#1 |
Member Sales Rating: (11)
Member#: 112510
South East
Vehicle:2006 WRX, Black |
You are looking at a used TURBOXS Engine Management System Computer (UTEC). This unit is in perfect working order and was only used for about six months prior to me selling my 03 WRX bugeye. This UTEC computer has a tunned MAP loded that was custom made for my WRX. Map was tunned for the fallowing modifications:
Full turboback ehxaust Upgraded injectors Air intake This auction also includes a used manual TURBOXS boost controller for the higher bidder. Boost controller is in perfect working order. Package contents: UTEC computer Computer serial cable Boost controller & 8inch vaccum line This item is currently listed on eBay, here is a link for it: Click HERE for eBay auction on this Item. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() UTEC standard features include: Plug-&-Play installation with OEM connectors for 2001-2005 WRX No cutting, splicing or additional sensors required 20 minute, do-it-yourself installation End-user programmable via PC or PDA with HyperTerminal and serial cable Fine tune the maps for your exact setup Pre-programmed base maps get you started quickly and safely Base maps for our Staged upgrade packages, dyno proven and road tested from the leader in WRX tuning Don’t waste hours tuning just to get your car to idle and cruise decently Maps can be e-mailed or simply downloaded then uploaded Four (5) maps plus “stock mode” selectable with a flick of the switch Create custom maps for street gas, race gas, nitrous, or whatever No need to lug around a laptop just to switch between your programs Optional remote dash mounted switch available View switch here Fuel, ignition timing, and boost are programmable in 250rpm increments up to 9000rpm over 10 load sites Complete ignition timing control No need to worry about the factory ECU pulling timing anymore Be as aggressive or conservative as you want or just let the factory ECU determine timing at any point in the map Fuel control Controlled via MAF sensor signal offset Tune stock and larger than stock injectors Load reference MAP (manifold pressure) Closed loop boost control programmable via Throttle Position and RPM No more re-adjusting the boost controller due to changes in temperature or altitude Keeps boost low while in closed loop fuel mode for reliability Knock control Automatically retards timing when the knock is detected safeguarding against engine damage Adjustable knock threshold, timing correction, and duration On board data logging Provides valuable information to assist you in tuning Built in programmable solenoid controller Control nitrous, water injection, intercooler water spray or any other solenoid device Primary rev limit control Drag racing launch control (secondary rev limit used during launch) Shave precious time off your launch Free software upgrades As we add more features, simply download the latest software version from our website and upload it to the UTEC. UTEC FAQ How does the UTEC increase WRX engine performance? By allowing the user to tune more aggressive ignition timing, air fuel ratios and boost curves. With 36 RPM sites from 250 RPM to 9000 RPM and 10 load sites, the UTEC gives you 360 possible map points for fuel, ignition timing, and boost. How much extra power can I expect from the UTEC? This really depends on the other modifications you have done to your WRX. The UTEC will let you get the most out of whatever hardware you have on your WRX. On a stock WRX, power gains of 30-40 horsepower at the wheels are easily and safely obtained. Adding a freer flowing exhaust, a larger turbo, an upgraded fuel system, etc. will allow even larger power gains. Our staged upgrades will allow you increase horsepower from between 40hp to over 120hp more than stock. We have used the UTEC on our personal WRXs to make even more power. Ultimately, how much power your WRX makes with the UTEC will depend on how well you have prepared the car’s power train and how well the car is tuned. Is the UTEC a piggy-back computer or a stand alone engine management system? The UTEC is a really a bit of both. It acts as a stand alone system in that it gives you complete control over ignition timing, fuel and boost under load. The factory ECU is also used to manage some of the more mundane functions that are necessary to keep a car drivable on a daily basis. Some examples are cold start, hot start, and closed loop fuel control under cruise conditions. Does the UTEC run low impedance injectors? No. Do I have to start from scratch and do all the tuning myself? No. The UTEC comes pre-programmed for various sets of modifications like exhaust, turbo chargers, fuel system upgrades, etc. Although these maps may not be a perfect fit for your exact modifications, they will get you close. However, you will need to fine tune the setup. If you stick to our staged upgrades, you may not have to do any tuning at all if you do not want to. Can I blow up my engine with the UTEC? Absolutely! If improperly tuned, the UTEC will give you the ability to destroy your engine in short order. However, as long as your modifications match our kits, our pre-programmed maps offer a good, safe starting point. What are some of the ad vantages of the UTEC over other engine management systems? The UTEC comes pre-programmed for a given set of modifications so you can simply plug it in and drive away, yet it is also user tunable allowing you to take full ad vantage of your modifications. It also allows you to create and store up to 5 different programs that can be used at the turn of a dial. There is no need to drive around with your laptop simply to change from one map to another. Maps are easily shared with others via e-mail. You can go back to stock setting with the turn of dial. Data logging is included. The list goes on and on. Does the UTEC modify the original factory engine control unit? No. The factory engine control unit is not altered in any way. Removing the UTEC puts all engine management control back in the hands of the unaltered factory ECU. How do I install the UTEC and how long will it take? The UTEC simply plugs in to the factory ECU using OEM connectors. Installation takes no longer than 30 minutes and requires no cutting of wire or soldering. Most of the time is spent simply gaining access the factory ECU that is under the carpet in the passenger foot-well. Who can tune the UTEC? With a little practice and patience, our belief is that anyone can. What octane gas should I use with the UTEC? We suggest you tune your car on the best gas that is readily available in your area. We’ve created our street maps using 93 Octane unleaded gasoline. If you run a lower Octane gas, you will have to modify the programs appropriately. What else do I need to effectively tune the UTEC? While tuning can be done solely on the road, tuning is most effective when done on an AWD dyno combined with road tuning. For the most accurate fuel tuning you will need a good wideband O2 sensor that is accurate down to at least 10:1. The UTEC logs AFR from the front O2 sensor, but it is only accurate down to about 12:1, which is too lean for normal pump gas. Narrow band AFR gauges that work off of 1V O2 sensors are useless for accurate fuel tuning. For accurately tuning the UTEC's Knock Correction system, some form of knock amplification/detection hardware is required.
| Thread Tools | |
| Display Modes | |
| FS: 02-05 Subaru Impreza (WRX/STI) 3" TANABE Super Medalion Racing Cat-back Exhaust | subadupa | Engine/Power/Exhaust | 10 | 04-25-2010 05:14 PM |
| OEM Fog Lights w/bulb 02-05 Subaru wrx | wrxdragger | Exterior/Styling | 1 | 11-28-2007 08:13 PM |
| AEM EMS 02-05 SUBARU WRX with sensors $1200 OBO | alex03wrx | Engine/Power/Exhaust | 4 | 05-16-2007 05:20 PM |
| AEM EMS 02-05 SUBARU WRX with sensors $1300 OBO | zeb0r | Engine/Power/Exhaust | 3 | 05-07-2007 07:49 PM |
| F/s 02-05 Subaru Wrx Cross Drilled Rotors | junkyardgabe | Suspension/Brakes/Handling | 0 | 12-05-2006 07:57 PM |
