Old 02-16-2010, 04:04 PM   #801
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Originally Posted by MartinSTi05 View Post
Dual pass intercooler?
Either that or no-pass intercooler.
BAN SUVS is offline   Reply With Quote
Old 02-16-2010, 04:45 PM   #802
wgknestrick
Member#: 32576
04 STI
Originally Posted by leoimpreza View Post
Not to start an E fight, just giving suggestions. What works with cooling systems turns into the worst flowing intercooler you could've made for your car.
There is nothing good about that end tank design for your otherwise awesome setup.
wgknestrick is offline   Reply With Quote
Old 02-16-2010, 05:10 PM   #803
TheMadScientist
Member#: 23717
2005 Big red
Does it even cool? Looks like inlet and outlet is on the same endtank.
TheMadScientist is offline   Reply With Quote
Old 02-16-2010, 05:20 PM   #804
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Normally a setup like that has a divider wall inside the top end-tank between the inlet and outlet. The air has to go down through the core, make a u-turn in the bottom end-tank, and then come up the other side.
CKxx is offline   Reply With Quote
Old 02-21-2010, 03:02 PM   #805
leoimpreza
Member#: 197989
2002 Impreza WRX STI
WR Blue
leoimpreza is offline   Reply With Quote
Old 03-09-2010, 11:42 AM   #806
25rsti
Member#: 166324
if you use this intake mani, what are you supposed to do using the wrx dbc throttle body? you can clearly see its not right
Old 03-09-2010, 05:29 PM   #807
25rsti
Member#: 166324
anyone?
Old 03-09-2010, 05:46 PM   #808
CKxx
Member#: 33458
93 RX7+09 Forester
Originally Posted by 25rsti View Post
anyone?
It isn't an easy process. I had the "backing" built up with weld, and then machined flat so that I could mount my DBW TB.
Old 03-09-2010, 11:19 PM   #809
Brydon
Member#: 107569
1998 Forester S
SRP
anyone?
I built an aluminum plate between mine and it seems to run great. I of course also had to make a throttle holder.
Brydon is offline   Reply With Quote
Old 03-10-2010, 04:45 PM   #810
25rsti
Member#: 166324
hmmm...interesting. scary but interesting.
has anyone used or looked into the sohc long runner intake manifolds of older years, ie 99???
Old 03-11-2010, 12:15 PM   #811
Bob the fabricator
Member#: 104246
Not a big deal, I've prepped about 10 of each over the years (DBC and DBW). For the DBC, I welded and redrilled the intake to the correct pattern, and made a phenolic spacer to block the coolant passage that inevitably is exposed on the TB.
Bob the fabricator is offline   Reply With Quote
Old 03-11-2010, 02:22 PM   #812
25rsti
Member#: 166324
oh man! i wish you had some more in depth pictures, or step by step stuff. good work either way
Old 03-12-2010, 12:02 PM   #813
Bob the fabricator
Member#: 104246
I have a few more pics of other intakes I've prepped on flickr, but nothing up close at the mounting flange.
Old 03-19-2010, 12:32 AM   #814
sick1.8t
Member#: 22345
2003 RSX
black
yeah the adapter plate is the easiest method. make sure you make provisions for the idle valve.
sick1.8t is offline   Reply With Quote
Old 03-19-2010, 06:26 PM   #815
25rsti
Member#: 166324
easy huh, doesnt look it. the flange on that mani is smaller than the throttle body it self
Old 07-30-2010, 02:11 AM   #816
Kosmic
Member#: 99140
GD Racing chassis
Slowly in construction
Kosmic is offline   Reply With Quote
Old 08-08-2010, 10:50 AM   #817
Kosmic
Member#: 99140
GD Racing chassis
I'm wondering how much gain you get using velocity stacks vs none in a forced induction IM setup?
Old 08-11-2010, 12:34 PM   #818
Kosmic
Member#: 99140
GD Racing chassis
Another Q
Runner length start from back face of the intake valve all the way to the opposite wall facing velocity stack?
For a good wave rebound, must the runners be stagered? so that the wave hit the opposite wall...not the other side velocity stack?
Noobish!!
Thanks for the help.
