Old 08-11-2010, 01:34 PM   #201
haberkorn
Member#: 97732
2004 STi
65 Nova [email protected]
Make sure those fittings have the olive in them for the Teflon line. If they do not they're just an an hose end which will not work for power-steering applications. That is the correct line for power steering though.
haberkorn is offline   Reply With Quote
Old 08-11-2010, 01:48 PM   #202
Fabry
Member#: 222939
2000 WRX 3
Special Gray
Ok! Very thanks for reply.
So...i thinks they not have the olive....
Fabry is offline   Reply With Quote
Old 08-11-2010, 09:47 PM   #203
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Originally Posted by Fabry View Post
Hello, anyone know if this hose end can be used for power steering line?
http://www.summitracing.com/parts/EAR-807691ERL/
http://www.summitracing.com/parts/EAR-800106ERL/
http://www.summitracing.com/parts/EAR-804606ERL/
And can be use this hose end winth this teflon line?
http://www.summitracing.com/parts/RU...0&autoview=sku
Thanks to All for reply
wrong ends, use the stainless ones with the compression fitting.
scby rex is offline   Reply With Quote
Old 08-12-2010, 10:28 AM   #204
Fabry
Member#: 222939
2000 WRX 3
Special Gray
@ haberkorn & scby rex thankyou mate, You saved me from wasted money
Old 09-17-2010, 08:56 AM   #205
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
3-1/2 years later and its nice to see people are still using my design!
SloRice is offline   Reply With Quote
Old 09-17-2010, 04:44 PM   #206
gtasti
Member#: 152036
2004 Sti
Slorice do yea want to make me one and ship it to canada for me
I'd need one going around the mainfold not under it
gtasti is offline   Reply With Quote
Old 09-20-2010, 08:19 AM   #207
SloRice
Member#: 44351
2004 Mitsubishi Evo
Nope!
Old 10-28-2010, 09:33 PM   #208
devildog12390
Member#: 251000
What's the story on the ImportImage Racing lines? I need new lines and for the same price of building one I might as well buy one already assembled... does it come with everything necessary for install?
thanks.
devildog12390 is offline   Reply With Quote
Old 10-29-2010, 07:22 PM   #209
scby rex
Member#: 104878
02 wrxbastardchild
Id just get the P&L one.
Old 10-30-2010, 11:24 AM   #210
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Dont people still have issues with the P&L stuff?
rexworx is offline   Reply With Quote
Old 11-08-2010, 08:31 AM   #211
flyers7732
Member#: 209901
2007 Sti
i just installed the import image one, ill let u know how it goes when the motor is back in, crossing fingers.........
flyers7732 is offline   Reply With Quote
Old 11-08-2010, 07:50 PM   #212
scby rex
Member#: 104878
02 wrxbastardchild
the old one did but afaik they have a new one thats good. My buddy has one with no complaints.
Old 12-14-2010, 12:10 AM   #213
STIBungy
Member#: 51684
Tired of the constant power steering line leaking, I pulled the P&L line off my car. Low and behold, I went through this thread and realized that they forgot 1 piece in the kit they sent me.
http://www.summitracing.com/parts/EA...0&autoview=sku
I never had this piece to begin with. The stock flared line poked right through the end on the 6AN fitting. Wow! Crap! Fudge! Bull****!
STIBungy is offline   Reply With Quote
Old 12-21-2010, 08:01 PM   #214
STIBungy
Member#: 51684
For those who dont want to make their own line, here's one that's premade:
http://www.summitracing.com/parts/FRA-372024/
And only $30.95
Old 01-01-2011, 12:31 AM   #215
devildog12390
Member#: 251000
Has anyone had any issues with the pre-fab'd p/s lines? I got mine installed and when I'm at an idle I can hear a loud humming sound. No air in my lines and it stops when I turn my steering wheel. It's really just annoying...
Old 05-10-2011, 09:54 PM   #216
tekgnosis
Member#: 76044
2000 RS w/02WRX swap
BRP
I finally got around to pulling out my old rack (which was beyond busted).
Unfortunately, the reman'd rack didn't come with the hardlines that go from the rack, and poke out just above the crossmember.
I could reuse the pressure side line, but not the return line.
Does anyone know what size fitting to use, to plug right in to the rack itself?
Essentially, I need to build part "15" in this picture:
Here's the page if the pic doesn't work: Link to original page with picture
Any help would be hot. I can't think of a local place to take this in to, and have them measure it/give me a line that'll work.
tekgnosis is offline   Reply With Quote
Old 05-11-2011, 03:13 AM   #217
LeoNYC
Member#: 106583
1999 2.5RSTi
I replaced both the high pressure and return with some premade teflon/steel braided lines from summit.
