Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 03-20-2007, 07:19 PM   #1
panman91
Member#: 37524
Platinum Silver Metallic
Question NEED HELP!! Weird sound from turbo when letting off gas. VIDEO INCLUDED
Just for some background my car is a 2002 wrx with tuboxs TBE and a PDE uppipe. listen to this clip and tell what you guys think this could be. I don't think its the heatshield because when i hold down the heatshield the sound still resonates.
Click Here for Video
panman91 is offline   Reply With Quote
Old 03-20-2007, 07:39 PM   #2
thosepeople
Member#: 133104
2002 silver WRX
oh yes 4:11 gears
It sounds to me like you have some serious shaft play or your bearings are gone and you probably need to replace your turbo or atleast have it rebuilt.
I am not an expert, but that is my 2 cents.
thosepeople is offline   Reply With Quote
Old 03-20-2007, 08:22 PM   #3
Cation
Member#: 88779
00 E55 AMG
That sounds like a heat shield rattle. Do you still have the heat shield installed under the turbo? The one that used to bolt to part of the DP near your Up Pipe? Maybe it is rattling on something. Doesn't sound internal to me, but I've never heard what a turbo sounds like with excessive shaft play or bad bearings. From what I've read though excessive shaft play results in a whistling sound from the turbo not a rattle like you have. Have you noticed any loss in power/performance or are you just getting that sound? If you are getting a loss in power/performance then I would venture to guess that your turbo is going out. Get under the car and have a listen, maybe you can isolate it there. Good luck and keep us posted with what you find!
Cation is offline   Reply With Quote
Old 03-27-2007, 04:18 PM   #4
panman91
Member#: 37524
anyone else want to shed some light on this.
I took it to the dealer and they said they couldnt do anything unless they took it apart. they its not a heatshield rattle but possible something inside between the turbo and downpipe. maybe the gasket or the shaft play with the fins on the turbo. what do you guys think?
Old 03-27-2007, 07:53 PM   #5
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
just take the heatshield off and drive it to narrow the variables if you feel it may be that. if your turbo is broken well thats an easy fix just get a new one! i wouldnt spend the money to buy a new stock one through the dealer though..
PaulRex is offline   Reply With Quote
Old 03-27-2007, 08:43 PM   #6
deebee8
Member#: 85437
2002 Wrx
Land of the dead
it sounds like the compresser wheel is slapping the hell out of the housing =(
how does it run under boost?
deebee8 is offline   Reply With Quote
Old 03-27-2007, 09:45 PM   #7
boozy04
Member#: 87034
08 Stg2 9.5's 275s
SSM
wow that sounds awful... i would agree with the need of a new turbo.
boozy04 is offline   Reply With Quote
Old 03-27-2007, 09:54 PM   #8
Force
Member#: 123515
2005 vette c6 z51
LeMans Blue
Yes, like the others have said:
If not the heat shield....
bad bearings--->excessive shaft-play--->turbine and/or compressor blades scraping against the housing.
Force is offline   Reply With Quote
Old 03-27-2007, 10:21 PM   #9
Luckie8
Member#: 105240
04 Wingless STi
mk2 vr6
yeah.. I highly doubt that's the heatshield making that noise. But just to be sure I would take that shield off and drive without it to see what happens.
Gluck.
Luckie8 is offline   Reply With Quote
Old 03-28-2007, 10:15 AM   #10
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
It doesn't really sound like the compressor is hitting the housing. I have had turbos blow on me in the past and they have never made that noise. I would take your downpipe off and see if you have a lot of shaft play on the turbo. That will tell you right off if that is the problem.
tony
Old 03-28-2007, 10:21 AM   #11
Force
Member#: 123515
2005 vette c6 z51
LeMans Blue
^^Yeah, same here. Usually, the sound of the blades hitting the housing will sound more like an electric jigsaw cutting through plastic or something like that. (At least thats what my old 16G sounded like when it happened)
His video doesn't sound too much like that, but ya never know.
Old 03-28-2007, 12:54 PM   #12
Bbasso
Member#: 66235
2005 WRX
Dammmmmmmmmm that sounds bad!
