Old 03-30-2010, 09:29 AM   #151
Mechie3
Member#: 120152
From what I hear, it's possible, just not all that much fun.
Mechie3 is offline   Reply With Quote
Old 03-30-2010, 11:29 AM   #152
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
if you get under the car,there is enough room to do it,yes.
jsnm is offline   Reply With Quote
Old 03-30-2010, 09:51 PM   #153
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Originally Posted by ownnij View Post
can you get to the steering rack thing without removing the turbo or motor? i've been thinking about doing this but looks preteen tight.
just pull the turbo/uppipe. Then its really easy.
scby rex is offline   Reply With Quote
Old 03-30-2010, 09:59 PM   #154
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
or you can pop out the axle
Old 04-02-2010, 02:15 PM   #155
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
now when i connected the pressure line,i put the fitting(http://www.summitracing.com/parts/RU...5&autoview=sku) right on the rack,without the use of the blue adapter.
this fit perfect,but will it leak without it?
Old 04-02-2010, 07:02 PM   #156
scby rex
Member#: 104878
02 wrxbastardchild
It probaly will the flairs are different. 45* vs 37*
Old 04-04-2010, 01:05 PM   #157
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
greaaat,i guess ill pop that fitting off and put in the other piece then.
Old 04-05-2010, 10:47 AM   #158
Mechie3
Member#: 120152
On my rack, it wasn't a flare fitting at all, but an O-ring fitting. The adapter goes from the o-ring fitting to the AN flare fitting. The threads might match, but the sealing surfaces definitely won't.
Old 04-05-2010, 12:56 PM   #159
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
i got a problem here,my pressure fitting on the rack is alot smaller than the fitting mentioned(http://www.summitracing.com/parts/EA...0&autoview=sku).
what is the smaller diameter fitting for this?
Old 04-05-2010, 01:06 PM   #160
Mechie3
Member#: 120152
What part itself is too small? I have an 06 WRX and used the parts on the first page.
Old 04-05-2010, 01:09 PM   #161
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
The Earl s Performance 9894DBHERL fitting,it connects to the russell hose adapter piece,but it is too big for the fitting on the rack itself.this fitting just slides right inside of it and is too small. im stumped here.
Old 04-05-2010, 11:49 PM   #162
scby rex
Member#: 104878
02 wrxbastardchild
did you order the return fitting on accident? The return line is bigger than the pressure one.
edit, dont know what the problem is, got a pic?
Old 04-06-2010, 08:36 AM   #163
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
yea,that must be the case,it has to be the return line fitting,its the same size as that one.
what is the proper(smaller) size for the pressure fitting?
Old 04-06-2010, 07:58 PM   #164
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
anyone know?
i dont know how i ended up with too big of a fitting
Old 04-07-2010, 09:33 AM   #165
Mechie3
Member#: 120152
Should be in the list in the first post.
Old 04-07-2010, 09:38 AM   #166
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
Old 04-07-2010, 09:48 AM   #167
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
I have the perrin rotated pipes (horrible fitment) and I just used a flexible high pressure hose, it worked fine and cost 5$ Ill try to get a pic up sometime
BlackJavaPearl04 is offline   Reply With Quote
Old 04-07-2010, 07:19 PM   #168
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
k,figured it out,must have ordered the wrong thing,in 16mm instead of the 14mm fitting.
Old 04-11-2010, 07:25 PM   #169
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
nevermind,worked perfect.
all fittings were correct
Old 04-20-2010, 09:18 PM   #170
WRenXhaven
Member#: 43905
02 WRXBastardchild
Ah well crap, got all excited to do this, gathered all the parts into my basket just to find out both the Russell Powerflex Hose ends are out of stock! Estimated ship date, 5/10/2010
WRenXhaven is offline   Reply With Quote
Old 04-20-2010, 11:01 PM   #171
scby rex
Member#: 104878
02 wrxbastardchild
hahahhaah, yup, Im waiting til the 23rd of this month for 1 90 fitting. I have everything else here and fabed.
Old 04-21-2010, 09:12 PM   #172
WRenXhaven
Member#: 43905
02 WRXBastardchild
Went to Jegs, will have everything in a week, but I did grab one of the last fittings.
Old 04-24-2010, 03:35 AM   #173
WRenXhaven
Member#: 43905
02 WRXBastardchild
Well shatmaster! Got everything but one part
Old 04-24-2010, 12:19 PM   #174
Hayaboosted
Member#: 60042
2004 WRX STI
Rotated T67 ALLABOUTSPEED
I ordered my stuff from Jegs last week or so.. Also try Lefthander chassis for those fittings.. Im pretty sure they have them.
Mark
Hayaboosted is offline   Reply With Quote
Old 04-24-2010, 12:24 PM   #175
STIBungy
Member#: 51684
My P&L power steering line has been leaking for a while now and I've noticed the braided line is swelling. Some plastic goo from under the braiding is seeping out. Weird!
STIBungy is offline   Reply With Quote
pic of the stock oil feed line ej20 please supernick77 Newbies & FAQs 1 09-08-2009 04:48 AM
How important is the placement of power steering line behind the grill tino Built Motor Discussion 23 06-01-2009 07:26 PM
Does Perrin rotated mount inlet/intake hit power steering lines? garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-03-2006 11:14 AM
short video of the broken Power steering pulley reddevil Normally Aspirated with bolt-on Forced Induction Powertrain 7 01-04-2005 02:50 AM
Any locals with the dreaded power steering line problem? supermarkus North West Impreza Club Forum -- NWIC 6 01-01-2002 11:58 PM
