Old 03-26-2007, 08:48 AM   #26
fmowry
Member#: 54604
2004 FXT
Cayenne Red (sold)
Your test #4 should be with your TMIC and a turbo that pushes the limit of all of the aftermarket TMICs. A FP green or similar.
Frank
fmowry is offline   Reply With Quote
Old 03-26-2007, 01:04 PM   #27
keaniegenie
Member#: 94494
2005 Element 92x
Frank
Agreed. Any TMIC that provides a pressure drop will give benefit over a stock WRX TMIC. Where people like myself really start shopping for one TMIC over another is how well they handle larger turbos.
For example, I currently have a Turbo XS TMIC. That said, I would definitely consider upgrading if there was tests showing any benefit in the form of cooling, efficiency and pressure drop. Even if it's minimally better on all aspects, I would still get one.
keaniegenie is offline   Reply With Quote
Old 03-28-2007, 06:36 AM   #28
thomtheviking
Member#: 134455
06 WRXTR COBB VF39
WRB / Gunmetal G-force
Wow....excellent thread! Is there a splitter/shroud that works well on the 06 with STi TMIC?
thomtheviking is offline   Reply With Quote
Old 03-28-2007, 01:18 PM   #29
keaniegenie
Member#: 94494
2005 Element 92x
Your stocker is good enough.
Old 03-28-2007, 02:32 PM   #30
Mykl
Member#: 14311
2010 GTI
How does spraying water on the top of the intercooler during driving affect it's cooling and efficiency?
Worthwhile or not?
Mykl is offline   Reply With Quote
Old 03-28-2007, 03:01 PM   #31
moswald80
Member#: 96620
2005 WRX STi
Keaniegenie,
I may be interpreting some of your posts wrong but you seem to be implying that a higher pressure drop is better for performance when, in fact, just the opposite is true. Pressure drop is related to the restriction to flow. For a given flow rate (CFM) a more restrictive system will have a higher pressure drop and vice versa.
Think of it this way: if your boost gauge (tapped into the Intake Manifold) is reading 20 psi and your Intercooler/Charge Pipes have a pressure drop of 2 psi (at a given flow rate) then your turbo is actually operating at 22 psi. You want to keep that pressure drop as low as possible to get as much boost as you can into the engine.
I just wanted to clear that up (I hope I didn't confuse the issue even more).
- Mike
moswald80 is offline   Reply With Quote
Old 03-28-2007, 04:11 PM   #32
keaniegenie
Member#: 94494
2005 Element 92x
Originally Posted by moswald80 View Post
Keaniegenie,
- Mike
You're correct. I meant reduced pressure drop. Thank you for clarifying.
Old 03-28-2007, 05:53 PM   #33
The Deliverator
Member#: 42376
2006 92x Aero
You want the STI splitter: 90817FE310
And the rubber seal: 90817FE340
The Deliverator is offline   Reply With Quote
Old 03-29-2007, 03:02 AM   #34
WaXed
Member#: 88273
2003 STi 2.0L
lower pressure drop may not always be better...
If the internal fin density is lower then you will get a lower pressure drop
however the IC efficiency can then suffer
in a correctly designed turbo system you allow for pressure drop across the intercooler (and you should have some)
If you have too little pressure drop ie. a very large intercooler
then you get the airflow going straight down the middle of the IC
this also creates lower IC efficiency
Air particles do not like to do right angle turns, pressure differential helps this to happen making for more even air flow through the IC
Like everything it comes down to good design
correctly sized IC for the design power levels and application
also good IC design/efficiency goes without question
stock subaru IC's are a very good design for stock power levels
tube/fin IC's are also very light for their size and efficiency (weight is also a consideration)
at elevated power levels they will of course produce increased pressure drops which are tehn limiting maximum achievable power levels
one reason to upgrade to larger IC
WaXed is offline   Reply With Quote
Old 03-30-2007, 06:19 AM   #35
Gatchaman
Member#: 143057
2004 STI
Dark Grey *Custom*
When will this Process West TMIC be available in the US.? I will be in the market for a new TMIC in the next few weeks and I am loving yours. Should I wait or is it going to be a while? How long?
Thank you.
Gatchaman is offline   Reply With Quote
Old 03-30-2007, 02:39 PM   #36
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Process West - Dou need a STi scoop to fit that splitter? Or will the standard WRX scoop be OK? Or will you be making different versions with different heights for WRX and STi and the different model years?
