Welcome to the North American Subaru Impreza Owners Club Saturday August 1, 2015
Old 03-21-2007, 10:53 PM   #1
BLK REX
Member#: 102673
2000 Legacy GT LTD
Default Stock 04-05 Headlights Questions.
Im building a Relay Harness for a friend and need a few bits of information in order to do it right.
1. Just to confirm, Low Beams are H1 and High Beams are 9005?
2. With the Low beams on, when you pull the light stalk towards the driver to flash the high beams, do the lows stay on?
3. With the Low Beams on, when you push the light stalk away from the driver to keep the high beams on, do the lows stay on?
4. With the Low Beams off, when you pull the light stalk towards the driver to "flash to pass", do the highs come on by themselves, or do the lows come on too?
Thanks guys.
BLK REX is offline   Reply With Quote
Old 03-22-2007, 12:59 PM   #2
12sechatch
Member#: 132458
Okie Dokie Fine
1. yes
2. yes (fogs go off though, if that matters)
3. yes (fogs go off though, if that matters)
4. hmmmmm....i don't know i'll check later today, i believe that they both are on because of the DRLs. but i don't know if the lows are full voltage or if they stay at DRL voltage
12sechatch is offline   Reply With Quote
Old 03-26-2007, 01:05 PM   #3
RickDaTuner
Member#: 28806
05 STi
with the low beams off when you Flash to pass on a WRX or STi, no lights come on
RickDaTuner is offline   Reply With Quote
FS: Rota rims, stock turbo, stock uppipe, 52mm gauge, stock 04-05 headlights spyda23 Engine/Power/Exhaust 9 10-25-2008 10:26 PM
FS: Rota rims, stock turbo, stock uppipe, 52mm gauge, stock 04-05 headlights spyda23 Tri-State Area Private Classifieds 5 08-26-2008 05:08 PM
CF 04/05 Headlight question Twiztidunreal Interior & Exterior Modification 4 07-28-2008 11:30 AM
How to tell difference between 04/05 STI HID headlights from regular 04/05 headlight Cyclonus Newbies & FAQs 13 04-04-2008 04:38 AM
04-05 headlight question ADAS1223 Electrical & Lighting 4 03-02-2008 12:40 PM
