Old 09-28-2008, 12:08 AM   #101
xxscaxx
Member#: 86459
2013 BRZ
sorry for the crappy quality.
xxscaxx is offline   Reply With Quote
Old 09-28-2008, 10:56 AM   #102
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Yeah, I may just do it myself, I just ordered some hose and -6 AN fittings for my fpr. Maybe Ill order up some of the hi pressure tefflon line and do the p/s stuff.
scby rex is offline   Reply With Quote
Old 09-28-2008, 02:17 PM   #103
skate enjoi
Member#: 120716
2002 psm ver7 wrx
reversed and rotated
cool. Ill be trying to do mine today
skate enjoi is offline   Reply With Quote
Old 03-15-2009, 06:38 PM   #104
wgknestrick
Member#: 32576
04 STI
Just to add some more info to this thread.
The low pressure return line from the rack uses a 16mm x 1.5 o-ring female to AN adapter. This is the larger line that is right next to the high pressure line by the up pipe.
http://store.summitracing.com/partde...EAR-9894DBJERL
This will allow you to use the line you have left from the high pressure line to run the return to the fluid tank.
wgknestrick is offline   Reply With Quote
Old 08-06-2009, 04:56 PM   #105
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Originally Posted by salt View Post
One thing I just remembered, take the O ring out of this part.
http://store.summitracing.com/partde...0&autoview=sku
Luckily I found it in the line before it got a change to circulate around.
I believe using this part will prevent having to remove any o-rings:
http://www.summitracing.com/parts/EAR-9919DFHERL/
It's just a straight-up -6 AN male to 14x1.5mm male adapter. I'm assuming it should probably be used with a crush washer on the metric side like a standard banjo bolt would have underneath.
lancelucas is offline   Reply With Quote
Old 03-01-2010, 10:44 PM   #106
scby rex
Member#: 104878
02 wrxbastardchild
bumping up this good info. Just ordered the fittings, Ill make the rest at work with ss hardline and teflon braided.
Old 03-06-2010, 08:36 PM   #107
scby rex
Member#: 104878
02 wrxbastardchild
Ok, I did mine a little different. I made hardlines and then Im making the braided ones, just waiting on a couple parts.
Old 03-07-2010, 12:20 PM   #108
wrxd1
Member#: 240427
04 rexx
187 murderrd
idk if you guys know this but pandl motorsports sells a braided line for the power steering on subys.. for rotated turbos or stock!! like 100 bucks ez enough
wrxd1 is offline   Reply With Quote
Old 03-07-2010, 04:11 PM   #109
scby rex
Member#: 104878
02 wrxbastardchild
yup, didnt want my line routed like theirs. I like being different and making parts myself, also the one pandl sells can be made for 77 bucks.
Old 03-07-2010, 07:40 PM   #110
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
hrm. good info.. reviewing it makes me wanna keep my ps.
Dubstar112 is offline   Reply With Quote
Old 03-10-2010, 04:21 PM   #111
xxscaxx
Member#: 86459
2013 BRZ
i just had to redo my PS line. im an idiot and picked up the wrong type of line (wasnt teflon) and when i was having some fun in the latest snowstorm i blew a hole right through the line. *sigh*.
scby rex - i like the way you have done that so far. what are those bolted/tied down? (the hardlines). i was going to do something similar, but i just have way too much crap over there already. my perrin kit doesnt allow for much room either between the uppipe and tranny.
Old 03-11-2010, 08:13 AM   #112
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Both good to know... I still need to figure this one out for my swap. Maybe my next parts order?
Seraphinwolf is offline   Reply With Quote
Old 03-11-2010, 03:36 PM   #113
xxscaxx
Member#: 86459
2013 BRZ
P&L, just to clear up any confusion on that.
Old 03-11-2010, 10:03 PM   #114
scby rex
Member#: 104878
02 wrxbastardchild
xxscaxx, Im going to use clamps to hold them and bolting them to existing holes. My order is backlogged til the 18th.
Old 03-12-2010, 12:22 AM   #115
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
It can be done for even less money if you don't use so many aluminum fittings. I've done a few of these so far and I just order the one lower adapter fitting, and have the rest crimped together by a local industrial supply shop out of stainless fittings and teflon/braided line. You pay a lot more for the blue and red.
CKxx is offline   Reply With Quote
Old 03-12-2010, 07:59 AM   #116
xxscaxx
Member#: 86459
2013 BRZ
^my dad just crimped me a set for mine and thats exactly what i did. im actually glad b/c as much as i love earl's fittings, the red and blue i hated in my engine bay
Old 03-12-2010, 08:12 AM   #117
Mechie3
Member#: 120152
So no restrictor? Going to pick up parts tonight while the motor is out.
Mechie3 is offline   Reply With Quote
Old 03-12-2010, 08:17 AM   #118
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
In for info as well
Bad Noodle is offline   Reply With Quote
Old 03-13-2010, 11:19 AM   #119
scby rex
Member#: 104878
02 wrxbastardchild
No.^ The only "restrictor" Ive seen is the flex part of the hose is slightly smaller than the hardline.
Old 03-13-2010, 11:29 AM   #120
Mechie3
Member#: 120152
Sounds good since I bought the parts last night.
Old 03-14-2010, 01:07 PM   #121
cpturbo
Member#: 49175
2004 STI
Yeah, and mine blew up for and almost started a fire. Yeah, I bought it from P & L with their turbo kit.
Sucks
cpturbo is offline   Reply With Quote
Old 03-14-2010, 09:17 PM   #122
xxscaxx
Member#: 86459
2013 BRZ
and how did it blow up? only way i could see it breaking is if it was sitting on something and burned a hole through it. not saying this is the case, but i just wanted to know what caused it.
Old 03-14-2010, 11:36 PM   #123
Mechie3
Member#: 120152
How did you guys remove the crimped hose on the return line? Did you just cut it off?
Old 03-15-2010, 11:29 PM   #124
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Awesome info Bill! I didn't see this until now but you confirmed my digging around! Now I will have -6 high pressure line and -6 low pressure line. The question is, does anyone know what size I should run from the pump to the tank on the low pressure side? I'm thinking it's -10 but my friend thinks -12.
D Money is offline   Reply With Quote
Old 03-16-2010, 11:52 AM   #125
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
This isn't a good idea bro. That fitting is not high pressure. You need to run crimped on fittings only or a power steering designed fitting seen here.
http://www.anplumbing.com/shop/index...ower!_Steering
I agree the earls fitting you used looks soo much nicer, but it's going to be bad news if it leaks. Your car will catch on fire since the up pipe and turbo are right there. I had to suck it up too and get fittings that were silver and didn't match the rest of my fuel, coolant, & crank vent systems.
pic of the stock oil feed line ej20 please supernick77 Newbies & FAQs 1 09-08-2009 03:48 AM
How important is the placement of power steering line behind the grill tino Built Motor Discussion 23 06-01-2009 06:26 PM
Does Perrin rotated mount inlet/intake hit power steering lines? garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-03-2006 10:14 AM
short video of the broken Power steering pulley reddevil Normally Aspirated with bolt-on Forced Induction Powertrain 7 01-04-2005 01:50 AM
Any locals with the dreaded power steering line problem? supermarkus North West Impreza Club Forum -- NWIC 6 01-01-2002 10:58 PM