Old 08-11-2010, 12:50 PM   #819
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
yup, you measure runner length from the source of the wave face....thus the valve.
the return wave comes from the plenum...pressure differences. Now you have sound and pressure waves to think of in this case.
speedtalk forums and fsae forums would be some good reading for you. Really, you have a lot of reading to do and I don't want to do a lot of typing
Hopefully I'll get some money coming in soon to FINALLY build a manifold. Something I've been wanting to do on a subie for a long time.
One mistake you will commonly see on subaru designed manifolds where they run a dual plenum is that they have two intake strokes back to back on the same plenum. Now I know that it is done sometimes in light of other trade offs BUT it isn't desirable from a design stand point. You have less time to charge the plenum or see it as a greater pressure drop in the plenum. To fight this, you'd have to make a large plenum that would in effect hinder other aspects of plenum performance.
Old 08-12-2010, 12:08 AM   #820
Kosmic
Member#: 99140
GD Racing chassis
Thanks Micah for directing me into those forums. I don't mind reading....good stuff!
Old 08-12-2010, 12:21 PM   #821
Homemade WRX
Member#: 33782
96 bastard child
IIRC there was a site (grapeaperacing or something like that) that had a good, basic read on helmholtz tuning.
Old 08-12-2010, 01:29 PM   #822
Kosmic
Member#: 99140
GD Racing chassis
Yep, I printed that .pdf
http://www.grapeaperacing.com/tech/inductionsystems.pdf
I came to 15.48" for the runners length (2.250" ID) on a 280 Crower cams 6000RPM tuning - 3rd wave.
2.5l plenum (single) volume on a 2.35l 22T stroker sounds good?
Thx
Old 02-19-2011, 02:29 AM   #823
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
I know this looks like another Magnus ebay copy and it is a pos one at that. Pics taken down due to waste of bandwidth. Thanks for informing, bjm. Don't waste your money with this one. Link left on to remind everyone to stay away from this one.
link:Ebay auction Demon Motorsports intake manifold
methaddict is offline   Reply With Quote
Old 02-19-2011, 04:05 AM   #824
bjm
Member#: 87090
It's a cheap POS manifold that looks great in photos but not so hot in person.
I have one which is identical. It does not delete the TGV, it sits on top of them. If you notice there are no injectors bosses on the runners.
The runners are too small and where they enter the plenum they are just cut of straight. There has been no attempt to improve flow with bellmouths or even blending them into the wall of the plenum.
I had this when I made the decision to have my stock manifold because I thought I could get better flow out of it.
Here's the pictures of mine
bjm is offline   Reply With Quote
Old 02-19-2011, 05:10 AM   #825
Bohemian_Funk
Member#: 171218
1999 Impreza 2.5RS
"Silverthorn Metallic"
Good lord, who made that manifold? Personally, I would save the $400 for that pile of crap and just get the stock manifold extrude-honed, then take a dremel to it and the heads. Cleaning up the ports a little bit and port matching the manifold should be more than enough for whatever you're trying to do, really. At least, that's what I'd have to say if you're looking at intake manifolds on eBay. That one looks like they took an old muffler, and added some pre-bent tubes and flanges to it. That "divider" is useless, btw. If it was honestly something that actually did anything (especially for a turbo motor), Cosworth would have done it years ago.
To be honest, if you're really running a twinscroll 8364 setup (please tell me you went external wastegate), I would just drop the $1200 on the Cosworth manifold. I really hope you've taken care of everything else, though (oil system, fuel system, exhaust, valvetrain, engine block, fuel/spark management, boost management, drivetrain, drivetrain, brakes, etc.). Remember, you get what you pay for; paying less for sub-quality parts leads to paying for a metric a**ton of repairs later. For example, if you bought that manifold, under full racing conditions I could fairly easily see that little "air divider" shearing off and suddenly becoming one with your intake tract.
Bohemian_Funk is offline   Reply With Quote
WTB: Polished or Aftermarket intake manifold midnightsti Private 'Wanted' Classifieds 4 06-13-2006 06:39 PM
Aftermarket intake manifold west005 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 05-30-2006 09:03 PM
Aftermarket Intake Manifolds WRXRallyBlue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 10-03-2005 08:11 PM
New/Aftermarket Intake manifold Twelvz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 03-11-2005 12:32 PM
New Aftermarket Intake Manifold DonkeyPunch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 01-15-2005 06:15 PM
