Old 07-28-2012, 07:14 PM   #2851
IvanFA20
Member#: 227738
16' WRX CVT
^ awesome!
IvanFA20 is offline   Reply With Quote
Old 07-28-2012, 07:15 PM   #2852
IvanFA20
Member#: 227738
16' WRX CVT
Cupcake car meet!
Old 07-29-2012, 04:23 PM   #2853
reddoak
Member#: 147628
2014 Fiat Abarth 500
Rosso
Hit a puddle...
reddoak is offline   Reply With Quote
Old 07-29-2012, 08:16 PM   #2854
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
Ever since I drove on the beach, I've been considering lifting my impreza more and more. At first I was just joking around because it would have been nice for the beach, but it would make driving on PA's roads all around much better. Especially the gravel/dirt ones
I am seriously considering Forester struts/springs/ect for when the ones in my car now, go up. I have pretty good clearance in my stock Impreza L as it is, especially since the front sits higher than the rear (for some reason). That gives me pretty decent clearance up front, but a few more inches all around would be the bees-knees.
Too bad DirtyImpreza doesn't have a mobile app........
ManualOverAuto is offline   Reply With Quote
Old 07-29-2012, 10:34 PM   #2855
gregroot198521
Member#: 280844
2006 STi
What year is yours? Some of the model years have issues with more than a certain amount of lift ('08+ limit is ~2").
They're on Tapatalk along with a few other of the good ones.
gregroot198521 is offline   Reply With Quote
Old 07-30-2012, 12:54 AM   #2856
Smokin' Joe
Member#: 219679
2011 Impreza WRX
Rally Stuff
"Hit a puddle" doesn't seem to describe the way you seem to have REMOVED that puddle from existance! LOL! Nice work
Originally Posted by reddoak View Post
Hit a puddle...
Smokin' Joe is offline   Reply With Quote
Old 07-30-2012, 01:36 AM   #2857
ManualOverAuto
Member#: 304662
Sedona red Pearl
Originally Posted by gregroot198521
What year is yours?
'01
I don't plan on reaching the "limit", but what needs to be done/replaced/upgraded after that "limit" is reached?
Just curious
Old 07-30-2012, 07:33 AM   #2858
gregroot198521
Member#: 280844
2006 STi
'01
Just curious
Ah, not a clue on your MY then, but IIRC, the "limit" is more forgiving in the older MYs. In most cases it's the CVs that have issues, IIRC.
Old 07-30-2012, 06:21 PM   #2859
Vaughn Performance
Member#: 170489
Originally Posted by ManualOverAuto View Post
'01
Just curious
To run Foz struts you're also going to need to replace the rear trailing arm brackets and install the spacers in the subframe that lower the drivetrain back to the height it should be at to avoid damaging the CV joints. I'd really only ever recommend this to someone that is looking to do some serious trail type off roading.
If you want a more mild lift run the foz struts and Impreza springs.
-Anthony
Vaughn Performance is offline   Reply With Quote
Old 07-30-2012, 08:01 PM   #2860
gregroot198521
Member#: 280844
2006 STi
Or rebuild (get them rebuilt) your struts and run with some King springs. Winning?!
Old 07-30-2012, 11:09 PM   #2861
ManualOverAuto
Member#: 304662
Sedona red Pearl
Thanks for the info guys. This is more of a future thing though, and I will look further into things/research more when the time gets closer.
I also wouldn't want much lift anyway. Two inches would probably be plenty.
Old 07-31-2012, 01:09 PM   #2862
reddoak
Member#: 147628
Rosso
Just go with a smaller spacer on top of the strut, perhaps. A one inch spacer.
Old 07-31-2012, 04:19 PM   #2863
Vaughn Performance
Member#: 170489
Can't rebuild the stock KYB twin tubes, only the monotube inverted STi struts. That or Feal inserts can be rebuilt.
When your ready to go just drop me a line and I'll get ya sorted.
2" lift actually is pretty substantial in terms of increasing ground clearance. Nothing wrong with lift via spacers, but some lift from springs is nice as you get the benefits of added suspension travel.
-Anthony
Old 07-31-2012, 09:25 PM   #2864
gregroot198521
Member#: 280844
2006 STi
^Yep, was talking about inserts for the stockers.
