Old 02-07-2011, 01:51 AM   #1751
skunkman
Member#: 118141
95 'lifted' legacy
Originally Posted by calgearhead View Post
I forget. . . Do you have a 5MT in that?
looks good, looking forward to more shots in action, especially with that lift
skunkman is offline   Reply With Quote
Old 02-07-2011, 01:07 PM   #1752
cmpequeno
Member#: 87036
2002 Impreza Outback
Red
05ASPINREX, your car looks good! like it a lot!
cmpequeno is offline   Reply With Quote
Old 02-07-2011, 06:43 PM   #1753
05ASPINREX
Member#: 190454
2005 wrx stage II
white like my bitch
thanks man! im thinking of painting the rims black . but it looks like it came from the factory like that haha
05ASPINREX is offline   Reply With Quote
Old 02-07-2011, 06:49 PM   #1754
chrisGT
Member#: 272873
89 lift 89 D/R GL
chrisGT is offline   Reply With Quote
Old 02-07-2011, 07:13 PM   #1755
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
1970 Subaru FF-1 Coupe
I thought for a second those solar panels were installed on the roof and hood
Old 02-07-2011, 09:40 PM   #1756
subaru0276
Member#: 172940
02 wrxstg2alicious
ifudontknowicanthelpu
^^^^ me too!!!!
subaru0276 is offline   Reply With Quote
Old 02-08-2011, 10:46 AM   #1757
calgearhead
Member#: 133745
1998 Lifted Outback
Green + Dirt
Yes its a stick, wouldn't have bought it otherwise
calgearhead is offline   Reply With Quote
Old 02-09-2011, 07:14 PM   #1758
calgearhead
Member#: 133745
1998 Lifted Outback
Green + Dirt
Pic from my first outing
Old 02-09-2011, 07:20 PM   #1759
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
You need a low clearance muffler
Old 02-09-2011, 09:31 PM   #1760
Back Road Runner
Member#: 60082
2004 Forester STI
Current Setup:
Suspension:
Struts : Tokico D-Spec - full stiff front, 4.5 turns rear
Springs : GC coilover kit - 10" 350 lb/in front, 10" 250 lb/in rear
Sway bars : 20mm oem front, 20mm oem rear
Camber : Noltec front camber plate, full caster, zeroed camber, -2.5 degrees front, -1.5 degrees rear set at lower bolts
Tires: "retired" Blizzak LM25 for gravel/packed/clay, ExtremeWinterContact for snow/mud/loose
Engine:
Internals: stock
ECU: SRS-20 I-Speed reflash
Exhaust: TWE rally prototype header + 2.5" high flow exhaust
Intake: Modified airbox to top feed cold intake
Power: 174chp/186cft-lbs (+/- 1-2)
Chassis:
Interior: full
Bracing: Mo-Boost 4-point rear strut tower brace
Bushings/mounts: uh...lots, everything cept the rear end so far.
Old 02-09-2011, 10:24 PM   #1761
kickniteasy
Member#: 201661
2009 WRX "Stage 2"
2002 Forester
Originally Posted by TommySWRX View Post
My 08 WRX on 09 Forester Struts. Soon it will have every other suspension component from the Forester which is quite a bit more than you might think, but the rest is all sitting on my floor going on Saturday.
From this:
To this:
any more updates?
kickniteasy is offline   Reply With Quote
Old 02-13-2011, 01:35 PM   #1762
premier00000
Member#: 251060
2008 Impreza Outback
I'm thinking about lifting my '08 OBS, which is DD, what would be the best (cost effective or easiest) way to lift my car?
premier00000 is offline   Reply With Quote
Old 02-13-2011, 02:43 PM   #1763
Gclark
Member#: 192352
1993 Legacy Turbo
ლ( ಠ ಠ)
1" Spacers, $225.
Gclark is offline   Reply With Quote
Old 02-13-2011, 03:12 PM   #1764
premier00000
Member#: 251060
Originally Posted by Gclark View Post
1" Spacers, $225.
is that enough to really lift it and make it more useful? i have 215/60-16 on now, and i want something with more meat, but dont want to rub on everything.
