Notices
Old 02-16-2013, 07:36 PM   #551
blessthekellen
Member#: 273859
MY98
WRX
Here is the ECU off my Version 4 WRX with the EJ20K.
Not sure what numbers off here work, if none of them do let me know and I'll try and find another number stamped on the ECU..
http://farm9.staticflickr.com/8051/8...2f809848_k.jpg
blessthekellen is offline   Reply With Quote
Old 02-17-2013, 07:56 PM   #552
junior9463
Member#: 291539
1995 L
looks like these numbers should work, ill pm you if anything but thanks!
junior9463 is offline   Reply With Quote
Old 02-21-2013, 03:16 PM   #553
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Any chance of part numbers for the coolant hoses under the intake manifold for both G and K?
tenchu is offline   Reply With Quote
Old 04-02-2013, 07:07 PM   #554
t1bud42
Member#: 298635
http://www.rallysportdirect.com/cata...eywords=ej20g+
they say that these are the head gasket I need for my ej20g? is this true?
also I was wanting the whole Turbo inlet hose for my motor samco had them what is the best to get?
t1bud42 is offline   Reply With Quote
Old 04-03-2013, 11:16 AM   #555
mike-tracy
Member#: 135290
2000 Impreza
BRP
This is the parts # thread. Search for info on the saamco, its well covered elsewhere. As far as that need gasket goes, the description states those are for 2000-2005 wrx's. It is too thin for a stock ej20g.
mike-tracy is offline   Reply With Quote
Old 04-03-2013, 07:13 PM   #556
loyms
Member#: 350142
95 wrx sti jdm
Default Parts #'s yo for newb
Car- 95 Subaru WRX STI JDM
Valve Cover Gasket set, Intake manifold gaskets, PCV valve,
loyms is offline   Reply With Quote
Old 04-03-2013, 10:06 PM   #557
t1bud42
Member#: 298635
Rally sport said they called and confirmed it is why I'm asking!
Thanks for your help
Old 04-05-2013, 01:10 AM   #558
mike-tracy
Member#: 135290
2000 Impreza
BRP
The 02-05 WRX gaskets are too thin for ej20g's. Your valves will likely do a tapdance on the pistons in short order. However, in the item description, they also mention a number .051, is ~ 1.3mm, and is thick enough for an ej20g with stock internals. It's good that you asked a second opinion. So despite their description of the compatible years, this will work as they promised over the phone.
I didn't click past the first page in the link to see the full details, sorry for the mis-info initially.
Old 04-06-2013, 07:15 PM   #559
WelDun1
Member#: 249130
1999 Ver5 STi RA
Ver6 ej207 rebuild gasket kit? I've heard ppl say that the 02-03 USDM ej205 works, but I wanna be sure.
WelDun1 is offline   Reply With Quote
Old 04-29-2013, 11:34 AM   #560
razerv3c1
Member#: 354933
98 wrx sti
white
Default ej20K
hey im buying a BPM 38 series twin dump down pipe but need to know which one to buy. theres one for VHI IHI turbos or whatever and then TD04 and 05. i just imported a 98 wrx sti Ver. 4 would anyone know what the turbo is? im pretty sure its a TD05 but i wanna make sure so i dont waste mmoney on a down pipe that wont fit. also if anyone knows a cheap BPM twin dump pipe please msg me as well. thanx
razerv3c1 is offline   Reply With Quote
Old 04-29-2013, 01:14 PM   #561
WelDun1
Member#: 249130
1999 Ver5 STi RA
Yeah you have a vf24. JDM WRX STi only come with IHI VF series turbos. The td04/5 came on USDM WRX
Old 04-29-2013, 01:23 PM   #562
eg33GC
Member#: 206851
56 Belair
Pro Street
wrong
wrx had td04 and td05 til v3
eg33GC is offline   Reply With Quote
Old 04-29-2013, 01:37 PM   #563
WelDun1
Member#: 249130
1999 Ver5 STi RA
Originally Posted by eg33GC View Post
wrong
Td04 only came on usdm WRX and the ver3 WRX had a vf22 optional on 22b
Old 04-29-2013, 01:42 PM   #564
WelDun1
Member#: 249130
1999 Ver5 STi RA
And if I'm wrong, the TURBO link here is wrong, and I know its not
Old 04-29-2013, 03:00 PM   #565
eg33GC
Member#: 206851
56 Belair
Pro Street
none of your normal wrx owner has any idea these engines existed, let alone the capacity to make a comprehensive turbo list.
