Old 03-17-2009, 07:27 PM   #601
surfer5567
Member#: 61199
2002 wrx wagon
wrb, s2, blouch 2.5, 6spd
Originally Posted by srREXed View Post
The only thing reverse is good for is looks and a bit less piping. Honestly, there has been flow tests proving that flipping the manifold does not yield better spool up enough to go through the trouble of a custome bracket and belt and all that... my .02 is unless you are doing it for the ' being different aspect' dont bother homie.
no only reason was for quicker spool. i ultimately want to go to a twinscroll 35r w/meth and want it to spool like my polka pickle...at least close to it haha
surfer5567 is offline   Reply With Quote
Old 03-22-2009, 01:46 PM   #602
FATCanuck
Member#: 142534
What do you guys think would be the appropiate setup for a custom IM on a 06 STi with a 4088? the only catch is that bottom end is not a big deal , as I have a supercharger as well . So should i go with a shorter runner (like 7-8inch) and keep the top end power freed up as much as possible ? We plan on using velocity stacks inside the plenum or plenums. was considering the twin plenum with cross connection to balance air press/flow.
Lastly , anybody have a bigger throttle body soloution to the drive by wire tb's? not really interested in going to cable.
FATCanuck is offline   Reply With Quote
Old 03-23-2009, 09:45 AM   #603
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
if you only care about top end, target you manifold runner lengths for it and use a large plenum. Since we have no clue about your setup or what your flowrate will be, can't really say what is an appropriate size for the plenum.
For the TB question; bore and make new butterfly?...
Old 03-23-2009, 08:55 PM   #604
FATCanuck
Member#: 142534
Do you know of/have you done a bored DBW TB? Very interested .
As for flow , the super charger is quite large . designed for the AMG C32 Benz . not sure of the specs, ill get em though. as well as the exact trim on the hair dryer .
Old 03-24-2009, 10:02 AM   #605
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
Point in case: It will not increase your spool noticeably. If you want your spool another 150rpm sooner and spend a whole lot of time and a bit of money to do it, I applaud you. Post pics when youre done! BTW, twinscroll FTW! I think you need to ditch the 6mt and go 5spd ppg... Instead of concentrating on spooling sooner/faster, you could just stay in boost longer and it will be overall better power to ground!
srREXed is offline   Reply With Quote
Old 03-27-2009, 03:34 PM   #606
BigRigger
Member#: 129969
2005 Sti
Silver/Black
This is a cool setup, but I dont know about the unequal length intake runners.
BigRigger is offline   Reply With Quote
Old 03-27-2009, 03:53 PM   #607
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Moar pics!
wcbjr is offline   Reply With Quote
Old 03-28-2009, 10:25 AM   #608
leoimpreza
Member#: 197989
2002 Impreza WRX STI
WR Blue
leoimpreza is offline   Reply With Quote
Old 03-28-2009, 10:56 AM   #609
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Can you post more details on this???
jigga is offline   Reply With Quote
Old 03-30-2009, 06:03 PM   #610
hanzo918
Member#: 82148
1992 Daihatsu
Charade
Any chance of using TMIC w/ the Cosworth intake manifold?
hanzo918 is offline   Reply With Quote
Old 03-30-2009, 06:28 PM   #611
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Only if you make some sort of brakets to hold it, but whats the point of using a large volume manifold with a pos tmic? If your not flowing enough air to max your stock manifold and are using a tmic why waste the money on one?
scby rex is offline   Reply With Quote
Old 03-30-2009, 06:37 PM   #612
ScorpionT
Member#: 195677
+1
A top mount just wouldnt do the Cosworth any justice.
ScorpionT is offline   Reply With Quote
Old 03-30-2009, 08:05 PM   #613
BigRigger
Member#: 129969
2005 Sti
Silver/Black
Nope sorry, that was a random pic I found, no details at all.
Old 03-30-2009, 10:23 PM   #614
hanzo918
Member#: 82148
1992 Daihatsu
Charade
Originally Posted by ScorpionT View Post
+1
Srsly, guys, srsly?
Old 03-31-2009, 11:50 AM   #615
Big_DeWeY
Member#: 37078
95 L
Blue-ish
+1
Do you REALLY know what your saying here? Honestly.
Big_DeWeY is offline   Reply With Quote
Old 03-31-2009, 04:57 PM   #616
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
According to Cosworth, a TMIC in theory technically could fit with the manifold. In reality though, the location of the BOV/BPV on the TMIC is right where the rear runner on the driver's side of the manifold goes...
So while in theory, yes, in the real world, umm... no... unless of course you don't mind running without a BOV or BPV on the car... You kinda need to have a FMIC sadly.
Old 04-01-2009, 04:48 PM   #617
BallPeenHamr
Member#: 126526
2007 STi Limited
#339 UGM -SOLD
^^ or you could relocate the BOV/BPV to anywhere it could fit- as long as it's somewhere between the turbo and throttle body... and it's plumbed in correctly of course. It would def be a custom project though.
BallPeenHamr is offline   Reply With Quote
Old 04-01-2009, 04:52 PM   #618
wgknestrick
Member#: 32576
04 STI
More info on this build. Those are ITBs bolted to the plenum.
wgknestrick is offline   Reply With Quote
Old 04-01-2009, 07:52 PM   #619
hanzo918
Member#: 82148
1992 Daihatsu
Charade
so it's only the BPV that's getting in the way... that should be easily remedied...
Old 04-15-2009, 08:36 PM   #620
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Okies, just picked up the intake manifold. This thing's runners are HUGE!!! The manifold is also very light for how big it is!!! Of course it's a BARE manifold... but... very nice. They deburred a lot of the casting edges so you won't get cut, but you can still in some spots. Running this manifold requires a FMIC setup.
Unless you want to buy this one...
http://www.xcceleration.com/itemdeta...tm#xccelintake
Also we have these fancy seats at our Dealership! I love sitting in them every time I'm there!!
FuJi K is online now   Reply With Quote
Old 04-15-2009, 09:25 PM   #621
STI_KLR
Member#: 189660
'02 WRX
Element Tuning Race Team
^^^I want one of those seats. Now.
STI_KLR is offline   Reply With Quote
Old 04-15-2009, 10:30 PM   #622
bjm
Member#: 87090
Does that manifold bolt straight onto stock TGV?
bjm is offline   Reply With Quote
Old 04-16-2009, 12:45 AM   #623
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Mine looks exactly like this one. Except that he grind off a few of the mounting points.
Old 04-27-2009, 05:43 PM   #624
subie12345
Member#: 132783
2003 wrx 480 whp
08 silverado 98 ek
Originally Posted by leoimpreza View Post
Forsa Intake Manifold
hahah the one on the carpet is mine in my bed room
installed
subie12345 is offline   Reply With Quote
Old 05-21-2009, 10:26 AM   #625
leoimpreza
Member#: 197989
WR Blue
Zen Performance time attack w/ Cosworth intake manifold
More here: http://team-zen.co.uk/blog/
WTB: Polished or Aftermarket intake manifold midnightsti Private 'Wanted' Classifieds 4 06-13-2006 06:39 PM
Aftermarket intake manifold west005 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 05-30-2006 09:03 PM
Aftermarket Intake Manifolds WRXRallyBlue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 10-03-2005 08:11 PM
New/Aftermarket Intake manifold Twelvz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 03-11-2005 12:32 PM
New Aftermarket Intake Manifold DonkeyPunch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 01-15-2005 06:15 PM
