Old 03-21-2007, 11:59 AM   #1
nxwrxfx
Member#: 92011
02 EJ207 STi HTA68
05 EJ257 Baja 18G-XT
Default Need some Wiring Help: OEM Fog Light Switch & Aux. Lights!
Hey guys,
I need some wiring help.
I'm installing a lightbar and four Hella 500's soon onto my 2002 WRX sedan very soon.
I managed to pick up an OEM fog light switch that I want to use to engage my four Hella 500's regardless of whether my main lights and OEM foglights are on/off.
How would I do about doing this?
I realize that I'm going to have to wire the Hella's straight to the battery, use relays, etc. but it's been awhile since I've done major wiring so I want to make sure I'm doing the job right before I start installing it all.
At the moment, I do NOT have relays with the Hella lights as I got them second hand. So what type of relay should be the minimum to use for this application? And should I have one relay per pair of lights or can I have all four lights on a single relay?
Also, does anyone have the pin-out diagram for a 2002-2003 OEM foglight switch?
Any pointers are welcome!
I'm not a beginner at wiring, and i've wired up Hella horns, a Pivot water spray controller, and a car audio system before to give you some examples of the work that I'm familiar with.
Thanks!
nxwrxfx is offline   Reply With Quote
Old 03-21-2007, 12:43 PM   #2
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Pair of relays, each one running to 2 hellas, wired to the switch? The relays I usually see are rated for 30A, you may be able to run all four on one relay on that.
Hook up the switch to an illum wire, like the cig light, or a parking light wire coming from the stalk.
rougeben83 is offline   Reply With Quote
Old 03-23-2007, 04:09 PM   #3
cMags
Member#: 88668
'05 Outback Sport
5MT - Regal Blue / Grey
Outback Sport
This relay should be more than sufficient, and this site has great prices and service:
http://www.delcity.net/delcity/servl...d=73576&page=1
They also have relay sockets wired or not wired so you don't have to put female spade connectors on and mix up wires.
As far as the OEM switch goes, from memory there's two wires that actually make the connection for the switch (one you'll tap from swtiched-with-lights +12V, the other will go to the relay), two are for illumination, and one is ground for the two illumination wires. I've got to do the same thing soon, so if I can find my switch, I'll post about it. Otherwise, grab a multimeter and go for it!
Edit: Here we go - thought I had written this up at some point:
http://forums.nasioc.com/forums/show...ght=fog+switch
cMags is offline   Reply With Quote
Old 03-23-2007, 08:35 PM   #4
nxwrxfx
Member#: 92011
02 EJ207 STi HTA68
Thanks cMags!!
And d'uh... lol... i have a multimeter, but for some reason that didn't hit me until just now... STUPID MOMENT!
Thanks for that website link too, looks like that'll help a ton!
WTB oem fog light switch & 06-07 fog light brackets knighter MAIC Private Classifieds 16 03-14-2009 01:26 AM
WANTED:fog light switch & interior rear deck coach_emile Private 'Wanted' Classifieds 0 05-02-2007 01:09 AM
Need some electrical help: I want to add footwell lighting paultg Interior & Exterior Modification 21 03-21-2007 10:21 PM
using stock fog switch for aux lights PARANOID56 Electrical & Lighting 2 05-08-2003 12:21 AM
Need some quick help: Need to borrow a set of stock rims w/ tires and stock exhaust Tony Mid Atlantic Impreza Club -- MAIC 18 10-17-2002 11:11 AM
