Old 10-17-2010, 10:58 PM   #1451
ALTIMIT_09
Member#: 138527
2004 WRX 4eat vf39'd
ALTIMIT_09 is offline   Reply With Quote
Old 10-18-2010, 11:16 AM   #1452
carl s.
Top Scoob 026
Member#: 119034
96 Open Class STI
took a big rock during LSPR. Came over a crest, road was washed out on my line and bam. broke the wheel, tie rod, ball joint and axles. I think the strut is ok and the control arm might be ok but it might be cracked - haven't really looked at it yet. The GRIPPA was still holding 28psi afterward.
carl s. is offline   Reply With Quote
Old 10-18-2010, 01:15 PM   #1453
iluvdrt
Member#: 46248
82 Brat
Tan
^^Damn, that's a hell of bead to still be holding air LOL.
iluvdrt is offline   Reply With Quote
Old 10-18-2010, 08:13 PM   #1454
skunkman
Member#: 118141
95 'lifted' legacy
Originally Posted by dgsblb2 View Post
Wrong.
Both lift the car the exact same way (suspension lift). The only difference is that the Forester suspension will lift it about 3-4 inches. It comes down to what you want.
Nay.
Not to argue the point, but to clarify my take.
Unfortunately this forum tends to be an unfriendly forum where disagreement occurs
but here is the support for my argument:
FOR suspension provides longer suspension travel with taller springs and longer strut shafts, thus suspension lift.
Spacers use stock struts and springs, but push the body UP OFF the suspension, thus body lift.
left to right:
FOR, LEGacy, IMP
left to right:
second gen FOR, first gen OB, LEGacy
The only time you will achieve a body lift is when you install cross member spacers. I don't recommend Forester suspension on an Impreza without front cross member spacers, but some people still do it. It also requires outback rear control arm mounts and a modified steering coupler, but those aren't complicated and way worth it. Your oil pan will be 1.5 inches lower, but your axles will be at a healthy angle. 1.5 inches isn't a big deal clearance wise, but axle wise it is.
These cross member spacers do not provide lift, but rather drop the drive line.
The Outback and forester strut shafts are longer than IMP or Legacy, thus providing "lift". They push everything of the car higher off the ground, including engine and transmission, but by dropping the driveline, you lower the engine and transmission so the axles/half shafts/CV joints remain in a nearer horizontal geometry from transmission/rear differential to the hub assembly.
As such, when you push the car up on OB or FOR struts and do NOT lower the driveline (with engine, transmission and rear control arm mounts), then the exles maintain a slight angle, not straight line, from engine or diff into inner CV joint, through the shaft through the outer CV joint to the hub....
At any rate, those spacers do not lift, nut rather lower driveline. Which is why, for example, a legacy on OB struts has slightly more ground clearance than it's OB counterpart, because the driveline lowering counteracts the increased ride height, but decreases albeit slightly, minimum ground clearance.
This is oil pan lowered, b/c engine, transmission, driveline lowered with respect to the body, thus losing some of the graound clearance gained by the strut swap.
This is why some people transfer those parts and others don't bother. Ideally for axles longevity one should transfer all those spacers/brackets, but ideal means different things for different folks. Ideal maximum ground clearance: forget about the crossmember spacers, ideal for increased (over stock) ride height and axle life: transfer the spacers and brackets...
I did the OB strut swap in my legacy 6.5 years ago and just replaced my first axle last week. It was a front axle due to cracking boot and some play developping in the half shaft. probably more an artifact of hard driving (rallying and off road) than an axle angle issue.
At any rate, to each his/her own, as they say. . .
skunkman is offline   Reply With Quote
Old 10-18-2010, 08:19 PM   #1455
skunkman
Member#: 118141
95 'lifted' legacy
NICE!! I like that you're out of the ruts looking for freshies! Where in Utahr are you?
Old 10-18-2010, 09:22 PM   #1456
dgsblb2
Member#: 197278
1999 Lifted OBS
Exactly! The cross member spacers make it a body lift because you still lift the body using the longer suspension, but lower the rear diff/transmission/engine with the cross member spacers.