The welds on the IC look great and the data you have so far is also good.
drees is offline   Reply With Quote
Old 03-30-2007, 04:08 PM   #37
MikeCandler
Member#: 123018
2009 Legacy Spec B
Process West, your TMIC looks great very high quality unit too say the least! Where are you located in Australia? Opps I see you are in Sydney (beautiful place btw). Would you be willing to simply ship to a Brisbane address if I were to pick one of these up? My friend lives there and I am going to visit him again in July .
I also noticed you have changed the y-pipe slighty which is a good thing, any reason why you did not go another step with that? I mean eliminating the y-pipe all together using a single entry core hotside tank?
Thanks for the info,
Mike Candler
MikeCandler is offline   Reply With Quote
Old 04-01-2007, 01:04 AM   #38
Process West
Member#: 71459
2008 STi Silver
R Spec
Thank you.
MastroWRX will have some in about a week.
Kevin
Process West is offline   Reply With Quote
Old 04-01-2007, 01:07 AM   #39
Process West
Member#: 71459
2008 STi Silver
R Spec
The splitter is designed for the WRX scoop. If you have an STi then the splitter is not needed because the STi splitter works perfectly with my intercooler. There are 3 different splitters available. 01/02 WRX (bugeye) 03+ WRX and I also have a splitter for Forester XT.
Kevin
Old 04-01-2007, 01:09 AM   #40
Process West
Member#: 71459
2008 STi Silver
R Spec
Mike Candler
I can send one to your friends place in Brisbane no problem.
The idea of the Y-pipe is to give an even distribution of charge air along the rear end tank.
Kevin
Old 04-01-2007, 02:10 AM   #41
drees
Member#: 25905
2003 Silver Wagon
Sounds like you guys thought of everything. Good job!
Old 04-01-2007, 02:45 AM   #42
Gatchaman
Member#: 143057
2004 STI
Dark Grey *Custom*
In a week!?!? Fantastic!!! I thought your were going to say a few months.
Thank you!
Old 04-04-2007, 02:28 PM   #43
Gatchaman
Member#: 143057
2004 STI
Dark Grey *Custom*
Where can we buy this? Links to website? Phone numbers? Price?
Thanks!
Old 04-04-2007, 04:45 PM   #44
SnowMann
Member#: 79996
2005 LGT Ltd.
GRP
Thanks!
www.mastrowrx.com
SnowMann is offline   Reply With Quote
Old 04-06-2007, 03:06 AM   #45
Gatchaman
Member#: 143057
2004 STI
Dark Grey *Custom*
I don't see it their. Not available yet? Thanks for the quick reply.
Old 04-06-2007, 06:48 AM   #46
MattPersman
Member#: 139385
MattPersman is offline   Reply With Quote
Old 04-06-2007, 09:21 AM   #47
klinebau
Member#: 122383
2006 WRX Wagon
Its on the site with no picture. The description says coming soon and no price is listed yet. I would just keep checking up on it or sending them an email.
klinebau is offline   Reply With Quote
Old 05-14-2007, 11:16 AM   #48
MRGLASS
Member#: 66424
2005 STI
has anyone been able to get the new Process West tmic yet??
MRGLASS is offline   Reply With Quote
Old 05-14-2007, 12:21 PM   #49
keaniegenie
Member#: 94494
2005 Element 92x
Kevin
Make one for a Saab 92x, and you won't have to redesign a splitter when the new WRX's come out.
New WRX hood scoop= Saab 92x hood scoop.
Old 05-24-2007, 06:37 AM   #50
AnorexicSTI
Member#: 85227
2005 STI
Does anybody have a weight spec for the PW TMIC? Also wondering if it includes any hoses or clamps?
AnorexicSTI is offline   Reply With Quote
FS : a/c, hks bov, tmic, , intake, fogs, intercooler, tires, rims, lots more! white guys wrx Engine/Power/Exhaust 28 07-30-2010 01:03 PM
FS : Stock 06-07 WRX TMIC moosedude2.5 Engine/Power/Exhaust 2 06-22-2010 06:46 PM
Hey upstaters-there's a Solo discussion board on the F.L. Region web site! Mike Smith Tri-State Area Forum 2 05-09-2001 06:13 AM
90-94 Legacy Discussion Group now up! Shik Legacy Forum 8 09-09-2000 10:08 PM
Auto-X discussion imprezzed New England Impreza Club Forum -- NESIC 14 08-18-2000 02:59 PM
