#126 |
Member#: 156655
SCIC
Vehicle:2005 STi cgm |
be careful guys the power steering feed (high press) side needs high pressure line ONLY!! i laughed when i had first seen PandL's joke of a steering line hahaha, obviously not intellegent when it comes to hydraulics. the hose you need to use will look like -10 on the outside and have a -6 inner. ITS BEEFY!! remember small overlooks can cause major damage!!! ill post pics shortly of the proper setup incl. all part numbers/hose types
kenny "Yeah, and mine blew up for and almost started a fire. Yeah, I bought it from P & L with their turbo kit. Sucks "
#127 |
Member#: 104878
TXIC
Vehicle:02 wrxbastardchild aw, 1,000,000 whp 2 aw tq |
Yeah, it has to be a ptfe line with powersteering line ends, they are stainless not aluminium. The one I have a pic of it the proper end.
#128 | |
Member#: 86459
Vehicle:2013 BRZ SWP |
i can laugh now but im fortunate. |
#129 |
Member#: 186356
Vehicle:2006 WRX-pte6262 CTS-V,& 05 RS |
so this setup will not fit with the oem setup/factory inlet then?
because i have my motor out,perfect time to do it,but down the road i will be going rotated. |
#130 |
Member#: 120152
Vehicle:2006 06 WRX, 86 FMOD Blue, White/Red |
It will. Well, it better, since that's what I'm doing. It might depend on your specific PS pump. I eyeballed mine holding parts up next to it when the engine was still in.
You might not be able to use the 90* and come directly off the pump towards the fender. It looks like I might have to angle it forward just enough to clear the turbo inlet and then hook under my intake pipe before being secured to the frame rail for support. |
#131 |
Member#: 104878
TXIC
Just run it down the frame rail and use a 90 at the pump. dont run it under the manifold.
#132 |
Member#: 186356
Sounds good,i would like to do this as well because of how the stock lines are ran tucked up on the side of the fuel rails/head.
way too much clutter going on there. |
#133 |
Member#: 120152
I should have pics by monday. Put the line on the rack last night, but have more engine work to do before I do the pump side/put the engine back in.
For the fitting on the pump, I removed the o-ring, but don't see how the fitting seals. It's a standard thread, not NPT and there's no seal on the inside. Did you guys just wrap it with a lot of teflon or stick a copper washer uner the adapter? |
#134 |
Member#: 86459
i put a copper washer, and teflon. originally just had the copper washer but i had a slight leak so i put the teflon on.
#135 | |
Member#: 109948
Vehicle:. Most famous car on Nasioc ever. :/ |
For the low pressure line from the pump to resovior and resovoir to the rack I did mine just in regular earls swivel seals. From what I was told, that would be ok. What do youthink? Clutch lines are high pressure too, correct? I did a sick ass setup on mine and I wanted to post info on it so others can do it as well. It consists of a -3an 8" high pressure line, m10x1.0->-3an fitting, and m12->-3an banjo and crush washers. Basically it gives a one sure shot connection from the master cylinder to the slave cylinder. It's really neat. haha Good thing! That had bad news written all over it! |
#136 |
Member#: 186356
So then the original mentioned parts on the first page should not be used?
Should it be made at a hydraulics shop,or are the summit bought parts adequate enough for this? |
#137 |
Member#: 120152
^^ I don't think he's saying that. I think he's referring specifically to the aluminum anodized end fittings and the plain rubber hose used xxscaxx. The fittings on teh first page are aluminum adapters (which are plenty thick) and SS end fittings and teflon hose meant for high pressure.
#138 |
Member#: 186356
excellent,thanks for clearing that up.
#139 |
Member#: 86459
yeah i ****ed up on that lol. but that picture was used for reference for the adapter fitting for the rack...at least that fitting was ok
#140 |
Member#: 109424
International
Vehicle:06 AW STI TS HTA 3076r 436hp/426tq |
Josh/ scby rex had told me about this a couple weeks ago. I just happened to stumble across this thread. It seems like there's alot of "use this instead of this". Josh had said the ps lines would get in the way of my rotated kit that I'll be recieving tomorrow. It looks like I'll be ok for the time being although it's a tight fit and I am interested in doing this.
