Old 03-20-2007, 12:52 PM   #1
flatusboy
Member#: 63023
02 WRX
Default Cluster swap
Hey guys,
I know, I know another cluster swap thread. But, I cant find any good info for a non-STi swap...please be gentle.
I will be swapping a 2005 WRX instrument cluster into my 02 WRX very soon (maybe today) and need a little clarification.
I have read tons of threads, all talking about STi cluster swaps. If I ever do swap for an STi one, I think I got that down?
I know that the ABS light will probably stay on (working on a circuit to fix that though), but, is there anything else that I have to do to make the swap work?
Thanks in advance.
flatusboy is offline   Reply With Quote
Old 03-20-2007, 01:47 PM   #2
Force
Member#: 123515
2005 vette c6 z51
LeMans Blue
The guys at my local performance shop said it should bolt right in with no problem. Plug and Play.
Force is offline   Reply With Quote
Old 03-20-2007, 02:05 PM   #3
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
I dout they are the same. . . but not 100% sure . . . They probably have changed just like the 05 STi and up. The change is not much but one plug wont fit. Its not too hard to fix though
http://forums.nasioc.com/forums/show....php?t=1216932
dangerousatom is offline   Reply With Quote
Old 03-20-2007, 03:15 PM   #4
flatusboy
Member#: 63023
02 WRX
Thanks for the replies.
I heard that about the 1 plug that needs to be "shaved". Dont know if thats an STi specific thing though.
Old 03-20-2007, 04:27 PM   #5
azscooby
Member#: 115297
2002 ej207 vf34
I just put an '05 cluster in my -02. It is plug n play, no shaving, no problems. You will have the ABS light on, but you can just tape the back. My cruise light doesn't work, but I think it's a unique case, meaning not the swap, something else going on (the cc still works though.)
The ABS light will be on because they've reversed the polarity (light off when signal, light on when no signal - opposite of earlier models.) I've contacted a couple of electrical places but no one has an answer about how to fix this (cheaply.) -though I'm sure it could be done. Let us know if you find a circuit to fix it.
You need to do stage gels and Mechie3's LED swap, then you'll be coool.
azscooby is offline   Reply With Quote
Old 03-20-2007, 04:42 PM   #6
Mechie3
Member#: 120152
True, blue gauges are cool.
Mechie3 is offline   Reply With Quote
Old 03-20-2007, 04:46 PM   #7
wrxman60
Member#: 75523
yea i kno that the sti cluster from 04 to 05 they made slight changes, so it is most likely there are differences between each year
wrxman60 is offline   Reply With Quote
Old 03-20-2007, 05:12 PM   #8
flatusboy
Member#: 63023
02 WRX
Thanks azscooby!
I'm assuming that the 02-04 ABS circuit has voltage present during normal operation. When it faults, voltage is removed and the light lights.
But, On the 05 +, there is no voltage present during normal operation and it applies voltage when faulted. Or is it reversed? Need to pull out my scope and check it out.
Its just in the "thinking" phase right now, but there must be a relay in the ABS circuit that is either NO or NC. Maybe just put an opposite relay inplace if the existing one? Or add another relay based on the normal condition of the circuit.
It will take some time (low priority), but I hope to get it figured out.
Old 03-20-2007, 06:43 PM   #9
azscooby
Member#: 115297
2002 ej207 vf34
I think it's the opposite, but test to make sure, as I haven't checked it myself.
I know there's got to be something that can do this, is a simple engineering process, I'm just not an engineer. Seems like all you would need is a seperate device/relay to reverse the signal.
I called a few places, but the guys didn't know what I was talking about - but they didn't sound all that bright either.
Let us know what your progress is.
Old 03-20-2007, 08:24 PM   #10
flatusboy
Member#: 63023
02 WRX
Right on. Got the cluster and in plugged right in. (no triming, no cussing, no nothing)
I will update the masses when (if) I find a fix for the ABS.
Thanks all.
Old 03-20-2007, 09:27 PM   #11
Force
Member#: 123515
2005 vette c6 z51
LeMans Blue
Glad to hear it.
I'm gonna do this to my 02' as well.
Definitely let us know when you get a fix for the ABS light
Old 11-12-2007, 01:42 PM   #12
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
anyone have a fix for the ABS light?
djerickd is offline   Reply With Quote
Old 12-06-2007, 09:15 PM   #13
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
will the reverse circuit work for the abs light?
arco is offline   Reply With Quote
Old 01-23-2008, 11:06 PM   #14
simprezl25
Member#: 71647
2002 Bug iD
i am ordering an 05 wrx cluster non sti and i know it will be a plug and play. but about the ABS light, i did a swap from a 02 2.5rs to a 02-03 wrx and the abs light is on and doesnt work....????? is it becuase of the reverse thing? if i get a wrx guage it will not fix the abs and make it work right...?
simprezl25 is offline   Reply With Quote
Old 08-22-2010, 10:12 PM   #15
WhiteNite
Member#: 164857
2005 Wrx - Sti
I realize im waking the dead here but if I can get an answer in this thread it would be useful to someone else in the future.
My bro just bought an 02 WRX Wagon. He would like to have the tach in the center of the gauge cluster as well. I see that in the 05 wrx a cluster swap is doable but the ABS light will be ON, if he swapped in a 04 WRX cluster that had the tach in the center, would the ABS light be on just like the 05?
WhiteNite is offline   Reply With Quote
Old 08-22-2010, 10:27 PM   #16
subaru3169
Member#: 55252
* pullup bar *
no, 04 will be plug and play with everything working like normal
subaru3169 is offline   Reply With Quote
06 wrx cluster swap to the 06 sti cluster problems... knighter Electrical & Lighting 1 10-07-2009 09:14 PM
STi cluster swap to OEM wrx cluster JustAnotherSubie Newbies & FAQs 2 09-08-2008 04:17 PM
cluster swap - 03 -> sti or jdm v7 cluster djcttb Interior & Exterior Modification 4 02-08-2006 05:08 PM
New STi cluster swap Leonardo Interior & Exterior Modification 60 12-07-2002 04:40 PM
gauge cluster swap? hairband Interior & Exterior Modification 0 08-28-2002 11:24 PM
