Old 02-19-2011, 05:45 AM   #826
kimokalihi
Member#: 186972
91 Legacy SS EJ20G
Pearl White
Originally Posted by TheMadScientist View Post
This is what is going on my car. You need to use a FMIC and DBW throttle, and a little bit of work to use it. But I don't care I really like the way it looks, and it is an OEM part.
TMS
From what engine/car/year?
kimokalihi is offline   Reply With Quote
Old 02-19-2011, 05:58 AM   #827
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Originally Posted by methaddict View Post
I know this looks like another Magnus ebay copy and it is a pos one at that. Pics taken down due to waste of bandwidth. Thanks for informing, bjm. Don't waste your money with this one. Link left on to remind everyone to stay away from this one.
link:Ebay auction Demon Motorsports intake manifold
Originally Posted by bjm View Post
It's a cheap POS manifold that looks great in photos but not so hot in person.
I have one which is identical. It does not delete the TGV, it sits on top of them. If you notice there are no injectors bosses on the runners.
The runners are too small and where they enter the plenum they are just cut of straight. There has been no attempt to improve flow with bellmouths or even blending them into the wall of the plenum.
I had this when I made the decision to have my stock manifold because I thought I could get better flow out of it.
Here's the pictures of mine
Originally Posted by Bohemian_Funk View Post
Good lord, who made that manifold? Personally, I would save the $400 for that pile of crap and just get the stock manifold extrude-honed, then take a dremel to it and the heads. Cleaning up the ports a little bit and port matching the manifold should be more than enough for whatever you're trying to do, really. At least, that's what I'd have to say if you're looking at intake manifolds on eBay. That one looks like they took an old muffler, and added some pre-bent tubes and flanges to it. That "divider" is useless, btw. If it was honestly something that actually did anything (especially for a turbo motor), Cosworth would have done it years ago.
To be honest, if you're really running a twinscroll 8364 setup (please tell me you went external wastegate), I would just drop the $1200 on the Cosworth manifold. I really hope you've taken care of everything else, though (oil system, fuel system, exhaust, valvetrain, engine block, fuel/spark management, boost management, drivetrain, drivetrain, brakes, etc.). Remember, you get what you pay for; paying less for sub-quality parts leads to paying for a metric a**ton of repairs later. For example, if you bought that manifold, under full racing conditions I could fairly easily see that little "air divider" shearing off and suddenly becoming one with your intake tract.
I'm with these guys, my boss has one on the shelf in the shop. It's garbage.
BAN SUVS is offline   Reply With Quote
Old 02-19-2011, 06:13 AM   #828
Bohemian_Funk
Member#: 171218
1999 Impreza 2.5RS
"Silverthorn Metallic"
kimokalihi - It looks like it's out of the newer Impreza's; 08+ I believe. Mind you, it's made for N/A EJ253 engines, not a turbo motor. I can't say anything for the flow numbers, or how much boost it can hold, but I seem to recall the runner length/diameter is, well... it certainly isn't ideal. I suspect that depending on what boost level you plan to run, it could help in some areas, but hurt in others.
A little off topic: Nice that you're running an EJ20G... what did you do with your EJ22? If you still have it, I might have a happy home for it . Also, are you a member of SL-i.net? If not, you should be!
Bohemian_Funk is offline   Reply With Quote
Old 02-19-2011, 08:03 AM   #829
kimokalihi
Member#: 186972
91 Legacy SS EJ20G
Pearl White
Thanks for the info. I blew the ej20g after 3K miles. I have a thread in the built motor section about what my options are to replace it. Engine was knocking and blew the piston rings in cylinder number 2. The EJ22T was not included in the sale of the car when I bought it. Sorry.
Should I be a member of SLI? I think I am but I don't post on there because it's all newer gen legacy guys so I spend 90% of my time on legacycentral.
Old 02-19-2011, 03:37 PM   #830
Bohemian_Funk
Member#: 171218
1999 Impreza 2.5RS
Ah, that's too bad (about both engines). Last I was there (used to have a '95 BK chassis wagon) it was mostly older Legacy's, but I suppose it could have changed since then. Mostly second and third gen, but there's definitely first gen-ers on there. I must admit I never really spent much time over at LegacyCentral, so I don't know it very well. My opinion is that at least you're a member of a Legacy-specific forum.
I would suggest replying via PM on this one: What's the shape of the EJ20G in as far as the cylinder walls are concerned?
Old 02-19-2011, 07:43 PM   #831
R1Z4T
Member#: 176105
1912 Alco
Red
Whats wrong with the internal WG TS (assuming youre refering to the EFR8374) ?
R1Z4T is offline   Reply With Quote
Old 02-19-2011, 08:41 PM   #832
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
I did go with ewg BW EFR 8374. As for the intake manifold, I just thought it was another option for an intake manifold. I would have gotten the Cosworth if it was a design that deleted the tgvs. I am actually using a 2.5i manifold modified by Outfront motorsports. I had Jeremy weld bosses for Hydramist meth injectors on each runner:
Don't worry, it's taken care of.
methaddict is online now   Reply With Quote
Old 02-19-2011, 09:37 PM   #833
Bohemian_Funk
Member#: 171218
1999 Impreza 2.5RS
Excellent, guess I'll have to check out your build thread. Are you using standalone engine management, by the way (judging by the fitting you've added to the middle of the manifold, I'm guessing you are)? If so, you could have just removed the TGV butterfly and motor, and plugged the holes for the throttle plate rod. Additionally, APS makes a set of replacement TGV deletes that also have provisions are additional fuel injectors, which could be quite useful for your application (depending on your injector size/whether or not you care about street drivability of course).
