Old 12-16-2012, 02:07 PM   #876
squarebush
Member#: 173656
Originally Posted by 8thWonder View Post
^^update, they're not 1/8" NPT
I'm thinking they're M10-1.0 bolt size... not 100% sure though, since the only parts store within walking distance didn't carry that size.
You can use a 1/8NPT tap to re-thread them, I've done it several times, and have not had any leak problems. I just use a dab of RTV on the NPT threads as they are going in.
squarebush is offline   Reply With Quote
Old 08-05-2013, 11:32 PM   #877
04subielover
Member#: 347637
2004 wrx
Originally Posted by sick1.8t View Post
exactly.
this is what mine looked like when i first got it. bone stock w/ tgv-less runners. even still has the injectors in it. unless theres $1750 worth of work done to the manifold other than what you see, i'd say xccelleration.com is over pricing their stuff.
Sick 1.8t what year and model is this 2.5i manifold from? Will top feed id1000's drop right in this? I plan on that manifold with a 2004 wrx dbc.
04subielover is offline   Reply With Quote
Old 08-14-2013, 06:49 AM   #878
ScoobieDoBDo
Member#: 252102
03 WRB WRX Bugeye
Mazda Miata
Does anybody have any measurements from the throttle body to the firewall with a 2.5i intake manifold?
ScoobieDoBDo is offline   Reply With Quote
Old 08-14-2013, 06:53 AM   #879
ScoobieDoBDo
Member#: 252102
03 WRB WRX Bugeye
Mazda Miata
Does anybody have any measurements from the throttle body to the firewall with the 2.5i intake manifold swap?
Old 08-14-2013, 05:54 PM   #880
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
What are you trying to do?
medamullet is offline   Reply With Quote
Old 08-15-2013, 01:01 AM   #881
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
Call Joe with ASF Machine 970-242-0919....He is an expert on intake manifolds, with flow data and makes great products.....
jdpsearcher is offline   Reply With Quote
Old 08-15-2013, 05:25 PM   #882
ScoobieDoBDo
Member#: 252102
03 WRB WRX Bugeye
Mazda Miata
I want to see how much room I would have to run an air to water intercooler.
Old 08-15-2013, 05:50 PM   #883
25rsti
Member#: 166324
Very old pic of mine.
Old 08-15-2013, 08:55 PM   #884
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
Again call Joe with ASF Machine he builds Air to Water Intercooler into the intake manifold....Ask me how I know...
Old 08-16-2013, 03:56 PM   #885
Gettingthere
Member#: 155933
05 suby
I've got a Tomei intake manifold for sale =)
Gettingthere is offline   Reply With Quote
Old 09-29-2013, 02:44 AM   #886
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
How much for the manifold?
srREXed is offline   Reply With Quote
Old 10-13-2013, 09:22 PM   #887
ScoobyJD
Member#: 185910
moar manifolds!
ScoobyJD is offline   Reply With Quote
Old 10-31-2013, 04:57 PM   #888
franknbeans
Member#: 86113
2005 STi
is 2010 2.5i manifold the same as 2005?
I can't find any part numbers for these manifolds.
franknbeans is offline   Reply With Quote
Old 11-07-2013, 09:10 PM   #889
04subielover
Member#: 347637
2004 wrx
Here's mine so far, still needa powdercoat it all
Old 11-08-2013, 01:40 AM   #890
user1029
Member#: 57064
2008 STi IAG built
HTA86, Meth, 272s, Cos IM
user1029 is offline   Reply With Quote
Old 11-25-2013, 01:55 PM   #891
franknbeans
Member#: 86113
2005 STi
does anyone know what aftermarket fuel rails and injectors work with the 2.5i manifold?
Old 11-25-2013, 04:35 PM   #892
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
flat 4 motorsports on here have some. Hit phil up he'll get you everything you need
Old 11-25-2013, 11:14 PM   #893
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
I'm still looking for stock rail adaptors.
Anyone?
wrxsubiemod is offline   Reply With Quote
Old 11-25-2013, 11:17 PM   #894
04subielover
Member#: 347637
2004 wrx
Talk to Moore performance they made me a set
Old 01-25-2014, 06:24 PM   #895
WKDWRX02
Member#: 76950
2009 NISSAN GTR35
SUPER SILVER
Just another guy installing a 2.5i manifold...
Does anyone know off-hand what size NPT fittings are needed to plug these holes? Are they 1/8" NPT?
what year manifold did you use? do all the 2.5 manifolds come with the egr holes on them?
WKDWRX02 is offline   Reply With Quote
Old 01-25-2014, 07:43 PM   #896
AKSubieDubie
Member#: 190003
2007 STI EFR 8374
Im doing the same thing- using garret 750hp rated cores. Im taking the lightning heat exchanger and water pump off my truck to see how well it does.
Im going to use the 2006 2.5i legacy intake so i can retain tgvs and not mess with spacers. I mocked it up in thr GFs bugeye and using that intake, it measures about 7-8 inches total from the firewall to the throttle body. Its closer to 8 ish if you lose the ac.
Ill be putting the same setup in my car (sti swap gc) with a twinscroll bw 8375. Current setup is a gigantic 4" thick a2a intercooler, im hoping to reduce pipe length to gain a little spool .
* I noticed a huge difference (negative) when I went to that fmic with normally routed plumbing on a stock location 30r and sti tmic. I ended up doing a reverse intake which was a good compramise in spool.
Ill report back with gains sometime
Isaac
AKSubieDubie is offline   Reply With Quote
Old 01-26-2014, 12:15 AM   #897
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
GC and GD don't have the same room for a core in the top mount location. You will lose some height. Don't recall if the bulkhead gave me issues...
Old 01-26-2014, 12:34 PM   #898
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
Text me 2058350048 ive got my intake and tb on with no intercooler pipe. I can measure if needed
fastblueufo is offline   Reply With Quote
Old 01-26-2014, 03:27 PM   #899
WKDWRX02
Member#: 76950
2009 NISSAN GTR35
SUPER SILVER
sent ypu a pm.
Old 01-26-2014, 06:08 PM   #900
reemwrb04sti
Member#: 254796
04 Sti
Anyone done back to back testing on the dyno from stock manifold to the n/a manifold
reemwrb04sti is offline   Reply With Quote
WTB: Polished or Aftermarket intake manifold midnightsti Private 'Wanted' Classifieds 4 06-13-2006 06:39 PM
Aftermarket intake manifold west005 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 05-30-2006 09:03 PM
Aftermarket Intake Manifolds WRXRallyBlue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 10-03-2005 08:11 PM
New/Aftermarket Intake manifold Twelvz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 03-11-2005 12:32 PM
New Aftermarket Intake Manifold DonkeyPunch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 01-15-2005 06:15 PM