Old 02-13-2011, 06:27 PM   #1765
Back Road Runner
Member#: 60082
2004 Forester STI
It depends on what you want the car to do. Do you need more travel or more ground clearance. If you want more bump travel, you run a taller spring like what TommySWRX did. If you simply want more clearance, you add chassis spacers. I will note that this can include strut spacers but also spacers that drop the subframe which keeps the suspension geometry the same. I don't know of anything exists for the newer chassis though. The cheapest option is simply the spacers that go on top of the strut, but realize that is only a partial solution. Normally you would include lift blocks for the subframe front and rear.
Old 02-13-2011, 08:05 PM   #1766
premier00000
Member#: 251060
the strut spacers might be what i go with... i have [summer] wheels with a low offset (+35) and i rub over every bump with no cargo, so the extra inch should be a little more helpful, especially since i might be going on a nice long road trip in the next few months.
Also, what do all of you guys with bigger tires do about the speedo and odometer? I'm sure its probably way off. i have 205/60-16 on my car right now, and it seems a bit off.
Old 02-13-2011, 10:35 PM   #1767
dgsblb2
Member#: 197278
1999 Lifted OBS
I've just dealt with it, it doesn't annoy me at all. My tires are exactly 10% bigger, so if it reads 50, I'm going 55... if it reads 70, I'm going 77. Very simple for my situation.
dgsblb2 is offline   Reply With Quote
Old 02-14-2011, 01:28 AM   #1768
B-tons
Member#: 144352
2006 Impreza Wrx TR
Grey
Just had a great couple hours reading and scoping out some sweet pics for all 71 pages. Well done all I'm feeling inspired!
B-tons is offline   Reply With Quote
Old 02-14-2011, 07:43 PM   #1769
Hotwax
Member#: 262924
2004 RS 2.5
Red
How about Snow prepped...
Hotwax is offline   Reply With Quote
Old 02-14-2011, 10:02 PM   #1770
bugeye-joemomma
Member#: 192841
2002 Wrx
Sedona Red
a few oldies from 09:
bugeye-joemomma is offline   Reply With Quote
Old 02-17-2011, 04:37 PM   #1771
bugeye-joemomma
Member#: 192841
2002 Wrx
Sedona Red
i wouldnt call this lifted, or rally prepped. but these tires are pretty nasty when it comes to off road grip:
Old 02-17-2011, 09:28 PM   #1772
biebs96
Member#: 238035
yay... where are you in monmouth county????
biebs96 is offline   Reply With Quote
Old 02-17-2011, 10:47 PM   #1773
bugeye-joemomma
Member#: 192841
2002 Wrx
Sedona Red
Middletown. You from around the area?
Old 02-18-2011, 12:00 AM   #1774
pjkun
Member#: 160678
04 WRX Impreza
Originally Posted by bugeye-joemomma View Post
215/65R16 Grabbers? Are you on stock suspension also? Wondering because I absolutely LOVE how that looks.
pjkun is offline   Reply With Quote
Old 02-18-2011, 08:34 AM   #1775
bugeye-joemomma
Member#: 192841
2002 Wrx
Sedona Red
yes you are correct about the tires, and that is stock suspension. only thing is i had to cut the front flaps(width wise) on the inside of the wheel well because the tires would rub against the flaps when your turned the wheel lol.
SOA gotta love 'em or just plain hate 'em kalbo-1 Warranty Issues & SOA Problems 1 01-19-2004 08:29 PM
Hot or Not or Just Plain Ok.... n20x3whitewrx Member's Car Gallery 28 07-29-2002 10:05 AM
McRae: Dedicated or just plain nuts? SubaruStu Motorsports 2 03-20-2002 09:55 AM
Chamois, or just plain Sham? Lifino Interior & Exterior Modification 7 04-11-2001 12:01 AM
Jinxed? Or just Plain UnLucky??!! silverSurfer General Forum Archive 6 06-30-2000 10:27 PM
Message Board Statistics All times are GMT -4. The time now is 01:09 AM.