R1Z4T - There's nothing inherently "wrong" with internal wastegate (and in fact the EFR turbo's have one of the best internal wastegates I've seen, at least for twinscroll setups), but if you're trying to decrease spool time, having an external wastegate (or in the case of a twinscroll setup, two of them) is ideal. There is, of course, a disadvantage in packaging due to engine bay space, but every setup has its advantages and disadvantages. Similar concept for running an external BOV (in the case of the EFR turbos). Basically, if the engine bay space allows, it's generally better to go external. Besides, who doesn't want a couple of Turbosmart Comp-Gate40's and a Synapse Engineering DV sitting under their hood? I certainly do .
Old 06-13-2011, 09:10 AM   #834
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
5lipstream is offline   Reply With Quote
Old 06-13-2011, 10:36 AM   #835
MartinSTi05
Member#: 145145
2006 wrx STi
^Holy plenum volume Batman!^
MartinSTi05 is offline   Reply With Quote
Old 06-13-2011, 01:43 PM   #836
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I'm curious how they handled air distribution with it...I can see that on the backside that it's a bit deeper(or taller pending how you look at it).
Definitely not a manifold that I'd run a single point meth injection on!!
Old 06-13-2011, 03:29 PM   #837
MartinSTi05
Member#: 145145
2006 wrx STi
I wonder what the throttle response is like?
Old 06-13-2011, 03:42 PM   #838
Homemade WRX
Member#: 33782
96 bastard child
it's for making big power...that shouldn't be the first question asked
how much is the VE curve tilted upward and how much is the powerband shifted to the right?
Old 06-14-2011, 01:41 AM   #839
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
id say 1200 rpms
Alaskan EJ20 is offline   Reply With Quote
Old 06-14-2011, 09:22 AM   #840
fobiawrx
Member#: 91074
04 sti
white
i thought that had a water to air intercooler in it? in between the runner section and the tb section? could be wrong though?
fobiawrx is offline   Reply With Quote
Old 06-14-2011, 04:15 PM   #841
BLKonBLK05
Member#: 249379
2005 STI, black ....
hence the screen name
...hey anyone know a someone that selling a altinater braket for a reverse intake manifold? Or a least point me to a thread that talk about em.. I can't lower it... need to move it over
BLKonBLK05 is offline   Reply With Quote
Old 06-14-2011, 05:20 PM   #842
Homemade WRX
Member#: 33782
96 bastard child
everyone has just made their own.
I know Vern (vmiz) had talked about it briefly for All Aspects twin turbo WRX...or maybe it was Duncan's (dunk) track car.
Old 07-07-2011, 06:49 PM   #843
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Edited.
Old 07-19-2011, 07:18 PM   #844
WreaKLoosE
Member#: 165300
2006 WRX
Steel Gray Met.
Yea Im about to get one from J-dubb... (jermy) gotta call that guy to see if its ready yet.. haha.. Ive known Jermy for years (Lived across the street from him..) and they do good work at out front ms.. I got TGVD and a DBW TB so I think its all bolt up for me??
WreaKLoosE is offline   Reply With Quote
Old 08-15-2011, 07:58 PM   #845
WreaKLoosE
Member#: 165300
2006 WRX
Steel Gray Met.
Ok so I got my RS intake installed thanks to Jermy over at Outfront got it hooked up. Gotta do a lil bit more here and there but im diggen the feel.
Old 08-16-2011, 12:24 AM   #846
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
^^ Looks very nice
jigga is offline   Reply With Quote
Old 08-29-2011, 07:45 PM   #847
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
I just orderd the same intake from outfront with fuel rails john over there seemed super cool I will post pictures once fitted
I was in the process of building my own intake manifold but after seeing the flow data on this intake my turbo cannot out flow it
It flows 80cfm more air at 29 psi over a stock sti intake
And the runners are within 4cfm at 29 psi
The red sti intake has a 10 cfm variance
shilohb is offline   Reply With Quote
Old 09-04-2011, 07:01 PM   #848
onurba32
Member#: 203150
1996 gf8
red
its my intake manifold wrc magnesium v4 how is this manifold??efficient ?
[IMG] Uploaded with ImageShack.us[/IMG]
onurba32 is offline   Reply With Quote
Old 09-07-2011, 08:04 PM   #849
SomeoneWhoIsntMe
Member#: 160814
2002 WRX Wagon
I had no idea how much work shaving the manifold was going to be when I started
that said, after some grinding it looks like there's room for a turbo inlet. I'm psyched.
SomeoneWhoIsntMe is offline   Reply With Quote
Old 09-07-2011, 09:17 PM   #850
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Anyone know if the wrc ver 4 manifold will bolt to later year heads?
scby rex is online now   Reply With Quote
WTB: Polished or Aftermarket intake manifold midnightsti Private 'Wanted' Classifieds 4 06-13-2006 06:39 PM
Aftermarket intake manifold west005 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 05-30-2006 09:03 PM
Aftermarket Intake Manifolds WRXRallyBlue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 10-03-2005 08:11 PM
New/Aftermarket Intake manifold Twelvz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 03-11-2005 12:32 PM
New Aftermarket Intake Manifold DonkeyPunch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 01-15-2005 06:15 PM
