Old 03-23-2007, 08:42 PM   #1
bdon22
Member#: 113940
2006 WRX
Steel Grey Metallic
Default Limited number of ECU flashes?
This article states that after 100 or so reflashes the ECU becomes dead. Is that true?
http://www.subarureview.com/articles.php?id=24
bdon22 is offline   Reply With Quote
Old 03-23-2007, 10:15 PM   #2
Force
Member#: 123515
2005 vette c6 z51
LeMans Blue
I've heard of this....but COBB seems to have sorted everything out.
Force is offline   Reply With Quote
Old 03-23-2007, 11:02 PM   #3
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
not true. if you search you will find people with over 200+ flashes
AWDWRXLOVER is online now   Reply With Quote
Old 03-23-2007, 11:58 PM   #4
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Originally Posted by AWDWRXLOVER
not true. if you search you will find people with over 2000+ flashes
Fixed for accuracy.
On enginuity some people came out and said that the 100 reflash is not a limit, it is a minimum reflash guarantee for the flash memory as specified by the manufacturer. Anything after 100 and it is possible that you could have data corruption, as mentioned there are people with 20x this number without issue so far.
Old 03-26-2007, 04:16 PM   #5
jalm111
Member#: 119074
2008 STI
You're basically flashing a USB mass storage like device. After a number of writes/rewrites there is more of a chance of a corruption of data. ECU being one of the most important things on your car has to have a very high reliability thus 100 (I am basing this off what I read on here, it could be less it could be more) and below keeps it in the most reliable area. There is no physical or electronic lock preventing you from flashing over and over again but you have to keep in mind that with every flash you are slowly eating away at your ECU's reliability.
jalm111 is offline   Reply With Quote
Old 04-02-2007, 10:54 AM   #6
nardvark
Member#: 145108
2002 Impreza TS
Aye, this is the same reason that your PC manufactuter will put a big warning in the installation notes if you ever reflash your BIOS on your CPU. Statistically the chances of damage are low, but they're high enough that they're covering their legal liability...
nardvark is offline   Reply With Quote
Old 04-02-2007, 11:31 AM   #7
Freon
Member#: 88322
2009 BMW 135i
Who has done 2000? I know I've seen two or three claims of 300+. I'm probably at 70-80 myself.
Nardvark: That warning has nothing to do with how many times you can flash, just that if it fails for some reason (you lose power, your 3yo pulls the plug, etc). So it isn't a good idea to flash your computer during a thunderstorm. On a car, it'd be hard to pull the ground off the battery on accident during a reflash, and you don't have to worry about losing utility power.
Freon is offline   Reply With Quote
Old 04-02-2007, 11:57 AM   #8
fasterthanurwrx
Member#: 82734
I have 350+ Flashes on my 05 STi.
I use Enginuity...
It has great support and sweet logging w/ map tracing!!
fasterthanurwrx is offline   Reply With Quote
Total Number Of Flashes An ECU Can Take subydude Open Source Reflashes 19 03-30-2010 02:09 PM
Limits of ECU Flashing (Enginuity) Sko Commercial ECU Reflashes 13 09-26-2007 02:57 AM
IL: Numerical limitation on number of lights? skghori Mid West Subaru Owners Club Forum -- MWSOC 6 06-27-2006 05:32 PM
Purchase of ECU Maps for use with Open Source Flash Utilities? f4phantomii General Community 10 03-30-2006 11:06 AM
Dyno Flash ecu flashing for WRX / STI in West Palm Bch. 1/8 and 1/9 Dyno Flash South East Region Forum 7 12-20-2004 09:21 PM
