Old 03-21-2007, 06:09 PM   #1
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
Default Fuel level sensor wiring
Hey guys i have searches around and have yet to see what i need maybe you guys know where to find it or know your selves.
I just installed a fuel cell in my 2006 WRX and it has a 0-90ohm level sensor in it and I just want to find out which wires i need to tap into to make the factory fuel guage work on the new leveler? catch what im asking?
Kris
Chp_Stix is offline   Reply With Quote
Old 03-22-2007, 12:27 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
You just need to tie into the two wires that go back to the gauge. The connector should be under the rear seat on the pass. side. The stock float resistances equal up to roughly 90 when empty.
Legacy777 is offline   Reply With Quote
Old 03-22-2007, 05:39 PM   #3
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
can i go from the pump at all?
Old 03-23-2007, 12:09 PM   #4
Legacy777
Member#: 4800
I'm not sure what you're asking. I believe in the newer models, the pump & fuel sender level wiring is separated into different connectors under the rear seat. However they should be right next to each other.
Old 03-24-2007, 11:30 PM   #5
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
no there is just a 6 pin plug there that is all.... hmmm
Old 03-27-2007, 12:26 PM   #6
Legacy777
Member#: 4800
Ok.....then all the wiring for the tank & senders are in that plug. Unfortunately I don't have a wiring diagram for the newer cars. Hopefully someone else can help you out.
Josh
Fuel level sensor? lord1234 Service & Maintenance 0 09-22-2008 07:35 AM
WTB: Fuel Level Sensors RuskiiWRX02 NESIC Private Classifieds 1 10-21-2007 05:12 PM
Engunity logger: Can find ability to log fuel level sensor output. DoctorNick Commercial ECU Reflashes 8 04-26-2007 02:49 PM
Wanted: Fuel sending unit/fuel level sensor 05+ DJIMPREZA Private 'Wanted' Classifieds 0 04-08-2007 10:21 AM
fuel level sensor values silvialost Subaru Conversions 1 10-30-2005 09:31 PM