The 1992-1996.5 Subaru Impreza WRX had ONLY a MHI Td04 13t OR a Td05-s16g.
NOTHING ELSE.
Old 04-30-2013, 12:53 AM   #566
razerv3c1
Member#: 354933
98 wrx sti
white
So this would be the bpm down pipe for me?
http://revworksracing.com/cgi-bin/sh...tml/product=89
Old 05-10-2013, 09:07 PM   #567
Bruere
Member#: 353523
1998 STi RA V-Ltd
Super Mica Blue
Is it still possible to get ahold of these CD's??
Looking for the part number for a power steering pump for my MY98 WRX STI Type-RA V-Ltd.
Engine:EJ20KDW7PJ
Thanks!
EDIT: Also curious if this part is directly available from any USDM EJ?
Bruere is offline   Reply With Quote
Old 05-17-2013, 09:33 AM   #568
peanutswagon
Member#: 197057
1997 98 Foz V3 swap
In need of a power steering pump for my 1996 wrx ej20g.... does any of the usdm ones fit? Rs or wrx? This is really tough to search
peanutswagon is offline   Reply With Quote
Old 06-21-2013, 02:40 PM   #569
83portalberni
Member#: 350658
2000 impreza
black
Default lil help if you can
i have a 94-95 jdm ej20 from an sti i need to order parts from a parts store napa lordco
i just need a year and model to order engine parts if you can help
i need timing belt tensioner
plugs and wires
and such things
thanks
83portalberni is offline   Reply With Quote
Old 06-22-2013, 03:04 AM   #570
derk
Member#: 162625
if its a 94-95 then its still just a EJ20G, in which case, you dont have spark plug wires, cuz it runs a coil on plug ignition system.
spark plugs - NGK Copper V-Power plugs, BKR7E - #4644
or you can run the NGK V-Power race plug, R5671A7 - #4091
timing belt tensioner 1990-1997 legacy 2.2L
you should probably confirm that its a 20G first though.
plugs and wires
and such things
thanks
derk is online now   Reply With Quote
Old 06-22-2013, 03:39 AM   #571
super2ner2006
Member#: 98536
1999 Impreza 2.5RS
Silverthorn Metalic
Axles for 97 sti?
super2ner2006 is offline   Reply With Quote
Old 06-22-2013, 07:00 PM   #572
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Originally Posted by super2ner2006 View Post
Axles for 97 sti?
Same as any AWD GC Impreza.
i_c_the_light is offline   Reply With Quote
Old 08-27-2013, 08:40 PM   #573
yap
Member#: 209685
2004 STI
are the ej20g and ej20k under bucket shims the same?? im looking for under bucket shims for an 95 wrx ra
yap is online now   Reply With Quote
Old 08-29-2013, 07:38 PM   #574
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Yes, they are
2slofouru is offline   Reply With Quote
Old 09-05-2013, 05:34 PM   #575
DusterDizz
Member#: 302465
I need a oil pan gasket and a oil separator plate for my ej20k. Are these the same as a usdm wrx?
DusterDizz is offline   Reply With Quote
EJ20G & EJ20K Parts awdeclipseguy 1993 - 2001 Impreza Specific Parts 17 06-15-2009 07:04 PM
EJ20G Gasket Part Numbers... scoobydorift Subaru Conversions 13 02-14-2005 10:43 PM
Official XT Oil Filter Part Number thread BrysImpreza Forester Forum 8 10-29-2003 11:23 PM
NAPA Part numbers- can we have a nice thread with numbers listed? Tex-WReX2 Service & Maintenance 5 12-15-2001 09:21 AM
