Old 05-24-2007, 05:42 PM   #51
WRx1an
Member#: 120482
Originally Posted by 02wrx88 View Post
Does anybody have a weight spec for the PW TMIC? Also wondering if it includes any hoses or clamps?
It comes with all hoses and clamps and also the splitter if its needed. (Weight?)
http://www.rexnet.com.au/forum/index...howtopic=67225
Its a pity Kevin hasn't posted pressure drop across the ic or finished writing up a test with it fitted to an STi.
WRx1an is offline   Reply With Quote
Old 05-24-2007, 09:04 PM   #52
keaniegenie
Member#: 94494
2005 Element 92x
It's also a pity he won't respond to my questions or PM's after he used my thread for advertising.
(hint hint)
keaniegenie is offline   Reply With Quote
Old 05-25-2007, 06:39 AM   #53
WRx1an
Member#: 120482
(hint hint)
Its an innovative product he has developed and it looks like he is filling back-order lists so I guess they are walking out the door. He is obviously busy but he stated early on he would do the STi TMIC comparo, lets hope he holds to it.
Old 05-27-2007, 01:48 AM   #54
SouthOCSTI
Member#: 149825
2005 STI
Any update?
SouthOCSTI is offline   Reply With Quote
Old 06-13-2007, 04:43 AM   #55
AnorexicSTI
Member#: 85227
2005 STI
Updates? still waiting for a weight spec.
AnorexicSTI is offline   Reply With Quote
Old 07-09-2007, 08:30 AM   #56
keaniegenie
Member#: 94494
2005 Element 92x
BUMP...
I talked to Dan at Prodrive and he mentioned to me how important it is for the gasket on the splitter to be 100% sealed on the TMIC. I noticed today that the Turbo XS I have isn't long enough and the gasket is left open on the passenger side.
This is bad for STI owners, as I have an STI splitter gasket.
Is the Process west out yet?
Old 08-24-2008, 03:33 PM   #57
Somboa
Member#: 156585
2006 WRX LTD Wagon
Bump. I just got a TurboXS (replica) TMIC and the stock WRX splitter is literally half the size of the intercooler.
Thinking of either the STI splitter or the Process West splitter.
Somboa is offline   Reply With Quote
Old 01-06-2011, 03:12 PM   #58
p220guy
Member#: 254265
06 WRX
Yes I am bumping this back from the dead... was this testing ever done???
And is this TMIC woth wild on a Stage 2 06/07 wrx or better to stick with OEM till a bigger turbo comes along???
P220guy
p220guy is offline   Reply With Quote
Old 07-05-2011, 12:38 PM   #59
docmaimran
Member#: 177209
2007 Subaru STi
Jet Grey
2007 STI, Walbro fuel pump, tomei headers / uppipe, Aps Turboback Exhaust, Man Boost controller, Fujita cold air intake, stock: turbo, injectors, fuel lines, engine....question, i know this is an older post, so hopefully someone will respond to me... But I'm planning on getting a AMR top mount intercooler, (so far the largest on the market and great reviews)...But I also want to get a larger Hood scoop... any ideas on both as in terms of will the larger hood scoop assist from the stock...(not into the FMIC at this time, cause its much more expensive, and I am not crazy about ruining the integrity of the chassis at this point as I live in NYC and..... I am also staying around the 400 whp range..OH...one more thing, should I look into changing any of the Turbo inleft tubes or would that not really matter until I change the turbo...the same going for the inlet tube from the COLD air intake.... thanks so much guys.....
docmaimran is offline   Reply With Quote
Old 07-12-2011, 06:39 PM   #60
sspeed
Member#: 161854
Welllllll..... since the thread is back from the dead....
When will Process West have a shroud/splitter available for the LGT? It's a proverbial kick in the teeth to have it available for the Forester and not the LGT. One splitter would open buying potential to another complete market...
