Nice Numbers man
WhiTe_07_WRx is offline   Reply With Quote
Old 03-20-2007, 02:34 AM   #7
j87w
Member#: 123349
06 wrxsti
aspen white
Nice. Im setting up a Appt with him to get a tune in the next few weeks. Looks good
j87w is offline   Reply With Quote
Old 03-20-2007, 07:09 PM   #8
dudley123
Member#: 120831
PIA Purpose Built -
SEMA-FullRace/HRE/Cosw.
Hmmm... I like those numbers... I have the same setup with the VF39 on an 06 with a FMIC... DO you know if He will tune things like your idle...AVCS?...
Chris
dudley123 is offline   Reply With Quote
Old 03-20-2007, 09:43 PM   #9
dhunckyn
Member#: 98553
2013 WRX Hatch
Chris
Ask him Nathan's Screen Name is nmyeti
Old 03-23-2007, 09:50 PM   #10
alpnwhite96
Member#: 115482
2006 WRX Limited
my vf39 isn't hitting target boost.. time to find a writeup!
alpnwhite96 is offline   Reply With Quote
Old 03-24-2007, 02:58 AM   #11
DigitalPunk
Member#: 124236
2006 WRX Built EJ257
Version 8 Twinscroll
excellent numbers brian! car felt amazing before the protune, i bet it's haulin ass now!
DigitalPunk is offline   Reply With Quote
Old 03-24-2007, 11:59 AM   #12
Scuba Steve
Member#: 35543
04 GT35R STi+E85
[email protected] @5800ft elv.
15:1 AFR's?
Scuba Steve is offline   Reply With Quote
Old 03-24-2007, 03:13 PM   #13
WRX_UA
Member#: 116189
2006 WRX Wagon 2.5L
Very black with T518Z...
Originally Posted by Scuba Steve View Post
15:1 AFR's?
+1 something weird...
WRX_UA is offline   Reply With Quote
Old 03-24-2007, 03:30 PM   #14
ProjectChaos
Member#: 129245
2007 Subaru WRX
Obsidian Black Pearl
Awesome numbers
ProjectChaos is offline   Reply With Quote
Old 03-24-2007, 03:30 PM   #15
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
It could not have been reading the AFR from the tail pipe, I suspect they did not have a sensor in the dyno wide band.
Jarrad
PDXTuning is offline   Reply With Quote
Old 03-24-2007, 03:30 PM   #16
sjl1614
Member#: 56791
06 OBS
You will see a good difference between a Mustang dyno and a Dynojet. Dynojet's are made to read 10-13% higher than all other dyno's. You can thank harley davidson for that
sjl1614 is offline   Reply With Quote
Old 03-24-2007, 04:15 PM   #17
Scuba Steve
Member#: 35543
04 GT35R STi+E85
I thought it was Yamaha and the Vmax back in the 90's .
Old 03-24-2007, 09:30 PM   #18
sjl1614
Member#: 56791
06 OBS
It was harley that caused this. Their engines didn't make what they wanted so dynojet "adjusted" the software so the power output was higher
Old 03-25-2007, 08:40 PM   #19
dhunckyn
Member#: 98553
2013 WRX Hatch
O2 wasn't hooked up to dyno, Nathan had his LM-1 hooked up to their sensor. The Dyno also wasn't getting a good signal for boost. The data logs show a more consistent boost #
Old 03-25-2007, 10:25 PM   #20
Mooneyes13
Member#: 113666
60' all over you
good stuff, i love the dyno picture
Mooneyes13 is offline   Reply With Quote
Old 03-25-2007, 11:33 PM   #21
Bboy AJ
Member#: 127021
2006 OBP WRX TR
So it will be a 20 WHP gain, generally speaking, from a FMIC instead of a TMIC? No lag or any other side effects, other than the extra hit to your wallet? Huh.
Nice numbers!
Bboy AJ is offline   Reply With Quote
Old 03-26-2007, 01:08 AM   #22
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Do not confuse lag for boost threshold. A dyno plot does not show lag, it shows boost threshold. A FMIC will always add lag, it may not be something that bothers you as a driver, but there is always an increase in lag with addtional piping.
Old 03-26-2007, 02:59 AM   #23
SKSTI
Member#: 116311
Nice numbers.
I like FMIC set up. It's a no-brainer that a front mount configuration facing cool air head-on is going to do a better job at cooling than a duct-fed con fig. The only gripe I have with this set up is not the price, but weight. Damn, these things are hefty.
I've got a WBR FMIC kit waiting to go on the FXT. I was happy when USPS wheeled the box out to me (gee, I wonder why) and was taken by how heavy the unit is. I've checked with APS's DR725 and noticed the shipping weight on that thing is no joke also - 80 lbs.
SKSTI is offline   Reply With Quote
Old 03-26-2007, 11:15 AM   #24
dhunckyn
Member#: 98553
2013 WRX Hatch
Nice numbers!
With a tune I would say it's safe to say that you can get a 20hp gain with a FMIC on a vf39. I'm not feeling a difference in lag (but that could just be me). It's a hit on the wallet; intercooler + intake + tune, but I'm that much closer to being ready for a bigger turbo all I need now is fuel pump (on order) injectors, and a new gear set for the tranny and another awesome tune by Nathan.
Originally Posted by SKSTI View Post
Nice numbers.
I may be wrong but I think the Perrin FMIC only adds about 9lbs when you figure up what you take off to install it.
Old 03-26-2007, 11:39 AM   #25
aps2fast4u
Member#: 57871
2004 WRX
13.4 @ 102
Yea, I don't that a FMIC adds too much weight as opposed to a TMIC. Yea, the core is quite bigger but that's really the only thing adding weight, as the piping is very light. I would estimate a net +20lbs. max when going from TMIC to FMIC depending on core size.
Back on topic, nice numbers, love the torque of the EJ255 in the 06+ WRXs.
aps2fast4u is offline   Reply With Quote
Fs: 06 Sti Vf-39 jung187 Engine/Power/Exhaust 5 04-08-2010 11:20 AM
F/S 06 STI vf 39 turbo,pristine condition,no cracks! bertune Engine/Power/Exhaust 1 05-31-2009 10:15 AM
New Dyno. 06 wrx vf-39 FMIC dhunckyn Proven Power Bragging 1 03-18-2007 11:42 PM
2006 Wrx Vf-39 Dyno Results subieracer18 Proven Power Bragging 40 02-04-2007 08:15 AM
VF-39 FMIC..in hot weather, worth it? WrxRick Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 08-30-2006 01:16 AM