I'm having some trouble with the return line . I have the older style pump with the reservoir that sits on top. I can fit a 3/8 heater hose over the return line nipple on the res but I can't for the life of me slip the 6AN braided line over it.
I thought the ID of 6AN is 3/8? Is the rigidity of the line not allowing it to get on there? I'm thinking of getting a 3/8 hose barb coupler to go from the braided line -> coupler -> 3/8 heater hose -> reservoir nipple. But I'm wondering if the barb coupler will be the same size as the return nipple on the reservoir, leaving me in the same boat.
Any advice is appreciated, and please forgive my mechanical newbness, thanks.
LeoNYC is offline   Reply With Quote
Old 05-28-2011, 05:23 PM   #218
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
I got one of the P&L lines. Do I need to put Teflon tape or something on the fitting that goes between the rack fitting and the SS line down by the up-pipe? I just want to make sure it wont leak.
dexterous is offline   Reply With Quote
Old 05-29-2011, 08:45 AM   #219
STIBungy
Member#: 51684
No, its a compression fitting.
Old 06-01-2011, 02:58 PM   #220
haberkorn
Member#: 97732
2004 STi
The inside diameter on a Pushloc (heater hose) style hose is larger than on a re-usable (steel braid) hose. That's where your having issues. They're not designed to be interchangeable.
Old 08-02-2011, 08:14 PM   #221
dexterous
Member#: 23553
2014 WRX - Daily
This has been installed on my car for most of the summer but I seem to have a pretty good whine in my power steering system. It makes a pretty significant noise while turning and stuff. The system operates perfectly (buttery smooth) but it leaves me wondering if there's air in there. I have driven over 1000 miles so its had plenty of time to self bleed.
Old 08-02-2011, 08:20 PM   #222
95SubieNate
Member#: 289764
99 rs
why? you dont need power steering, you get more hp without it
95SubieNate is offline   Reply With Quote
Old 03-19-2012, 10:21 PM   #223
okiedude
Member#: 37736
2003 WRX Race Wagon
Giving this thread new life.
Any thoughts about this Unisteer -6/14x1.5 Banjo fitting. Could it be used directly on the pump instead of the adapter?
http://www.summitracing.com/parts/UIS-8021550/
okiedude is offline   Reply With Quote
Old 03-20-2012, 08:08 AM   #224
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
Here is my list of parts. $92.74 shipped. Kind of expensive, not much savings over the P&L line and more expensive than the Fast Motorsports line. http://www.importimageracing.com/fas...6-wrx-sti.html
Code:
1	EAR-9894DBHERL - Fitting, Power Fuel Injection Adapter, -6 AN Hose End to 14mm x 1.5 Female, Blue Anodized, Each	$10.99
1	RUS-620411 - Fitting, Hose End, Power Steering, 45 Degree, -6 AN Hose to Female -6 AN, Steel, Nickel Plated, Each	$17.95
1	RUS-620421 - Fitting, Hose End, Power Steering, 90 Degree, -6 AN Hose to Female -6 AN, Steel, Nickel Plated, Each	$15.95
1	RUS-632610 - Hose, Powerflex, Braided Stainless Steel, -6 AN, 6 ft. Length, Each	$32.95
1	RUS-670520 - Fitting, Straight, AN Flare to Metric, Aluminum, -6 AN to 14mm x 1.5 Male, Each	$4.95
NITROS is offline   Reply With Quote
Old 03-30-2012, 12:56 AM   #225
arisking
Member#: 245282
04 JBP STi
Bumpers...thinking about doing this. Anyone else out there have pics of the low pressure/return line setup that isn't stock?
arisking is offline   Reply With Quote
pic of the stock oil feed line ej20 please supernick77 Newbies & FAQs 1 09-08-2009 03:48 AM
How important is the placement of power steering line behind the grill tino Built Motor Discussion 23 06-01-2009 06:26 PM
Does Perrin rotated mount inlet/intake hit power steering lines? garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-03-2006 10:14 AM
short video of the broken Power steering pulley reddevil Normally Aspirated with bolt-on Forced Induction Powertrain 7 01-04-2005 01:50 AM
Any locals with the dreaded power steering line problem? supermarkus North West Impreza Club Forum -- NWIC 6 01-01-2002 10:58 PM
