Old 04-01-2007, 03:19 PM   #51
Lachlan
Member#: 19470
1981 Brat GL
Do your CDs include procedures or just parts? I need a scan of the page(s) that show how to remove/replace EJ20K heads (bolt order, torque, etc.)
Lachlan is offline   Reply With Quote
Old 04-01-2007, 03:40 PM   #52
555 WR
Member#: 127307
96 WRX Type R
555 Subaru Blue
thanks marnix for the #'s on the rear deck cover, did you see in the picture if there were any speaker covers? is anyone shipping/selling these as a burned copy?
555 WR is offline   Reply With Quote
Old 04-01-2007, 08:57 PM   #53
linsavy
Member#: 11620
1997 GF4-STiV3 clone
Originally Posted by kheff46 View Post
so can any canadian friends hook us up with new turbo inlet/boots for our K's? i would like to buy one to solve my hiccup. i would really be interested in a metal one with flex boot. since plastic has failed once already. i don't want to give it a second chance!
--keith
I think your best bet is the silicone chinese/auzzy boot that Jaxx is using.http://cgi.ebay.com/ws/eBayISAPI.dll..._promot_widget
I doubt we can get the stock one here. I currently am running a USDM WRX pipe with some refabbed connections, its not going to be there long.
linsavy is offline   Reply With Quote
Old 04-01-2007, 10:07 PM   #54
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yeah i don't know if i could do it on the car though .. he hose for the PCV is really cranky/burried
yup i have ordered 2 things from those guys now.. things show up faster than parts shipped from the east coast via ups ground
and i have a stock one but i think i gouged it with a screwdriver taking it off
Old 04-02-2007, 01:43 AM   #55
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
well, i might as well ask.
numbers for version 4 sti type RA heads (complete)?
Hurley 2.5 WRS is offline   Reply With Quote
Old 04-02-2007, 02:55 AM   #56
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
For that I have othe CDs, but the EJ20G head bolts are torqued down exactly the same as the US EJ25D.
Clearly no covers, and specifically for the STI type RA.
Marnix is offline   Reply With Quote
Old 04-02-2007, 09:57 AM   #57
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
another ej20k request
power steering cooler
Old 04-02-2007, 01:28 PM   #58
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
That number starts with 34685, and that's where my JDM parts CD stalls: if there aren't any different part numbers, but just a single one, it doesn't show the number, instead I get an error message (in Japanese). Sorry.
As for EJ20K STI headgaskets:
11044AA463, the reinforced STI gasket for the EJ20K.
Old 04-02-2007, 06:16 PM   #59
Lachlan
Member#: 19470
1981 Brat GL
Is a scan of that floating around somewhere?
Old 04-02-2007, 08:08 PM   #60
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
its the same as any dohc subaru isnt it? so wrx pattern should work
Old 04-02-2007, 08:15 PM   #61
Lachlan
Member#: 19470
1981 Brat GL
Jaxx says the EJ20K head gasket is -355 (1.37mm), Marnix says it's -463 (.8mm)--which is correct?
Old 04-02-2007, 09:42 PM   #62
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
when did i say that??.. matt may have but not i
Old 04-02-2007, 10:14 PM   #63
Lachlan
Member#: 19470
1981 Brat GL
car gc8d48d
build 5/97
engine EJ20KDW6HE
tranny TY752VBCAA
plug wires:
-#1 - 22451AA793 not in system
-#2,4 - 22452AA682 not in system
-#3 - 22451AA822 not in system
coil pack: 22433AA370 (1) 73.19
maf: 22680AA271 (1) 210.91
power steering lines
-RHD 34610FA091 not in system
-LHD 34610FA100 not in system
boost solenoid: 16102AA091 not in system
map sensor: 22012AA160 (1) 219.39
iac: 22650aa132 not in system
injectors: 16611AA231 not in system
head gasket: 11044AA355 (2) 27.78
sti reinforced head gasket: 11044AA463 not in system
water pump gasget: 21114AA051 (1)1.93
rear main seal: 806786040 (1) 8.74
cam seals: 806732150 (4) 5.87
valve cover gasget:
-right? 13270AA062 (1) 9.64
-left? 13272AA063 (1) 9.64
-?? 13293AA051 (4) 5.82 (says its for an 05-6 h6?)
-wash rocker cvr (13271AA051 (12 or 16) 2.38
manifold to intake: 14035AA281 (2) 3.32
manifold to throttle body: 16175AA151 (1) 1.70
manifold to IAC: 22659AA060 (1) 3.88
manifold to injector: 16608AA020 (4) 5.22
crank
-(#3 thrust bearing) 12200AA150 364.71
-(#5 thrust bearing) 12200AA2240 272.60
main bearings
-(#3 thrust bearing) 12209AA000 84.80
-(#5 thrust bearing) 12209AA360 133.41
rod bearings: 12108AA290 182.80
rods 12100AA240 52.70
rings: 12033AA730 not in system
rear deck cover
-Up to July 1997: 65510FA001ML not in system
-April 1997 on: 65510FA001OE not in system
12345
Old 04-02-2007, 10:35 PM   #64
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
you realize you want the STi k head gaskets right?
i am positive they are 1.37mm, so says the set in my garage that came from my motor.
Old 04-02-2007, 10:46 PM   #65
Lachlan
Member#: 19470
1981 Brat GL
I know, but Jaxx and Marnix have different part numbers for the K gaskets
Old 04-03-2007, 02:11 AM   #66
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
The standard 'K' gaskets are 1.37mm composite gaskets, 11044AA355.
On some 'K' (STI?) engines the gaskets are 1.37mm metal gaskets, 11044AA463.
Sorry for the confusion.
Old 04-03-2007, 02:34 AM   #67
Lachlan
Member#: 19470
1981 Brat GL
But here you say the -483 is the 205/207 gasket and is .8mm thick
Old 04-03-2007, 09:40 AM   #68
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
all the number in that post are from marnix
since -355 is available and -463 is not, your choice is obvious
Old 04-03-2007, 02:53 PM   #69
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Besides, 11044AA463 and 11044AA483 are different part numbers and different parts.
Old 04-03-2007, 03:00 PM   #70
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
My Ej20K has the metal gaskets. Does this my engine has been apart previously?
Old 04-03-2007, 04:16 PM   #71
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
can you tell w/o taking it apart?
Old 04-03-2007, 04:17 PM   #72
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
so, are there any part numbers for complete heads?
i know you can get them overseas.
Old 04-03-2007, 05:18 PM   #73
Matt Monson
Member#: 832
99 2.5RS, '85 911
Yes. It's pretty obvious on my engine.
ps. Guess what just got delivered. Muhahahaha?!?!?
Old 04-03-2007, 06:53 PM   #74
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
part number for the plastic ends on the fuel injectors. I am not quite sure what they are called. They are like little plastic fuel injector condoms...I can get a picture if that doesn't make sense.
civic2scooby is offline   Reply With Quote
Old 04-03-2007, 06:53 PM   #75
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
what?
also,
are you questioning your own "muahahahaha"?
EJ20G & EJ20K Parts awdeclipseguy 1993 - 2001 Impreza Specific Parts 17 06-15-2009 07:04 PM
EJ20G Gasket Part Numbers... scoobydorift Subaru Conversions 13 02-14-2005 10:43 PM
Official XT Oil Filter Part Number thread BrysImpreza Forester Forum 8 10-29-2003 11:23 PM
NAPA Part numbers- can we have a nice thread with numbers listed? Tex-WReX2 Service & Maintenance 5 12-15-2001 09:21 AM