And I'm sorry, but you're wrong about the lift spacers (ex. jackson rally 1'') being a body lift. That's a suspension lift because they are increasing the angle of the axles and raising EVERYTHING rather than just the BODY.
I've encountered a few people having problems with their axles, like myself, because they're at too steep of an angle with 4 inches of suspension lift. Obviously it would be ideal to skip the cross member spacers because they do lower the drive line, but it's something you have to do in some applications. However, a body lift allows for more body clearance, healthier axles, and bigger tires. With proper tire placement and a little common sense, it isn't an issue and well worth it if needed.
I'm sure if we talked about this in person we would both be on the exact same page.
I saw someone on here posting about how they lifted their ride with forester suspension and then an additional 1.5 inches with cross member spacers. I , but didn't feel like explaining it.
dgsblb2 is offline   Reply With Quote
Old 10-19-2010, 12:28 PM   #1457
Skippy5883
Member#: 34730
Midnight Black Pearl
Wow... I'm surprised I haven't found this thread before now!
Here's my '02 with 1" spacers in the front, 1 3/8" in the rear and a set of General Grabbers (along with a few other "bolt-ons" )
Skippy5883 is offline   Reply With Quote
Old 10-19-2010, 02:38 PM   #1458
skunkman
Member#: 118141
95 'lifted' legacy
Yeah you're right. I think we're talking circles of the same thing from different angles.
I think the deeper point here is, we agree lifting and rallying Subarus are good ideas
I really think IMPS and WRXs on FOR gear or even the spacers, with grabbers are the way the car is meant to be/function.
Cheers my lifted Subaru brother
Old 10-19-2010, 06:30 PM   #1459
biebs96
Member#: 238035
not lifted yet but after some offroading.
i took these pictures after we got a rain storm so imagine how dirty it was.
biebs96 is offline   Reply With Quote
Old 10-19-2010, 06:33 PM   #1460
fgonz662
Member#: 260430
look at all these subarus in here doing what their meant to do GET DIRTY!!! HELL YEA!
fgonz662 is offline   Reply With Quote
Old 10-19-2010, 11:58 PM   #1461
dgsblb2
Member#: 197278
1999 Lifted OBS
I think the deeper point here is, we agree lifting Subarus is a good idea
Couldn't agree more! Good deal!!!
Old 10-21-2010, 02:54 AM   #1462
Eriksport
Member#: 5825
02 Impreza WRX Wag
Silver, curb rash, mud
In the 4X4 (non Subaru) world:
Suspension Lift=creating higher ground clearance by whatever means are available.
Body Lift=creating tire clearance by moving body off the suspension higher, and thus only getting the ground clearance by running larger diameter tires.
Which of course is why we're all flogging the dead horse here, really a spacer mounted on top of the strut assembly is almost a body lift, but it also lengthens the overall strut length, thus creating a suspension lift. So lets all agree to disagree=lifting good, lowering only good if your car lives on pavement. Now if only I hadnt just bought new MX's for my goldies before lifting the car last year about this time. The snow tires never came off this year, hoping they'd wear out so I can upsize to some AT's. But alas, my Observes still look new despite my attempt and killing them with power sliding with monster truck lean.
(from last fall's Hatch Patrol wild Xmas Tree Hunt on Mt.Rainier)
Eriksport is offline   Reply With Quote
Old 10-21-2010, 04:15 AM   #1463
dgsblb2
Member#: 197278
1999 Lifted OBS
Just took a trip to Yosemite. Both of these pictures were taken after I simply parked, turned around, and said hey that looks like a good picture. I didn't edit these at all.
Old 10-21-2010, 02:51 PM   #1464
kptimpreza
Member#: 140700
2007 2.5i wagon
satin white pearl
does putting on bigger tires mess with speedometer and gas mileage?
how does everyone like the ride quality and handling?
kptimpreza is offline   Reply With Quote
Old 10-21-2010, 04:15 PM   #1465
ansonowicz
Member#: 103179
2006 OBXT Lesbaru
SoCal F4 #21
I dont' know about mileage, per se. But since my tires were about 8-10% larger than stock, then my speedometer was off by that same amount (verified with GPS and a friend in the same MY06 wrx next to me on stock tires). So since speed is affected, so is odometer...MPG calculations during fillup, etc.