Someone should post a Barney style how-to for people like me From a complete parts/links list to routing of the lines etc. |
#141 |
Member#: 104878
TXIC
routing is up to you, theres really 2 ways, under the manifold and one similar to stock but out of the way.
The first page has the summit parts you would need, just make sure they are for powersteering lines if you buy them elsewhere. Mainly that the line is teflon and the fittings on that line are stainless. I have the packages for the min parts you need also if you want to stop by. |
#142 |
Member#: 186356
im getting all my pieces in today,probably installing this weekend,ill try to get some pics of the assembly.
#143 |
Member#: 120152
Only a week late with pics, but here they are.
First, I didn't like the o-ring fitting bit to go on the pump itself. I couldn't pull the stock fitting off either (which itself is an o-ring fitting) to replace it. My issue was that the surface under the hex was beveled. This is probably why other people had trouble with it leaking with just a copper washer. I spun it on a lathe and made that surface nice and clean.Ooooh, shiny. ![]() ![]() The return line was replaced with 3/8" fuel line (low pressure return) and zip tied to the ABS lines. The high pressure line was -6AN teflon line with SS end fittings. All the bits used were as suggested in post 1 (except I went to "Earl's Indy" in person and just gave them the list). This also came up and zip tied along the frame rail, but I put some coolant hose over it where it had the potential to rub. If I've learned anything about working with braided lines over the years it's this: diamond cutting wheels cut cleaner and faster and last longer than carbide wheels you will stab your fingers multiple times and make them bleed SS braid can and will rub through anything it touches (and sometimes magically move just to piss you off) ![]() Here's a nice top down view of the new fitting. Unlike the stock bit, it actually doesn't rub against the turbo inlet. Score! Plus, it looks 100x better than bent zinc coated steel and frees up the left side of the manifold. ![]() Took a few minutes to bleed it, but it worked. Started by having the wife turn the wheel (front up on jack stands) as I filled it (car not running). Then I started the car and slowly turned it left. I would stop when it started to shudder to allow the pump to try and catch up and not destroy my rack. Then to the right. After 3 times of this, the shuddering was at a minimum. I went left-right quickly a few times and it went away. Did it a few more times for good measure and I was good to go. No leaks, no problems while actually driving. Pic ho-ing, waiting for the test drive: ![]() |
#144 |
Member#: 186356
nice,looks like what im doing on mine.
on the return line,did you just clamp the rubber hose over the fitting on the rack? or did you add a fitting to that first. |
#145 |
Member#: 120152
Just clamped it. I used one of the clamps that was on the "S" bent tube that went from the aluminum line to the return port on the tank.
Edit: Pic ![]() Last edited by Mechie3; 03-29-2010 at 11:28 AM. Reason: I find witty responses here amusing |
#146 |
Member#: 238843
Vehicle:1997 Honda Accord |
These lines can be bought already made "bolt-on status"!
#147 |
Member#: 104878
TXIC
Yeah...we know, its been said before. Some of use can make this part for less than 100 bucks though and how we want it.
#148 |
Member#: 109424
International
I ended up cutting the s hose on the reservoir and made the line go straight in. The hard line coming from the p/s pump I bent a little and the hose just went under my intake.
#149 |
Member#: 104878
TXIC
now lose the oem pressure line.
#150 |
Member#: 70459
TXIC
Vehicle:2002 AW Bugeye ej257 6spd, GT3076R, Alky & EWG |
can you get to the steering rack thing without removing the turbo or motor? i've been thinking about doing this but looks preteen tight.
| Thread Tools | |
| Display Modes | |
| pic of the stock oil feed line ej20 please | supernick77 | Newbies & FAQs | 1 | 09-08-2009 03:48 AM |
| How important is the placement of power steering line behind the grill | tino | Built Motor Discussion | 23 | 06-01-2009 06:26 PM |
| Does Perrin rotated mount inlet/intake hit power steering lines? | garface | Factory 2.0L Turbo Powertrain | 3 | 06-03-2006 10:14 AM |
| short video of the broken Power steering pulley | reddevil | Normally Aspirated with bolt-on Forced Induction Powertrain | 7 | 01-04-2005 01:50 AM |
| Any locals with the dreaded power steering line problem? | supermarkus | North West Impreza Club Forum -- NWIC | 6 | 01-01-2002 10:58 PM |