Sorry I have nothing usefull to add :|
Bbasso is offline   Reply With Quote
Old 03-28-2007, 03:06 PM   #13
illsuby
Member#: 72635
03 WRX
Wink
I had my heatshield make a VERY VERY similar noise. I also did the same thing, put some gloves on, put pressure on the shield and had someone work the throttle, still rattled. The dealership told me it was "okay" to run without the heatshield, but it woudl be recommended to find an aftermarket. Their reason for the sound was that some parts that bold to the stock up pipe, and those were missing when I swapped it out for my Vishnu.
My easy answer for you is take the heat shield off, it's only a few bolts. Drive it, if its still happening, it's not the heat shield. Cobb makes a dandy replacement for about $50.
illsuby is offline   Reply With Quote
Old 03-28-2007, 03:10 PM   #14
amukaoen
Member#: 62595
04 WRX Cobb S2
World Rally Blue
So in your case it was the heatsheild that made that noise?
amukaoen is offline   Reply With Quote
Old 03-28-2007, 03:23 PM   #15
illsuby
Member#: 72635
03 WRX
Yes it was. I took it to two dealers, my personal mechanic, and had a few gearheads I know take a peek, and they couldn't find it. The second time around, the dealer I bought it from took off all expendable heat shields, the rattle stopped, and they just added them back one by one until it started again, and it was the turbo heatshield. I haven't replaced it yet, and it's been seemingly fine. Been about 8 months now.
Old 03-28-2007, 03:50 PM   #16
illsuby
Member#: 72635
03 WRX
Just to verify, it happens on decel only, between 3,500ish and 2,200ish RPMs? I ask because those were the circumstances of my rattle. It may not have been that whole band, but it was definitely always in there.
Old 03-28-2007, 04:40 PM   #17
panman91
Member#: 37524
Yes. only when i let off the throttle.
Old 03-28-2007, 04:47 PM   #18
illsuby
Member#: 72635
03 WRX
Yeah, my vote then is the heatshield. Three bolts I think and it's off. Please post after you try it without the shield, I'm curious to see the results.
Old 03-28-2007, 05:59 PM   #19
panman91
Member#: 37524
It is sooo not the heatshield....took it off and it does the same exact thing. i'm leaning towards shaft play in the turbo. i noticed while driving that it only makes noise once vacuum pressure based off the stock turbo gauge is in the 4 o'clock position. if i just give it a little gas until the gauge is at the 6 o'clock position the noise disappears. while driving, medium to light throttle you can hear the rattle coming in and out based on how much the turbo is spinning. i have been driving like this for a while now.
I was gonna ask what is normal vacuum pressure supposed to be when you let off throttle?
Old 03-28-2007, 06:09 PM   #20
illsuby
Member#: 72635
03 WRX
No prob on the heatshield, it was worth a shot. My stock boost guage will have the vaccum pressure at about (what would be) -.4 (about 6:30 or 7 oclock on the guage), which i think converts to about -6 PSI, but I may be way off on the math. n00b(ish) at work here. I can't say I've seen my boost guage get to the 4 oclock position...i think that's really bad.
Old 03-28-2007, 07:09 PM   #21
Gethin
Member#: 2998
check the flapper, is your WG working properly?
Gethin is offline   Reply With Quote
Old 03-28-2007, 09:40 PM   #22
panman91
Member#: 37524
how do you check that?
Old 03-29-2007, 05:06 PM   #23
cspangler6
Member#: 122803
2004 Subaru
If you need a new turbo look on ebay. you can find one for like 100 bucks or less and its probably an easy install ( or at least cheap to get installed)
cspangler6 is offline   Reply With Quote
Old 03-29-2007, 07:22 PM   #24
awdguy
Member#: 59101
2004 wrx
white
Let just say......It's F@#k up.
awdguy is offline   Reply With Quote
Old 03-29-2007, 07:42 PM   #25
Assassin4457
Member#: 96773
04 WRX, RIP GC8
*Withdrew my post*
Assassin4457 is offline   Reply With Quote
Car shakes violently when letting off gas at 5k rpms? Help... ImportVenom Transmission (AT/MT) & Driveline 9 10-21-2011 06:16 AM
Smoke out bov when let off gas????? EklipzGSXkid Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 23 08-05-2008 12:38 AM
Weird sound from turbo? Eyefixstuff Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 08-30-2007 07:00 PM
Metallic noise when letting off gas _JsWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 01-16-2007 01:20 PM
weird sound from turbo area under boost OneArmedScissor Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-02-2003 03:29 AM