As for handling, I tell people "it turns like a truck, but goes fast in a straight line like a subaru". acceleration is definitely affected since there's so much rotating mass.
ansonowicz is offline   Reply With Quote
Old 10-22-2010, 03:54 PM   #1466
Charlie Sti
Member#: 261759
2005 Sti
I wish there were more rally roads in around phoenix
Charlie Sti is offline   Reply With Quote
Old 10-22-2010, 05:04 PM   #1467
ansonowicz
Member#: 103179
2006 OBXT Lesbaru
SoCal F4 #21
Subiefest 2010. The dirt hill above Willow Springs Raceway.....the day after (drove about 150mi home), I suffered the notorious Oil Pickup Failure and my motor was destroyed
Old 10-22-2010, 07:20 PM   #1468
wrxodee
Member#: 162183
2ooo 2.5 RS
This is a picture of Downtoearth aka the low master of utah Lance. It was on a back road coming home from miller motorpark. We just got finished at the Le Mons races I forget the name of the road it was.
wrxodee is offline   Reply With Quote
Old 10-22-2010, 07:27 PM   #1469
wrxodee
Member#: 162183
2ooo 2.5 RS
I just did some test fitting. What do you guys think? Im not done yet color or even the right rims. But I'm close
Old 10-22-2010, 07:32 PM   #1470
cmpequeno
Member#: 87036
2002 Impreza Outback
Red
what's the tire size?
cmpequeno is offline   Reply With Quote
Old 10-22-2010, 09:48 PM   #1471
kickniteasy
Member#: 201661
2013 STI
2002 Forester
are those jeep rims?
kickniteasy is offline   Reply With Quote
Old 10-23-2010, 09:08 PM   #1472
wrxodee
Member#: 162183
2ooo 2.5 RS
225/75/15
And yes sir they are the stock wheels off a 98 jeep wrangler
Old 10-24-2010, 01:39 PM   #1473
kickniteasy
Member#: 201661
2013 STI
2002 Forester
Very nice! I thought I recognized them, my wife used to own a Cherokee when we first started dating.
Old 10-25-2010, 11:45 AM   #1474
skunkman
Member#: 118141
95 'lifted' legacy
I think ride quality is fine on ATs and I've stiffened the suspension a touch and by replacing struts with KYB GR2/Excel G and springs with FOR springs.
I think my tire size (27" from stock 24") puts my Speedo and Odo off from 3-5% I'm going a touch faster than the speedo reads, but the car doesn't go that fast anymore (I think max is like 95mph, downhill with tailwind, I usually cruise 73 on hwy) anyway so its not a problem.
Handling is fine, but would prefer to upsize my sway bars to Outback bars for rally and search for disconnects for off-road and max suspension articulation...
Gas mileage is down a touch, but I still get from 19-22 city and 23-26 hwy (accounting for the 3-5% difference)
So though handling, ride quality and MPG are a little affected, the benefits WAY outweigh those minor costs...
Old 10-25-2010, 11:48 AM   #1475
skunkman
Member#: 118141
95 'lifted' legacy
There is a group in Flag working on bringing rally to the people in AZ and their main contact/qualified guy is in Tucson...
AZ has great driving but needs more folks to make rally happen there.
So there's another reason to make the trip up the hill and get out of the valley hell. To go rally those northern AZ FS roads
*EDIT** Check here and get involved:http://www.azrally.com/
Chamois, or just plain Sham? Lifino Interior & Exterior Modification 8 10-02-2013 08:01 PM
SOA gotta love 'em or just plain hate 'em kalbo-1 Warranty Issues & SOA Problems 1 01-19-2004 08:29 PM
Hot or Not or Just Plain Ok.... n20x3whitewrx Member's Car Gallery 28 07-29-2002 10:05 AM
McRae: Dedicated or just plain nuts? SubaruStu Motorsports 2 03-20-2002 09:55 AM
Jinxed? Or just Plain UnLucky??!! silverSurfer General Forum Archive 6 06-30-2000 10:27 PM