Fair amount of interest in this thread...
http://legacygt.com/forums/showthrea...ic-119336.html
Heck, the shroud/splitter purchased alone is $227. If I buy the WRX kit I get $227 worth of parts I don't need and can't use... give me a comparable discount and I'll fab a splitter/shroud and send you the prototype....
sspeed is offline   Reply With Quote
Old 07-13-2011, 06:51 PM   #61
OzWRX
Member#: 15150
2015 WRX
I have replied to your post on Rexnet
Kev - Process West
OzWRX is offline   Reply With Quote
Old 07-14-2011, 09:38 AM   #62
sspeed
Member#: 161854
Kev - Process West
Thank you Kev, much appreciated! PM me if you need any detailed pictures or measurements on the US model while you work with the test car.
Old 07-15-2011, 10:28 AM   #63
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Originally Posted by Process West View Post
Guys
These pics are worth a look. As Unabomber said ealier my new TMIC comes complete with a replacement splitter/shroud.
this pic shows the difference between the factory splitter (rear) and the Process West unit.
Kevin
Ok, so here's a question for you Kev ...
When you look at the left side of both the OEM splitter and the Process West splitter, you see the area that is nor directly under the scoop, but is still perforated which allows air to escape into the engine bay.
Why not change the design, so that the left side of the splitter (and maybe the right side of the splitter as well) takes that air that flows into the engine bay and re-directs it over the intercooler?
One would think that this will add additional cooling to the intercooler.
Samurai Jack is offline   Reply With Quote
Old 07-15-2011, 11:20 AM   #64
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Kev
A second question I thought of, becuase I don't remember seeing the answer anywhere ...
How much HP do you believe your TMIC will support, and retain it's high degree of cooling/performance? For example, IF the Process West TMIC can handle up to 800WHP, when would the peak performance characteristics of the TMIC be reached? 500WHP?
Old 07-15-2011, 12:14 PM   #65
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
That area is to vent hot air from the turbo and allow fresh air to help cool it when moving.
indytruckboy is offline   Reply With Quote
Old 07-15-2011, 01:40 PM   #66
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Hadn't thought of that. Good idea.
Old 07-16-2011, 04:18 AM   #67
markesc
Member#: 164875
2007 WRXTR blouch20G
Up over $900 now:
http://www.rallysportdirect.com/Proc...-STI-2006-2007
I still plan on getting one though
markesc is offline   Reply With Quote
Old 07-16-2011, 04:41 AM   #68
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
PM the vendors that currently sell the PW unit. They will more than likely give you a much better deal than what they have advertised on their site.
Bishop is offline   Reply With Quote
Old 07-16-2011, 10:39 PM   #69
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
Originally Posted by markesc View Post
Up over $900 now:
I recently saw that as I'm about ready to buy one. I wish I had purchased it last year now. RSD also shows that they don't expect the 04-05 until the end of August
yamahaSHO is offline   Reply With Quote
Old 07-20-2011, 11:29 AM   #70
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Kev
Looks like I found the answer to my question ...
Originally Posted by RallySportDirect website
The Process West intercooler is a direct factory replacement, that features a larger then stock core, and lower pressure drop. These 2 features previously stated allow the intercooler to flow more air while reducing the amount of pressure that is lost over the surface of the intercooler. These features allow the intercooler to work better for longer, and also allow a larger amount of air to pass through the core. The combination of these things will allow this intercooler to handle upwards of 400WHP.
FS : a/c, hks bov, tmic, , intake, fogs, intercooler, tires, rims, lots more! white guys wrx Engine/Power/Exhaust 28 07-30-2010 01:03 PM
FS : Stock 06-07 WRX TMIC moosedude2.5 Engine/Power/Exhaust 2 06-22-2010 06:46 PM
Hey upstaters-there's a Solo discussion board on the F.L. Region web site! Mike Smith Tri-State Area Forum 2 05-09-2001 06:13 AM
90-94 Legacy Discussion Group now up! Shik Legacy Forum 8 09-09-2000 10:08 PM
Auto-X discussion imprezzed New England Impreza Club Forum -- NESIC 14 08-18-2000 02:59 PM
