Old 03-24-2007, 03:52 PM   #1
MasterKwan
Member#: 98961
2003 WRX
Default Tool for adjusting the valve clearance
Subaru shows a special tool to press on the valve springs so, you can fish out the valve adjustment disks when doing the valve clearance. Do I need that tool or are there other ways to get the job done?
Old 03-24-2007, 04:04 PM   #2
Jasper
Member#: 80136
2006 Ford F-150
you can make one, or there is something similiar you can buy through SnapOn.
im using one a buddy of mine made, although i havent used it to reinstall the retainers/keepers yet...but it did have all 16 valves out of the heads in ~ 30-35minutes.
tool looks like this
http://i135.photobucket.com/albums/q...n/DSC_1776.jpg
http://i135.photobucket.com/albums/q...n/DSC_1774.jpg
and you need the larger c-clamp style spring compressor
http://i135.photobucket.com/albums/q...n/DSC_1777.jpg
this is only if you're replacing springs though.
if you're talking about adjusting valve lash (its unclear from your post), you dont need to touch the springs or retainers. you remove the valve covers, measure the clearance between the cam lobes and the buckets, and if its out of spec, use the FSM to find the correct size bucket, and remove the camshaft and replace that bucket.
your info says you have an 03. you SHOULD have shimless buckets. if you have shim-over buckets, now might be a good time to swap over.
Jasper is offline   Reply With Quote
Old 03-24-2007, 04:25 PM   #3
MasterKwan
Member#: 98961
2003 WRX
I guess "lash" would have been more descriptive.
Yeah, I see. The manual I'm looking at's an 02. So, you make it sound like the 02 and 03 are different and the 02 uses the shims and the 03 uses the buckets. Think I'd prefer the shims...
Why are shimless buckets better than shim over bucket?
Old 03-24-2007, 04:44 PM   #4
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
the shims can break under certain conditions. i believe that the early 03 still have shim/bucket valves, and they switched late in 03 and in 2004.
PaulRex is offline   Reply With Quote
Old 03-24-2007, 04:48 PM   #5
MasterKwan
Member#: 98961
2003 WRX
Thanks. I guess that means I need to take a look at what I have.
Tool for easily removing valve springs Splinter Built Motor Discussion 6 03-31-2010 08:53 PM
Which Special Tool for holding the cam sprockets in place during timing belt job? WRX.357 Service & Maintenance 7 06-20-2007 10:31 AM
Can't adjust the valves, or is chilton wrong? Plays_With_toys Legacy Forum 13 04-30-2005 09:34 AM
Tool for cutting the front bumper cover for FMIC? sflint50 Interior & Exterior Modification 13 02-08-2005 04:16 PM
Valve adjustment tool for 98 2.5RS FatCatTurbo Private 'Wanted' Classifieds 0 02-29-2004 08:31 PM