Old 08-01-2012, 09:57 AM   #2865
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
Originally Posted by Vaughn Performance View Post
Some lift from springs is nice as you get the benefits of added suspension travel.
-Anthony
Its all about spring rate.
People make the mistake of increasing the rate too much.
Yes you want to be a touch stiffer to help absorb impacts, but you can run a taller spring with barely an increase in rate.
You just change the wire thickness and spacing.
Someone should make a coilover adapter mounts for the suby knuckle/pillar so you can just run regular bypass coiovers from fox or king.
Would drastically open up the options.
Maybe I'ill do it lol. Gimme lots of money and be a guinea pig. Ill break out the welder.
*nevermind... forgot there was no upper a-arm. Just run a longer spring.
The Phenx is offline   Reply With Quote
Old 08-01-2012, 07:09 PM   #2866
burkart
Member#: 305000
2005 Legacy GT 5MT
Bright Silver Metallic
anyone heard of an adjustable-ride-height mod? probably ridic $ and time, but just curious.
how sweet would it be to have a range of ground clearance options........ mmm
burkart is offline   Reply With Quote
Old 08-01-2012, 07:23 PM   #2867
Nawratil
Member#: 306659
2012 Impreza WRX
Obsidean Black Pearl
Ksport gravel coilovers. Lift up to 4in from stock, drop 2in from stock.
Nawratil is offline   Reply With Quote
Old 08-01-2012, 07:25 PM   #2868
burkart
Member#: 305000
2005 Legacy GT 5MT
nice! how about something button-operated tho? air suspensions couldnt be that tough if jeep figured it out in the 90s...
Old 08-01-2012, 07:26 PM   #2869
burkart
Member#: 305000
2005 Legacy GT 5MT
Hit a puddle...
thats the most bad-ass 5th generation i've seen so far. on steelies no less. where did you play?
Old 08-01-2012, 08:49 PM   #2870
Jaeh
Member#: 308139
I agree. Its rare to see the new ones getting ready to get dirty like that.
Jaeh is offline   Reply With Quote
Old 08-02-2012, 03:02 AM   #2871
I'mFineW/Slow
Member#: 260395
2004 Impreza 2.5 RS
Not mine. Just saw it in my town and it blew me away. Made me love the new outbacks (wasn't a big fan before)
I'mFineW/Slow is offline   Reply With Quote
Old 08-02-2012, 03:24 AM   #2872
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
^Do like
EvileyeZ88 is offline   Reply With Quote
Old 08-02-2012, 08:49 AM   #2873
ryan s.
Member#: 276486
'08 lowered Outback
That gray 5th gen is owned by a guy on SubaruOutback.org.
King springs w/ 1" Subtle spacers if I remember correctly.
ryan s. is offline   Reply With Quote
Old 08-02-2012, 02:47 PM   #2874
reddoak
Member#: 147628
Rosso
Actually... Kings with primitive rally spacers. Same difference.
That's FLHRSI on subaruoutback.org and here on NASIOC. I recognize the car... He had to jump through some hoops to get that bullbar installed. It was made by an Australian company, and there are some differences in the front bumper, so it needed a bit of work to fit. IIRC, he's lifted the same way as mine.
And uh... the 2010-13 Outbacks are 4th Gen.
Old 08-02-2012, 02:55 PM   #2875
reddoak
Member#: 147628
Rosso
Here: https://maps.google.com/?ll=28.34592...09645&t=h&z=17
And Ocala Nat. Forest, and wherever there's an access road or powerline trail. That's one reason i liked the Outback. I can just go exploring anywhere. If the car fits down the trail, I can probably make it to where it goes...
Lame videos (more fun making them than watching them!) from the same location:
Chamois, or just plain Sham? Lifino Interior & Exterior Modification 8 10-02-2013 08:01 PM
SOA gotta love 'em or just plain hate 'em kalbo-1 Warranty Issues & SOA Problems 1 01-19-2004 08:29 PM
Hot or Not or Just Plain Ok.... n20x3whitewrx Member's Car Gallery 28 07-29-2002 10:05 AM
McRae: Dedicated or just plain nuts? SubaruStu Motorsports 2 03-20-2002 09:55 AM
Jinxed? Or just Plain UnLucky??!! silverSurfer General Forum Archive 6 06-30-2000 10:27 PM
